Question about NexxTech Computers & Internet
I bought (used) a NexxTech USB Powered Vacuum Cleaner Model No. 2616513. It did not include a USB cable (USB-DC 5V cable line). Where could I order one?
  • 4 Answers
SOURCE: no power (orange) charge light
Hi there, I am assuming that it was working ok until you tried to charge it then?? I have come across this problem before and you are right about the fuse, there is a fuse on the charge/power circuit that is located in the very top right hand corner of the motherboard, next to where the black power lead attaches to the motherboard - if you repair or bridge that fuse then it will work fine assuming that like I said at the begining it was working before you put the wrong charger in. If you cannot repair that fuse then the console will work fine if you can charge the battery without using that PSP (i.e. another psp or third party external charger) as there is no fuse on the battery circuit as there would not be a surge in power unlike the mains circuit. If you need more information or if this reply is not clear then let me know and I'll get an image of the fuse you need to repair.
Posted on Sep 03, 2007
SOURCE: rainbow d4 model wet/dry/vacuum cleaner
Go here.
Posted on Mar 23, 2008
SOURCE: WD hd won't start up when turned on until you plug into usb
i cant put a solution for this but try the exact software for the disk which it came with this can help.Im also trying for the software
Posted on Nov 07, 2008
  • 96 Answers
SOURCE: How to replace the belt on my bissell model 3512-9 vacuum
Tehre are tabs on the bottom. Push them in the direction of the arrow (one at a time) and lift with some force on the cage thingy that partially covers the sweeper. Do the same for the other side. It doesn't matter which side you do first.
Posted on Nov 26, 2008
SOURCE: Kenmore Vacuum cleaner #175.3866180 bags and belt
I logged into the Kenmore website, entered the vacuum model no. and found that the bag has been superceeded by 20-50004, which appears to be available only from Kenmore. The belt required is #5270.
Posted on Aug 03, 2009
How to charge it
Hi Stacey
How to charge "what model" Cell Phone
iPhone & others usually charge from the USB cable that it comes with.
Plug into any USB port (5v DC)
Some chargers supply more current which can give a faster charge. iPad chargers supply 2A where as iPhone chargers are 1A
Sep 13, 2015 | Cell Phones
Nexxtech power bank, how do I charge it
On the side where it says IN, is a micro USB connector. Put in the connector from the cable that came with the power bank, and put the other end of the USB cable in an external charger, or a PC USB socket of which you are sure it delivers 5V. You should see the bleu lights on the IN side flicker, and one by one they start burning continuously. When all 4 burn continuous, th bank is full. Discharge goes on the other side and you have to press the button, to start the charge cycle.
Perhaps you also should see what is on Youtube about the power bank :
Nexxtech USB Power Bank Quick Look
Nov 02, 2014 | Televison & Video
What is the DC Voltage
If it has 3.5" Hard disk inside DC voltage is 12V.
If a 2.5" Hard disk inside the DC voltage is 5V and can be powered by USB alone.
Nov 21, 2013 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
I have a nexxtech 7 port usb 2.0 hub which prevents boot to windows. Incompatible?
This hub is USB powered through your computer while you are using the first ports available. If you use ALL at once ports you will need to add the appropriate AC/DC external power adapter to supply the needed extra power.
Jul 03, 2013 | Computers & Internet
Can I charge my HP 632 (that has rechargeable batteries in it; from the USB hooked to a solar charger?
You may recharge the batteries using any compatible charger. It doesn't matter to the camera whether the charger is powered by a nuclear reactor or a hamster running in a wheel. Bear in mind that the HP M632 is NOT a battery charger. The batteries must be recharged outside the camera.
Dec 12, 2012 | HP Photosmart M632 Digital Camera
Usb powered aoc monitor is blinking
Active USB cables boost the USB signal not the 5v power lines. After about 6 feet the 5v power lines will only provide 4-4.5 volts and this is not enough to power the monitor. For this to work you will you will need to also use a powered USB hub at the remote end by the monitor. The USB hub will supply the power and the monitor needs and the active USB cable will provide the signal.
May 03, 2012 | AOC e1649Fwu 16" LED LCD Monitor - 16:9 -...
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Where to get in car charger for evesham 7211
I just bought an in-car charger for the 7211 on ebay.
It is 5v with a 2amp flow.
It's not for the mini-USB port on the side but for the dc input hole on the other side.
I've just plugged it into my laptop via the mini-USB port to see if it will charge that way but it doesn't seem to be doing.
Hope this helps.
Aug 09, 2009 | Evesham Nav-Cam 7700 GPS Receiver
Does the ativa ATIVA-MP400 player usea a power adapter to charge?
It is supposed to charge with either an adapter that plugs into the wall ie: DC 5V 400mA, or through a USB 2.0 port on your computer. The 1.1 USB ports do not carry enough current to properly charge any USB powered items.
Apr 09, 2009 | Office Depot Ativa D5772 Phone
Usb drives
USB hubs operate at 5V DC power, as do a lot of things on your motherboard do. They are able to transmit DC power to a device which makes it possible for items to be plugged straight into a USB port and not have an external power supply.It sounds as though the main connection between the USB points and the power supply has become broken, as a lot of USB points are connected in series to save space. Also, one point on the USB line could have possibly become grounded. A fewer simple measurements with an OHM reader may help in this situation.
Mar 25, 2008 | Computers & Internet
Computers & Internet Logo
13 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
