Question about Building Materials
Mighty mule FM137 keypad lights up when numbers punched but doesn't open gate. Remotes work but not the keypad. Its a model 500 system with the FM137 green circuit board wireless key pad.
  • 3197 Answers
SOURCE: Liftmaster wireless keypad closes but won't open the door
If you are sure the battery is good you have a bad keypad. The signal strength is so weak it will not penetrate the door.
Posted on Aug 25, 2009
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
  • 68 Answers
SOURCE: Schematic for mighty mule 502, lighting hit gate
Well this is a BAD situation, because your opener was NOT grounded, you will have to replace the Circuit board, but since this damage was caused by an act of god "nature, being lightning struck" Than GTO, "mighty mule" will probably NOT replace the board leaving you to BUY new ones, which are about $100 to $200
Posted on Jan 24, 2010
  • 118 Answers
SOURCE: liftmaster key pad opens door with a single number punch
You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
Posted on Jun 16, 2010
SOURCE: Does anyone repair pc boards for the Mighty mule
I have used the Mighty Mule dual gate opener for 6+ years. The common failure is the relays. They are very inexpensive, less than $5 from Allied or Mouser, and easily replaced by any good electronic technician.
Might Mule will not sell the relays, only sells a reconditioned replacement circuit board for $250 - about half the cost of the whole system,
Posted on Jul 07, 2010
What is the u shaped component on the rev.counter card called? Where can i purchase this component?
  1. Mighty Mule Parts - Gate Opener Parts & Accessories‎
    Adwww.mightymule.com/Accessories‎Cable Gate Lock
  2. Driveway Alarms
  3. Gate Opener Kits
  4. Where to Purchase
Search Results
    Mighty Mule Store ' Genuine Mighty Mule replacement parts
    www.mightymulestore.com/Mighty-Mule-Gate-Opener...Parts-s/21.htm
    Genuine Mighty Mule Replacement Parts. Choose a Product Category. Mighty MuleFM200 Automatic Gate Openers · Mighty Mule FM350 and FM352 Gate ...‎Mighty Mule 500 Parts - ‎FM350 or FM352 - ‎MM600
    Mighty Mule 500 Parts ' Shop Accessories and parts for the ...
Jan 01, 2016 | GTO Mighty Mule Automatic Gate Opener For...
Why is my mighty mule FM500 gate opener opening by itself?
Cathie,
Thank you for using GTO Products. If the gate opener appears to be opening by itself, then it's receiving an input from an accessory such as a transmitter, keypad, push button, exit wand, photo beam, loop detector, telephone entry system, etc.
By disconnecting these devices and reconnecting them back to the system one at a time, we can use a process of elimination to determine which device is causing the problem.
If you still need assistance, please call our tech support from the gate so we can help you troubleshoot. You can contact us at 800-543-1236 Monday - Friday from 8:00 AM to 6:50 PM EST
Technical Support
GTO Access Systems, LLC
Jun 29, 2014 | GTO Mighty Mule Automatic Gate Opener For...
Is the GTO-Mighty Mule gate opener compaticle with 2012 Chevrolet Silverado Universal homelink?
Its kinda hard but if you follow the info in the owners manual for your truck it works. It is not rolling code like a gargae door this is a dip switch on or off .
Jun 07, 2012 | GTO Mighty Mule Automatic Gate Opener For...
Mighty Mule 500 motor repair
Try Mouser.com part # P6KE16CA 36 cents a piece.
Jan 12, 2012 | GTO Mighty Mule Automatic Gate Opener For...
Mighty mule gate opener motor burned up after 2 years
Did you ever find a motor to fix the gate opener? I am looking for the same motor and would appreciate any help you can offer
Mar 27, 2010 | GTO Mighty Mule Automatic Gate Opener For...
Does anyone repair pc boards for the Mighty mule gate openers?
Hello, im sorry to hear that you are having trouble with your gate opener. but it depends, on if your opener is still under warrenty and how the board got damaged, GTO "which is the manufacturer of mighty mule" is very picky about returning goods, so you MIGHT be able to get it replaced, but just getting it repaired is out of the question because of the components being heat sensitive and having software in the board, if you have more questions please email me a jasonruis123@yahoo.com
Dec 17, 2009 | Gates Deer Fence: Mighty Mule Driveway...
I have a mighty mule gate opener model number 352 and the cycles only open and close two inches. How can I have it properly open
Check the STALL FORCE setting on BOTH openers, check for gate obstructions broken gate hardware. OR your limit settings have been erased, but if none are the problem that you have a broken REV COUNTER which is inside the arm
Oct 18, 2009 | Gates Deer Fence: Mighty Mule Driveway...
Schematic for mighty mule 502, lighting hit gate opener and now it does not work have replaced parts of foil runs and blown capaitor
Sep 29, 2009 | Gates Deer Fence: Mighty Mule Driveway...
Building Materials Logo
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
