Question about Jensen Car Audio & Video
Jensen ms2a keeps disconnecting from wifi - Jensen Car Audio & Video
Wifi keeps shutting off
restart your tablet and restart the wifi router and see if that helps.
May 24, 2016 | Tablets & eReaders
Wifi keeps disconnecting
Change WiFi channel as another WiFi signal is conflicting with yours or try to find conflicting signal owner and ask them to change theirs
Mar 28, 2015 | HTC Cell Phones
Why does my Jensen TV keep looping?
try leaving off for about 15 minutes then turn back on may have a button battery for mrmory if so will need to remove for a couple minutes hand
Jun 28, 2014 | Jensen Televison & Video
Wifi disconect
if the wifi keeps disconnecting or wont connect that means your wifi cord is out.
Dec 12, 2013 | Apple iPhone 3G
My wifi keep saying disconnected this phone is not on I just let my son use the phone to download apps I reseted everything because it was not working right yesterday and now i can't get the wifi back
try this solution...
1. select "airplane mode" to disable all wireless connection then turn off your phone.
2. turn on your phone then disable "airplane mode"
3. turn on your wifi now.
Mar 05, 2013 | Cell Phones
Laptop and xbox keeps disconnecting on wifi.no
your wifi may have a weak signal. Either the devices aren't close enough especially when running both and eating up all that bandwith, or you need a more powerful router.
Dec 16, 2009 | Zyxel Prestige 660HW Wireless Router...
My indash jensen radio keeps shutting down when turned up?
Sounds like there's a power problem. First take out the radio and leave it connected. Turn on the radio normal volume, then disconnect the radio's antenna. If the radio shuts off then you need a better ground. If the radio doesn't shut off then you need to run power wires to the fuse box.
The only other thing is you have a bad speaker that only shorts out when you turn it up. Disconnect all but one speaker or one speaker at a time and see which one is the problem.
Jul 08, 2008 | Jensen Car Audio & Video
Car Audio & Video Logo
53 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
