Question about Denon AH-D1000 Headphones
Denon AH-D2000 Headphone hinge broke
The little rivet/screw that holds the headphone to the head-cover part snapped off after only 2 weeks of use. The little plastic piece, including the screw going through just snapped in half. Is there a replacement part for this, because apparantly I bought them new from an 'unauthorized' retailer according to Denon, so they won't warranty them......which is complete ********, because I purchased them brand new in box, from an online retailer.
  • HW_Dude
    HW_Dude May 11, 2010
    Well this is made in China for you !!! Denon happily manufactures in China yet charges as if they were made in Japan. What a ripp off. Try to send them back to the Retailer and get it replaced with them.
5 Suggested Answers
SOURCE: Bought new AH-D2000 Denon headphones.
This is an ongoing problem with Denons, if only your screw fell out like mine, you have to do the following to screw it back in properly.
1. You have to remove the ear cups from the head band part.
2. To do (1), you have to remove the styrofoam ear **** (the soft leather part) by press down on the soft part and rotating it counter-clockwise.
3. With the ear **** removed, you will see a total of 8 screws. 4 are flat and on a higher plane, and other 4 are inside holes. Unscrew the 4 that are bigger and on the higher plane. This will remove the plastic round back from the ear ****.
4. With the big round plastic part removed, you will now have the space to properly screw in the fallen screw.
5. Make sure to use Lock-tite to hold the screw in place so it doesn't fall out again.
Posted on May 18, 2009
Grubhead
  • 5391 Answers
SOURCE: Right speaker is not operating on a set of AKG headphones.
Go in by the part that fits to your ear. You will need to remove the ear pad. Also the foam, you might have to force the foam off, you can glue it back when done. With them gone you should see access screws.
Posted on Feb 17, 2010
Grubhead
  • 5391 Answers
SOURCE: the conection plug broke.
See if my tip on headphones will help you with this problem.
Posted on Apr 14, 2010
Grubhead
  • 5391 Answers
SOURCE: Is there anyway to repair the foam earpiece on
Have a look at my tip on headphone problems just click my user name to find it, you will find an answer at the bottom of it.
Posted on May 26, 2011
My denon 3808ci reciver has sound out put when you connect head phones but nothing coming out of the speakers when the head phones are disconnected?
hi,
In all receivers when you connect the headphone it will swich off the speakers. Its normal. When you use the headphone there is no need for external speakers its the principle behind this. .
ok
Sep 09, 2011 | Denon AVR 3808Ci Receiver
My Harley has a bad ignition control module and where it's located at there are what looks like 2 pot rivets holding the outside cover is this factory do I just drill them out and put new ones back...
Yes, you do have to drill the heads off the rivets to get the cover off the timer cavity. Drill just enough to get the heads off the rivets with a large diameter drill bit. Before you remove the old ignition unit, mark the unit and the inside of the timer cavity so that you can install the new unit in EXACTLY the same position. This way you'll get the timing right. Do not use standard rivets to reinstall the cover plate. They are special rivets. Standard rivets will allow the broke piece to drop into the timer cavity and destroy your igniton system. You can get the rivets from you local dealer or you can replace the cover with a decorative aftermarket cover that uses screws instead of rivets.
Good Luck
Steve
Jul 30, 2011 | 2000 Harley Davidson XL Sportster 883
Is there anyway to repair the foam earpiece on denon ah-d210 over the ear headphones?
May 24, 2011 | Denon Audio Players & Recorders
How can the wire into the right headphone be replaced?
See my tip on dealing with problems with headphones. Just click my name to find it.
Jan 29, 2011 | Denon AH-D1001 Headphones
The headphone jack broke. It is kind of pushed into the mixer. Is this repairable?
I repaired mine when that happened.... you have you unscrew all the screws on the top plare there is like 5 or 6 silver ones..Remove faders (2 volume 1 headphone) then remove the top plate. Then unscrew the the black screws on the side and front of the mixer... NOW THIS PART IS IMPORTANT..from the corners of the mixer there will be a little lifts carefully lift the top of the mixer up JUST A LITTLE BIT... have someone hold it or just rest it diagonally so you can unscrew the jack from the back MIC unless you were able to salvage the jack from the headphone if that silver and black piece are gone your going to have to borrow it from the mic... dont worry the mic will still be functional because its better set in that the headphone jack... now use the outside piece and bring the headphone component to the front where its suppose to be so you can screw the 2 back together.. then put every back together in a reverse order and you should be fine.... if you have anymore questions email me at DjAnthem222@yahoo.com
Sep 18, 2010 | Nu Mark Numark Dxm06 DJ Mixer With 12...
The conection plug broke.
Apr 05, 2010 | Denon AH-C751K Headphones
My frigidaire microwave door is sagging and is about to fall off
EASY get a machine screw, nut with washer. I believe I used a 1/8" machine screw.....(find something small to fit in the hole on the bottom hinge.
First step, take 3 screws off bottom to expose hinge area. Have someone hold it or support it so wires to the light do not pull out,.
Pop the machine screw through the front and then with your fingers get the washer an nut and tighten down.
If you want the professsional look. Paint the machine screw white first with a enamel white paint.
Sep 03, 2009 | Frigidaire PLMV169DC Microwave Oven
Head phone jack
Flip the Sansa face down with the headphone jack to the left. Take the cover off the battery then remove the 2 screws by the sync port. This frees up the plastic that covers the last screw. But before you can remove this piece you need to lift the 2 black tabs in the middle and slide your nail between the seam between the black and silver areas near the hold button. The rest comes apart easy or the couple I have fixed the headphone jack have.
Jan 05, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Bought new AH-D2000 Denon headphones. Only used a week. One earphone came detached from the headset. Looked carefully, and discovered the screw came out. Have washer and screw, but the area to put the...
May 24, 2008 | Denon Audio Players & Recorders
Taking apart headphone cases
Carefully remove the padding/leather cover of the headphone and you will see that there are three screws there on the inside part of the casing. Unscrew them and the case will open. Do not try to force open the cases...
Nov 13, 2007 | Philips (33-01-031) Headphones
Denon AH-D1000 Headphones Logo
1,105 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
