Question about Home
I would like to remove the sprayplate for cleaning on my Mira Fixed head Eco BIR shower head. The reason for this is that the power shower is pulsating on and off.
  • 2712 Answers
SOURCE: How to Remove Shower Head
Once you've purchased your new shower head the first step in replacing the head is to make sure your shower faucets are firmly turned off and then remove the old shower head. If you look at the existing shower head, you'll notice flat spots on what's called a pipe nipple at the base of the shower head where the head screws into the goose-neck pipe that sticks out of the wall. * Take an adjustable wrench and tighten the wrench onto the base of the shower head flat spots. * Turning counter-clockwise, loosen and remove the old shower head. * Clean the threads on the goose-neck of any debris such as old pipe compound or Teflon tape.
Posted on Aug 27, 2008
  • 34 Answers
SOURCE: shower goes cold after 5 mins
Sounds like you have got some elements out in the unit or you need to turn the heat up.
Posted on Feb 05, 2009
  • 34 Answers
SOURCE: does not stay hot long goes cold after 5 mins in my mira shower
This sounds like the elements or you just may need to turn the heat up. If it under two years old call the manu on the warranty. They make a good product so they should help you. I would check the heat setting first, though I doubt it is going to be the prob.
dennymulford
  • 1055 Answers
SOURCE: mira thermastatic shower problem,pressure&temprature.
you mixing valve may be going bad,do you have hard water? you may just need too take it apart and clean it
Posted on Mar 07, 2009
  • 659 Answers
SOURCE: Need assembly diagram for original Waterpik Shower
You just need to figure out which one you have and the manual should be on this site. If its not then give them a call.
http://www.waterpik.com/customer-service/instruction-manuals.html
Posted on Apr 03, 2009
What are the advantages of fixed showerheads ?
Everyone knows that a relaxing can fill out a whole day stress. A comfortable and soothing shower depends on the shower head or shower system .
To ensure a relaxing shower, you need choose wisely. Most of the American have seen a tend to take more showers than bath, when a bath usually for relaxation purposes. Where in America most people hot water tanks that hold about 40 gallons of water. Here people are more concerned about consuming less water.
Here in United States, it's usually most common to do one or the other, simply to get clean rather than soak in the bathtubs.
That's for why I found Static or Fixed shower head is mostly used at here. A suitable fixed shower head is critical to the safe performance of your shower .
Lets have look on the advantages of
Static or fixed shower heads:
  • Adequate pressure and less water consumption
  • Two jet and water spray settings
  • Extremely affordable price
  • Easy to install
  • UNRESTRICTED WATER FLOW
As we know there is a difference in bathroom size is also can be a reason that people are more likely go for shower. There is a issue about time which is also another reason.
The Ultimate Toilets Parts Reviews For 2018 Toilets Reviews Ratings
Apr 08, 2018 | Home
My mira elite 2 shower is leaking,The flow and tempt is ok. but the leak has got worse and it is cold water the leak is not from the hose that is connected to the shower head. It only leak when its on
Please use plumbers white tape wrapped in a clockwise diection. Tighten and let us know Geraldine. Thank you and send us a picture if you can. Best of luck leave feedback
Jul 13, 2016 | Home
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
Mira shower manuals
If you have water with head removed, Remove and soak shower head overnight in vinegar to remove hard water deposits.
Jun 09, 2014 | Home
I have a Mira Vie electric shower, the pull cord no longer lights up, and therefore my shower won't run. I've checked the fuse box and nothing is labelled, it's an old style fuse box. Ther
Buy a current tester( under a tender) and test if supply is going to pull cord (remove the 2screws on cover of pull cord. )Ifyou have power then it's you pull cord that needs replaced if not its mains fuse
Sep 26, 2012 | Home
My mira sport shower when switched on runs afew seconds and stops, then when switched off runs afew seconds then goes off. pls can someone advise. thank you
detach the hose from the shower head and clean the filter screen and do the same with the shower head. When you have the shower head detached turn the water on to the shower and see if anything comes out into a towel or bucket.
Feb 15, 2011 | American Standard 1660.501 Sport Hand...
My mira sport shower is only 2 years old just over and is leaking from the shower head I have taken the head off, is it the washer or do I need a new shower head? Sorry I am unable to give you the brand....
firstly clean all the shower holes with a needle tip. you can also apply some descaler on the shower. Cut an old cycle tube piece round to the size of shower head. Make a hole in the centre of the cutted piece.Apply some grease on the patch & place it between the shower & head. Tight it up.If there is not enough space for rubber just apply grease on the head & tight it.
Aug 13, 2010 | Home
Every time we use the shower there is a very pugnent smell [fishy] all drains been checked, all pluming been checked, all water is fine. shower is 11 years old could this be the problem. the shower we have...
Also check the following things:
The control unit, hose and shower head - depending on the type, some heads will hold water. Remove them and check to see if they are exhibiting signs of mold or possible failure. At 11 years old, the element could be on its way out. If your Mira unit has an auxiliary pump, it should be checked as well. If it's the shower head, you can try to soak it in white vinegar to remove the smell, or simply replace it. If you have well water, you should consider flushing the system to be sure water isn't being trapped somewhere. Also, if the iron content of the water is high, or if your water softener isn't operating properly, that could be an issue as well. The Mira control unit may need to be de-scaled or otherwise checked.
Check the shower stall walls (with no tub) at the bottom where they meet the basin, unless the shower enclosure is all one piece. There could be mold behind the intersection of the walls and base.
Look for any trace of mold growth around any other enclosure components.
If the shower is in a tub, remove the overflow cover on the tub and see if there is any trace of mildew or mold in that area. Follow your nose.
Finally, check for any excessive build up of soap scum, although this is less likely because you'd notice it more readily.
Things like this can be tough to diagnose, so just take things slow and one at a time.
Mar 08, 2010 | Home
My mira sport electric shower keeps overheating and no longer provides hot water. What shall i do? Please help...
Sounds like the heater tank is failing. Try ringing Mira Customer Service on 0844 571 5000 who have Engineers who can repair your shower at a competative fixed price
Jan 16, 2010 | Kitchen Appliances - Others
Mira thermastatic shower problem,pressure&temprature.
Mar 06, 2009 | Plumbing
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
