Question about Haier Dehumidifiers
Fairly new unit not drawing water, worked fine last year Haier dehumidifier
Also maybe my settings are wrong what setting is best to set at ?
INSUB
  • 15 Answers
SOURCE: Doesn't want to stay on...
Most likely the fan motor has broken. Without the fan, the compressor will overheat. There is a safety device inside that automatically shuts off the compressor to keep the overheating from destroying it. Check to see if you can feel air movement in the front or back of the unit while it is running. If not, then the fan motor has definitely broke. I had this exact problem on mine.
If you take the unit apart, you will find a parts list inside the unit. It will be inside a small plastic pouch. You can order a new fan motor from Sears. The cost is $30 plus shipping.
You will have to move the condensing coil in the front out a bit in order to exchange the motors. Just be careful not to break any of the copper lines. They are copper so they will flex quite a bit without breaking. Still, use caution. If you break the lines, all the refrigerant will leak out and your unit will be useless.
Posted on Nov 18, 2007
IrishDruid
  • 2712 Answers
SOURCE: Dehumidifier does not collect water.
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 29, 2008
  • 4 Answers
SOURCE: Dehumidifier not collecting water
most probable cause of a dehumidifier not collecting water when it appears to run fine otherwise is a dirty heat exchanger. It is unlikely that a huge spread in the time a unit works is caused by failure of the compressor of loss of refrigerant. On the other hand, people use their units in very varied conditions of dust in the environment with expected short to long operating times before failure. Here's how to fix this problem in two steps.
Step 1: Determine if your compressor and refrigerant sealed unit is operational
Step 2: If Step one is negative, dispose of the unit - specialized equipment is required to repair or recharge a compressor. If step one is positive, then clean the heat exchanger.
This site did not allow me to post the full instructions because they exceed an unspecified upper limit to message length. What a waste of time. In order to be helpful, please contact me at j_sjohn@hotmail.com and I will email you a file with a complete set of instructions. Cheers.
Posted on Jan 05, 2009
SOURCE: Dehumidifier Freezing up
Your dehumidifiers are LOW on freon. Over time, small leaks will occur and the coils will freeze. Take your units to a qualified repair shop (central air, or furnace) and recharge the freon.
Posted on Jun 05, 2009
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: I have a frigidaire LAD704DUL 70 pint dehumidifier. Last year it worked great. This year, it has not collected any water in the bucket. The motor runs, it is on CO setting but still no water. I have c
    If you have a dehumidifier that is not producing any water then you are wondering what you need to do to get this thing to work for you. In some cases you may be able to do something and in other situations there may be nothing that you can do.
    If you do not hear the compressor running and the unit says that the humidity in the room is higher then the setting, then you have a problem with your dehumidifier.
    A few things that can cause this are:
    The circuit board relay has gone bad...replacement of this board will often cost more then a new unit. This also is a very common problem with many dehumidification units.
    The compressor has failed...if you hear a buzz for a few seconds, every few minutes, then you have a bad compressor or at least bad start components on the compressor. Either way it again is a costly repair.
    If the compressor is running and the coils are not getting cold then you have a refrigeration system leak. Recharging or fixing these units is very difficult and is another costly venture compared to the price of a new dehumidifier.
    If the compressor is running but the fan is not, this also will cause low water production and continual freezing of the coil.
    If the compressor and the fan are running but the coil is totally blocked then you will get no water production. Air needs to be continually moved over the cold coil to get the water out of the air.
    If nothing is running, then you may also have a control board failure. Or the humidity sensor or humidistat has gone bad which tells the machine to run. If the sensor says that the humidity is low enough then it will never run.
    Also if nothing is running check the float switch or the bucket switch. Many of these switches are very touchy and if you do not have the bucket in place just exactly right it will not trip the switch to allow the unit to run. These switches often are more fragile then they should be and break easily. The good thing is that when available they are easy to replace and relatively inexpensive.
    There are some parts available for a few brands, but with the prices for most of the parts that you can replace running anywhere from 40.00 - 80.00 dollars, replacement parts with labor to install them, makes a repair more then the few hundred dollar cost of many of these dehumidifiers.
    As you can see there are quite a few things that can cause your dehumidifier not to work. Systematically go through the list and eliminate things to get to the bottom of the issue causing your problem and then decide if it is worth spending the money to try to fix the old unit. Only you can make that decision.
    Posted on Aug 14, 2012
    How many watts is a DE45EJ-L dehumidifier?
    There is a review website that claims the unit draws 590 watts. The refrigerant this one uses is R-134a.
    Haier 45 Pint Dehumidifier Review
    A slightly larger unit is also available from Haier, the DE65EJ that uses R-410a, which is a more efficient refrigerant and allows the unit to be perhaps 20% more efficient. That larger unit is rated for 65 pints a day, and uses 710 watts. It is a bit heavier than the DE45EJ also.
    Jul 01, 2014 | Haier Dehumidifiers
    My dehumidifier does not drop any water into the drawer. I cleaned the filter and made sure the settings are correct. My basement has 67% humidity, according to the gauge. The unit is less then a...
    There are many reasons why a dehumidifier willnot work or collect water.
    Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
    Dehumidifier is running but no water is in bucket
    heatman101
    May 29, 2011 | Haier 45-Pint Dehumidifier
    I have a brand new Haier 45 pint Dehumidifier. The manual gives no advice on setting temperatures. What do I do? I set up with hose going in to my sump pump but no water seems to come out
    Most of the time you set @55% RH. But on most Portable dehumidifiers you dont have a setting that tell you percent. Set about 1/2 way and see how much water it put out. That is about 60%. Go from there. Rus
    Oct 29, 2009 | Haier 45-Pint Dehumidifier
    Dehumidifier runs but does not collect water
    I have dehumidifier Whirlpoot Gold Model #39R171E Serial #H/XE11M1K 6203A it was working fine last year, but this year it is not collecting any water, it is running for day. I opened it, cleaned the filter (which was mostly clean) & it still has not water in bucket. What is wrong & is it possible to fix it by myself.
    Jun 10, 2009 | Haier HDN655E Dehumidifier
    Not operating properly - doesn't draw water
    May 18, 2009 | Haier HD306 Dehumidifier
    Cheers!
    IrishDruid
    Aug 05, 2008 | Haier HDN655E Dehumidifier
    Kenmore Dehumidifier
    if the compressor is running it sounds like a refrigerant problem or dead compressor in both cases its not cost efective to repair dan
    Jul 05, 2008 | Haier HDN655E Dehumidifier
    Dehumidifiers Logo
    71 people viewed this question
    Top Haier Dehumidifiers Experts
    Steve
    Shawn DuRee
    Michael Vincent Cruz
    Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
