Question about Pool & Spa
We have replaced the auger motor twice on our kitchenaid superba Kscs25inss02. The motor keeps dying because water is getting inside the motor. How do you prevent this?
Each new motor came with a shaft seal but it doesn't seem to make a difference.
  • 2651 Answers
SOURCE: Kitchenaid Refrigerator Superba
heres a part number for the valve, somple enougth to install just turn off the water supply and installe ne wvalve, exact replacement. soundsas if its not closingt correctly allowing water to tricklel in part number 4389177
Posted on Apr 08, 2008
  • 1314 Answers
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
Posted on May 13, 2008
SOURCE: kitchenaid superba icemaker leaking/freezing in freezer section
Thank you, I am going to go check right now
Posted on Nov 09, 2008
  • 12 Answers
SOURCE: How do you replace the water filter on a
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
Posted on Oct 19, 2009
SOURCE: Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Posted on Jan 22, 2010
I have a Frigidaire 1000, 1200 series. I noticed the dishwasher motor sounding louder lately while it was running. The other night I turned it on to run. Later I noticed that the three lights on the...
Check for obstructions inside in the bottom first and or the pump might be clogged. If it's not some type of obstruction or clog it is likely your motor has died or is almost dead. Start planning on replacing your dishwasher. I suggest to go with a higher end brand. Kitchenaid Superba EQ, Electrolux Wave-Touch, Bosch 800 Series for example.
Sep 10, 2013 | Frigidaire Dishwashers
Even though the Ice bucket is full it does not distribute through the door of kitchenaid superba
Take the ice container out and see if possibly ice has frozen the auger to the ice bin, clean and dry. Open door and press light switch in while someone presses dispence ice. Do you see the auger motor try to turn in the back? Can you confirm that the KSCS25INSS is your model number? I am glad to assist you in locating your problem even tracing the wiring if it comes to that.. Click Here=> for a KSCS25INSS Wiring Tech Sheet just in case you need to follow through the wiring with me. Let me know what you comew up with,Sea Breeze
Sep 07, 2012 | KitchenAid Superba Architect KSCS25INSS...
Will not drop cubes fills with water but does not rotate to push out cubes
first is it the ice maker that doesnt drop the cubes or the auger motor on the door you have to determine if your icemaker is droping the cubes into the bin if its not the replace the ice maker if it is replace the auger motor on the door you can find both of these parts at marcone hope this helps
May 18, 2010 | KitchenAid Superba Architect KSCS25INSS...
No ice comes out when pad is depressed.
does your auger turn? thats what pushes the ice doun the shoot. if not replace the auger
Oct 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice crusher does not turn
KSCS25FKSS is the model you posted under is this the correct model number.If so the motor should be behind the panel directly behind the ice bin inside the freezer.
Sep 24, 2009 | KitchenAid KSCS25FKSS Side by Side...
Problem with KitchenAid Superba KSRG25FK Side/Side Refrigerator
I found you looking for keep en mind kitchen aid is made by whirlpool good luck :)
Jun 12, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 | Ovens
Need to replace direct drive drum on Kitchenaid Superba side by side
May need to know your entire model # located on the inside in the refrigerator section. That plastic piece may unscrew but be a reverse thread.
Oct 07, 2007 | KitchenAid Superba Architect KSCS25INSS...
Pool & Spa Logo
29 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
