Question about Pool & Spa
Inflators not woke no on purespa - Pool & Spa
Just had my air bag inflators replaced due to the recall. Why is SRS light now on?
The SRS light should not be on after the recall work was done. The "mechanic" did not complete the job and the dealer should make things right without inventing a $600 part that needs to be replaced.
Feb 16, 2016 | 2004 Honda CR-V
My Purespa's bubbles wont work. The air pump keeps blasting the air and dislodging this one balloon clog piece. What can I do to make it stop dislodging this piece?
Is it plugged in "All" the way?
Possibly whatever "Retaining" lock grooves that kept it in originally, was smoothed out with the removal of it? Maybe a new piece will correct this?
Maybe contact Intex:
1-800-234-6839
OR VISIT WEBSITE: WWW.INTEXSTORE.COM.
Owners Manual attached
http://www.pool-j.com/pdf/574616.pdf
Intex PureSpa Owners Manual.pdf
Mar 10, 2015 | Intex Pool & Spa
Intex purespa error code
sounds like shorted temp sensor
Jul 13, 2014 | Pool & Spa
What fuse is connected to the radio
yes you sure did ! check in the owners manual for fuse location . the safest way to use those inflators are with a cigarette lighter adapter with alligator clips right to the battery hope this helps
Jul 26, 2010 | 2003 Toyota Corolla
How do I remove the ignition lock cylinder from a 2003 Saturn Vue for rekeying?
REMOVAL
  1. Disable SIR system. (Refer to "SIR Disable/Enable Procedure (For Frontal and Curtain Inflators)".
  2. Disconnect negative battery cable.
  3. Remove lock cylinder bezel from steering column shroud by carefully prying with thin blade screwdriver.
  4. Remove shroud fasteners and remove steering column upper and lower shroud panels.
  5. Insert key into ignition lock cylinder and rotate to RUN position. Then rotate ignition cylinder back to ACC position.
  6. Depress locking button on side of ignition module assembly with a thin pick-type tool. Slide lock cylinder assembly from ignition module.
INSTALLATION
IMPORTANT: Actuator blade within ignition module housing must be in ACC position to install lock cylinder assembly. If rotated, replace it to ACC position, using needle nose pliers.
  1. Insert key into ignition lock cylinder and install into ignition module.
  2. Install steering column upper and lower shrouds and shroud fasteners.
  3. Install lock cylinder bezel.
  4. Connect negative battery cable.
  5. Enable the SIR system. (Refer to "SIR Disable/Enable Procedure (For Frontal and Curtain Inflators)".
Apr 07, 2010 | 2003 Saturn VUE
I was wondering if I bought airbags designed for 2000-2001-2002 Saturn SL series can I put it into my SL1. I found I can buy replacement airbags but want to be 100% sure they will go in as replacements for...
Air Bags For S-Series Should Fit 2000-2002 All. SDM's there are 2 part # 's One for Standard Air Bags & One For Air Bags With Side Curtain Inflators!!
May 02, 2009 | Saturn SL1 Cars & Trucks
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
