Question about Toro Garden
I have a toro 900 trimmer weeder #51225 and i need to put a new string on, what can i do
StickyBeets
SOURCE: put string on tb425cs troy bilt trimmer
there are two ways to install the string..the cool way is without pulling the inner reel off the trimmer..just leave it in place..cut (2) approx.two arms length (thats spreading your arms out like airplane wings) of .095 string..now, align the arrow of the inner reel (it turns counter clock-wise..the arrow points outward) with the arrow on the outer spool (pointing inward)..holding the spool and reel together so the inner reel doesnt move, push one of the cut strings through the eyehole in the side of the outer spool, and it should come up to the right, through a slot next to a small round hole the diameter of the string..if it doesnt, it just missed the exit (as i call it)..pull out and try again..let about an inch come thru..now take that end of the string and push the line into the little round hole until it stops, which should be about a little more than 1/8 of an inch..hold it in while pulling the excess line outside the spool to keep it in place..now do the same with the other string for the other side..once you have both lines in place, turn the inner reel counter clock-wise to draw in both lines through the eyeholes of the outer spool..you may or may not get all of the line to wind in..not a problem..you will still have enough to do what you need to do..just cut off the rest..one problem you may or may not have that i do most of the tyme is that it gets hard to turn the inner reel..one solution is to bump the top of the 'bump knob' with your fist, then pull both strings at the same tyme, then continue to turn..this method is quicker and easier than the second way of having the inner reel out and trying to wind both lines at the same tyme and trying to place the reel back in the spool..hope this works for you...
Posted on May 19, 2009
  • 18 Answers
SOURCE: NEED TO REPLACE STRING ON TORO 15" ELECTRIC TRIMMER
http://216.213.143.2/ProAuthor/ManProc.cfm?&sk=9C8C458D-4977-11DE-9261-00D0B789305D&&ProcID=9812&ManualID=301&ProductID=-1&Edit=No&Skill=1&Lang=-1
Posted on May 27, 2009
  • 163 Answers
SOURCE: problems opening the weeder to replace the string
may have left handed treads on it
Posted on Jul 26, 2009
SOURCE: Need info on putting line on troy bilt 4-cycle
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Posted on Apr 05, 2010
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Posted on Apr 25, 2010
How do I find replacement string for a lawn trimmer?
home depot has trimmer string. as well as most hardwares.
Jul 26, 2014 | Toro Lawn Mower With Toro Power Tools
I can't get the spool off of my Toro 12 inch trimmer model 51325. I have tried all the suggestions on the web site and it won't come off, however it came off my itself earlier when it ran out of string...
You are doing well. The Toro site states that this is a model from 1985. User manuals were much more concise back then and so I will have you view yours. Click on the link on the left that states:
Toroe Electric Trimmer/Service Manual (English). I have viewed it and spool removal instructions with pictures are there.
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#manualsResultPage
Oct 24, 2010 | Toro Electric Trimmer
I dont know what string to use in my toro 8" battery trimmer
The thinner string works well in these machines and puts a lot less strain on them. I would suggest using a string of .065 range. The thicker (and more expensive) string used in the gas machines is too heavy for these lower powered electric units.
Sep 25, 2010 | Toro& Electric String Trimmer
Trying to replace the head of the weeder with a new line system,
I cannot get the head of my craftsman 791050 head off to replace with a new line system
Aug 01, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Cannot undo the string compartment to put new string in. There may still be string in the compartment but I cannot get into it. This is a 12 inch Toro electric wacker.
There sould be a knob that turns counterclockwise to take spool off. If not there sould be two taps that push in and pull down on what they call the spool head. Hopefully this will help you.
May 14, 2009 | Toro& Electric String Trimmer
String breaking
Check to ensure that the string is the correct size as specified in the owners manual. If ok check age of the string. If old it has a tendancy to be brittle. If new and supple try letting the trimmer get up to full speed and let the tip of the string do the cutting. Avoid taking on too much at once with this trimmer as the electric and battery trimmers are not as powerful as their gas counterparts. I hope this helps.
Sep 11, 2008 | Toro& Electric String Trimmer
Garden Logo
29 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
