Question about Brother Office Equipment & Supplies
Brother printer DCP-J140W Error in Print unable 48
Mix-it-up
  • 832 Answers
SOURCE: Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
Posted on Mar 29, 2008
  • 60 Answers
SOURCE: machine error 48 or init unable 48
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you open the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
Posted on Feb 03, 2010
  • 525 Answers
SOURCE: clean unable 46 error on dcp 135c brother printer
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Jan 23, 2011
raajeeen
SOURCE: brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Posted on Mar 05, 2012
SOURCE: brother dcp j125 unable to print 50 error
why dcp j125 paper jam
Posted on Apr 22, 2013
I have a problem with "brother DCP-J140W" printer, it shown at the LCD "Init unable 4F" i was thinking the problem must be the printer head, can it be repaired or just replace the head ?
Hi
Error 4F means your printhead is RIP, mostly due to bad quality ink, the only one way to fx the printer is changing the printhead but... is that really worth it?
Well, check on ebay.com or isscx.com if you can find your part at a good price!
Best Regards
Jul 22, 2016 | Brother Dcp J140w - Multifunct
How to fix brother dcp J140 message unable to init 4f?
Error 4f means that your carete is damaged, probable after using not oryginal cartridges, it's reportable but to expensive. If you used brother ink, you can do an complaint I in brother service point.
Feb 16, 2015 | Brother DCP-J140W
How to solve the problem of see troubleshooting and routine maintence chapter in users guide in .it unable 4f in dcp-j140w wifi brother printer
A print unable message in a Brother inkjet usually means the waste ink chamber is full. This can be fixed by removing the waste bottle, cleaning and drying the pads inside, then reassembling the machine and resetting the purge counter. Most of the instructions for this can be found on u-tube. Please note it is a messy job and many folk just replace the machine.
Dec 03, 2014 | Brother DCP-J140W
My brother DCP-J140W printer ink box full .. please help how to fix it.
The Brother manual says that you are required to replace the ink absorber box at a Brother Service Center. This is not an item covered by warranty.
http://www.manualslib.com/manual/437931/Brother-Dcp-J140w.html?page=44
Sep 09, 2014 | Brother DCP-J140w Wireless Compact Inkjet...
I have a problem of my printer, it shown in the lcd "Init unable 4F" for brother DCP-J140W printer, what it means?
Sorry... Print head damaged. There is an very low possibility to erase the error without buying new print head, but it's unprofitable
Mar 12, 2014 | Brother DCP-J140w Wireless Compact Inkjet...
ERROR 48 ON BROTHER DCP 140W
Print head is damaged. Needs repair or replacement.
Oct 16, 2013 | Brother DCP-J140w Wireless Compact Inkjet...
Print unable 48
unable to print 48 in brother dcp-j125
Jul 22, 2010 | Brother DCP 165C Compact Color Inkjet...
107 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
