Question about Dehumidifiers
I have a crazo mini dehumidifier and the blue light that indicates that it is working does not light up. The dehumidifier still turns on, just the light does not work.
I am afraid that once the tank is full the red light that indicates that it needs to be emptied will not work. I associate the blue light as reassurance that the dehumidifier is working properly.
  • 10865 Answers
SOURCE: Haier dehumidifier will turn on but does not collect water.
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Posted on Apr 14, 2010
heatman101
  • 43501 Answers
SOURCE: Maytag Dehumidifier will not run. Indicator light says "full"
Here is a tip that I wrote to help people with just that dehumidifier2_bing.gif problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Posted on May 04, 2010
  • 420 Answers
SOURCE: 'bucket full' light on, but bucket empty
There is likely a switch operated by a float to turn that light on and turn off the compressor, sometimes manufactures use a rubber "O" ring on the float shaft and they can slip. take the cover off the pump and check the float or in some cases one of two floats are used. Once float turns the pump on and off and the second float shuts OFF the compressor and turns ON the full reservior light.
Posted on Jun 04, 2010
gemyr2
  • 63 Answers
SOURCE: My new LG "ld450eal" DeHumidifier
The switch that says 'Bucket is full' is not adjusted properly.
It will need to be adjusted, normally a screw driver or pliers,
so that when its empty the switch is not made or the contacts
are open.
If it is in adjustment properly, then the switch is bad and needs
replacing.
Before you replace it, check to make sure the wires leading to it
are not touching, it may be sending a signal meaning 'full' by
electricaly touching each other at the switch.
Posted on Feb 25, 2011
heatman101
  • 43501 Answers
SOURCE: I turn on the dehumidifier and the red indicator
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
Posted on Mar 30, 2011
Dehumidifier stopped working because "water bucket full" indicator light stays on, although there is no water in bucket.
In the water bucket is a float assm. scale forms on the assm. and causes it to stick. Remove the float assm. and carefully remove the scale. Should start working again once done. If not you may have to replace it.
Mar 11, 2013 | Dehumidifiers
I bought a model 365 remington dehumidifier. I plugged it in and nothing lights up. I have it plugged in for the past 8 to 10m hous and still nothing. Should i be seeing the blue light up ?
Two things that you need to check: Make sure that the outlet the dehumidifier is plugged int, is in fact working. The circuit breaker for that outlet may be tripped or there may be a loose or damaged wire connection to the one of the outlet's terminals. I assume you are turning the Master ON/OFF Switch to ON of the dehumidifier, after you plugged the unit in and set the humidity extraction level below 40%?
Jun 27, 2011 | Remington Model 365 Dehumidifier
E1 display humidied is at 98% flashing blue light
That's indicating the the humidity level you have it set on is, set to high to remove humidity in the air. Turn the unit OFF and unplug it from the wall. Remove the water collection bucket and empty is if there's any water in it. Wait 10 minutes and remove the air intake filter and clean it, if necessary. Then, plug the unit back in and turn the Master ON/OFF Switch to ON. Lower the humidity extraction level to 32 - 35%. The unit should start up and operate as it should.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Danby DDR583R Dehumidifier
Not sure if I should charge the Remington 365 Mini dehumidifier before I use it for the first time.
If the little indicator ball is Blue at present, it doesn't need to be charged. Only charge it once the ball changes to Pink.
Hope this helped you.
Apr 20, 2011 | Remington Model 365 Dehumidifier
heatman101
May 02, 2010 | Maytag M7DH45B2A Dehumidifier
Apr 14, 2010 | Haier HD656E Dehumidifier
FULL LIGHT FLASHES
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Apr 24, 2009 | Fedders A7DH45B2A Dehumidifier
GHD30 dehumidifier completely dead
If any machine is completely electrically dead it is a sign that there is no electrical voltage getting through to operate it. Using an electric meter it is a relatively easy task to find the point of differential voltages which would indicate where the open circuit is located. The blue green fluid found is from copper oxide and is not necessarily indicative of a refrigerant leak. Oil present would be an indicator of a refrigerant leak.
Nov 01, 2008 | Goldstar DH504EL Dehumidifier
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
