Question about Bose Audio Players & Recorders
Campanion 2 Bose speakers: Is there any reason why I couldn't run this system from a 12 volt DC source, as long as it is receiving matching voltage (11.95-12.25 V DC with correct polarity)?
SOURCE: MISSPLACED AC POWER SUPLY FOR "MY BOOK" 250 GB USB.
THE ANSWER TO MY QUESTION WAS FOUND OUT BY MYSELF BY VISITING A REPAIR / SERVICE DEPARTMENT AND MAKING ENQUIRIES CONCERNING THE DC OUTPUT OF THE AC ADAPTER ASSOCIATED WITH THE WESTERN DIGITAL, MY BOOK 250GB USB. tHE VOLTAGES ARE THESE. : - AC INPUT = 100 - 240 VOLTS 50/60 HZ
DC OUTPUT = 12 VOLTS ( REGULATED ) 2 - 0 A
CENTER PIN OF 12 VOLT DC INPUT PLUG IS " POSITIVE "
THANK YOU FOR THE SPACE TO ASK MY QUESTION.
Posted on Feb 19, 2009
  • 71 Answers
SOURCE: Samsung TV and Bose Campanion 3 speakers
Are these PC speakers? OF so you need a stereo RCA to min-jack cable, assuming the TV has a set of RCA audio outputs.
Posted on Jul 26, 2009
  • 4 Answers
SOURCE: What is the DC voltage, current, and polarity of AC adapter
Howya mate , i wouldn't use a adapter which your not 100% sure belongs to it , even something you'll have the right connection and the right voltage on the plug it will still fry the chip or electrics cause the designers of the item designs adapters in such a way the voltage might be the same but the current is altered and that's why you have to buy a replacement adapter at double the price.
Posted on Aug 19, 2009
DaveMc3
  • 57 Answers
SOURCE: I have Bose® Companion® 2 Series I
Each device is different.
If the receptacle for the plug is not marked, you have few options.
I suggest the following.
Go buy the exact same setup from a store you can easily return it to.
Take the whole box to Radio Shack and explain that you need a power supply to replace the power supply in the box. They will sell you one, plug and all, for about $10-15.
If you have a DVM (Digital Volt Meter), you can check the voltage and polarity yourself, and buy what you need, test it out, and install it.
--Dave
Posted on Feb 08, 2010
Testimonial: "Good suggestion."
SOURCE: there are 2 sets of wires on the rca rt2760 home
one is for the speaker connection the other is a control wire for the sub that should have a white plug on it to plug in the back of receiver
Posted on Dec 13, 2010
Problems with bose companion II 12 volt adapter
I found that the 12v power pack from an external hard drive works fine. I think you need the 5.5 x 2.5 mm plug.
Jun 12, 2012 | Bose Companion 2 Series II Multimedia...
After playing music for a good 30-45 minutes, they overheat and shutdown! Its not turned all the way up but about a 7 on a scale of 1-10 level! I own a Companion 3 series II BOSE computer system! Live in...
Just because the system's volume knob can be set to 10, it dies not mean that this is a continuous rating.
The system is most likely overheating, and going into thermal protection.
If you feel like doing a custom mod, fit a small cpu fan to cause airflow over the amplifier ic or it's heatsink. CPU fans generally run off 12 Volts DC, and many speaker systems use the same voltage.
Jun 08, 2011 | Bose Companion 3 Computer Speakers
I only need the AC Adapter Campanion 2 for my Bose spearkers. How can I find just the adapter?
Look where the AC adapter would plug in.
Look for "rating", e.g., 'DC' or 'AC',
and '6V' or '9V',
and look at the size/shape of the plug.
Then, go to a "Dollar Store" or "Thrift Store", and try to match the ratings and the plug-layout with the available inventory.
Or, contact BOSE, and see if you can buy it from their web-site.
May 28, 2010 | Bose Companion 2 Computer Speakers
There are 2 sets of wires on the rca rt2760 home theatre system subwoofer, i know thay the purple ones are the speaker inputs......but the red and black is dc input for the amp thats inside the...
Oct 13, 2009 | RCA RT2760 System
Jul 25, 2009 | Bose Companion 2 Computer Speakers
Yamaha RX-770 Receiver display quit
there is a bulb inside the backlight on the lcd display.it is 12 volt and alot of manufacturers run it from the +- 15 volt preamp power supply,on the plus rail.when the bulb burns out it can activate the dc speaker protect,or some other 12 or 15 volt circuit..if it is a flourescent display that is a different problem.those run on 5 12 18 and -32 volts.there is also a 6 volt ac filament voltage.you need the schematic.
Jun 14, 2009 | Yamaha RX-770
Can Bose acoustimass 3 series II run on 12v????
I have the same speakers - and, system. I have a few comments. I don't think you can do what you want. This stuff is all specfic to bose. Man, they really don't want you using anything else. Question for you, I need one of those speakers - as, one of mine broke...I would love buy it from you if you don't use them any more. Let me know. rockyruggiero@comcast.net 630-723-7391 my name is Rocky
Feb 26, 2009 | Bose Acoustimass 3 IV System
Power Requirement for Delphi Roady 2 XM Radio
Radio shack has a unit that plugs into a 110 socket and will accept the 12V plug that is standard with the radio. I use my unit in the house, car and on my motorcycle. The part number is 22-505 for the Radio Shack part.
Dec 02, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Changing the inpout voltage of inside bose Acoustimass module
Probably not, but you can install a step-down transformer if there's room inside the unit. Since these speakers don't use much current, a small transformer will work. It doesn't have to be a 220-to-110 transformer either - any transformer designed to cut the voltage in half is fine. A 24 volt-to-12 volt transformer will also work.
Aug 13, 2008 | Bose Acoustimass 15 System
29 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
