Question about The Office Equipment & Supplies
If a sheet of paper is 8 1/2 inches by 11 inches. To make a box with the maximum volume how many cubic inches will the box hold?
checkitright
  • 1362 Answers
SOURCE: Custoem paper sizes
Sounds like it's more of  an A4 type,
go to the settings on your pc and try to switch it to A4 size instead of letter
Posted on Oct 19, 2007
hidalgo1301
  • 5 Answers
SOURCE: Cubic inches of a Audiofonics 12
You should be able to download the owners manual for these speakers. The manufacturer will give detailed specs. on the type and dimensions of recommended enclosures for this particular speaker. If nothing is available to download, you could try to contact the manufacturer directly.
Posted on Jan 04, 2008
old marine
  • 1973 Answers
SOURCE: pink tinge to colored photos
Canon has a number of things you can check in their knowledgebase. Go here. Type "pink tint" in the search box and click Search. If you select the first item "tinted printing" you will get at least 21 things you can try (only 10 show up per screen).
Posted on Apr 18, 2008
VOTIT
  • 2071 Answers
SOURCE: Riso V800
Riso's are famous for this, i will scrub the rubber timing roll with rubber rejuvenator and clean the steel roll with alcohol.The riso paper feed clutches are weak compared to what they were in this series you may have to replace the clutch. Bud, after doing some research you need to clean the oneway bearings on the pickup and feed rolls, adjust feed table hieght and lastly check/adjust timing in drive and feed roller-you will need a manual for this.
Hope this may help;
Regards,
VOTIT
Posted on Jul 26, 2008
SOURCE: cubic feet
4' = 48"
thickness" x width" x lengh" = cubic inches
2" x 8" x 48" = 768
1 cubic foot is 144 cubic inches
768 divided by 144 = 5.3333333333------
Posted on Dec 10, 2008
What is cubic feet in 11 feet by 21 feet
You cannot calculate cubic feet from only two measurements. Cubic feet is an area of volume, such as the inside area of a box. With only two measurements you get square feet, which is a measurement of area. A box 11 feet by 21 feet takes up an area of 231 square feet (11 times 21). If the box is 3 feet tall, then you can compute cubic feet since you take all three values and multiply them together. A box 11 feet by 21 feet by 3 feet would contain 693 cubic feet of space (11 times 21 times 3).
Feb 15, 2016 | Office Equipment & Supplies
Auto sheet feeder fault
he paper’s weight may be expressed on a different basis than the paper used to rate the printer’s capabilities. For example, a 20-pound bond paper equates to 28 pounds cover and 42 pounds index papers in thickness. The differences among bases stem from the sizes of the large sheets from which the paper was cut. For example, Sharp says, bond paper’s weight is determined by 500 sheets of 17- x 22-inch stock (later sectioned into 8.5- x 11-inch reams), whereas index paper’s weight stems from 500 sheets of 25.5- x 30.5-inch paper.
Match the basis for the weight of the paper to the basis of the printer’s maximum paper weight rating. If the printer was rated on only one basis, such as cover or index, and your paper ****’s wrapper only lists the paper’s weight by another basis, such as bond.
Mar 31, 2008 | Canon PIXMA MP130 All-In-One InkJet...
I need to pull an 11" x 48" sheet through my printer
That will never work as the printer looks for pages that are standard sizes. If it comes across something that is larger, the printer reports a paper jam. Making banners is best done on dot matrix printers using listing paper. Otherwise on a home printer, you use the banner setting in your creation software, MS Word, MS Publisher, and you print as separate pages and stick them together or stick them on a backing sheet.
Oct 22, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
A book box 17 x 13 x 8 inches is how many cubic feet?
First get the number of cubic inches by multiplying the three value provided.
17 x 13 x 8 = 1768 cubic inches
Then determine the number of cubic inches in a cubic foot:
12 x 12 x 12 = 1728 cubic inches
Determine the value in cubic feet by dividing the number of cubic inches in the box by the number of cubic inches in a cubic foot:
1768 divided by 1728 = 1.023148148148... cubic feet
Oct 17, 2015 | Office Equipment & Supplies
What would 150 letter size sheets convert to in cubic feet measure
8x10 x whatever the height of the package is= cu inches. divide by 12 to get cu.ft.
Jun 18, 2015 | HP Office Recycled White 8 1/2 x 11 Inch...
What is the dimension of 2.0 cubic feet to inches
A box that is one foot by one foot by 1 foot is 12 inches by 12 inches by 12 inches and hence the volume is one cubic foot os 123 = 1728 cubic inches. Thus a two cubic foot box will contain 2 multiply.gif 1728 = 3456 cubic inches.
Aug 03, 2014 | Games
20.5 x 17.5 inches into cubic feet
That depends on the third dimension.
If you have a piece of paper that's 20.5 x 17.5 inches, the volume will be very close to zero. If you have a stack one foot high of such papers then the volume will be about 2.5 cubic feet. If you have a stack one mile high then the volume will be about 13154 cubic feet.
Jun 08, 2014 | Office Equipment & Supplies
Calculate gallons of a tank
I assume the length of a side is 16 in, and the height of the prism is 23 inches.
Volume of a prism is V_prism=(Area of base)*(height of prism)
Area of base is made up of the area of the 6 equilateral triangles with sides =16 inches. The height of such triangles is given by 8*SQRT(3).
Use the Pythagorean theorem or the trigonometric ratios to find the height of each of the 6 traingles.
Area of base =6*16*(8*SQRT(3))/2 sq in
Volume =6*8*8*23*SQRT(3) cubic inches
Calculate the value in cubic inches and convert to gallons: I leave that task to you.
May 12, 2014 | Office Equipment & Supplies
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
21 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
