No water coming in. automatically switches to delicate cycle
3 Suggested Answers
  • 215 Answers
SOURCE: whirlpool 4213632 wont drain water on perm press or delicate
check manual as this seems to be correct, Often called rinse hold or crease gaurd on many other machines
Posted on Feb 11, 2010
markfreedman
  • 312 Answers
SOURCE: Fills with Water and does
Hi, I don't have the best news for your here. This type of problem is caused by the timer, i.e. main control that you use to select cycles starting to fail. If I am correct, when you put the machine into a normal cycle, the knob rotates, but the machine is silent. Just sits there.
the older Maytags are a cut above many other machines on the market.
If you install the timer yourself, you will probably pay about $100.00 for the part.
If you supply me with the model number and serial number, I can give your some instruction on how to do it. They will be located on a placard probably on the top rear of the machine. If my memory serves me correctly
It is not a difficult job. does not require any expensive tools to do.
Hope this helps,
Have a Happy New Year,
Mark
Posted on Dec 31, 2010
My washer recently hasn't drained all of the water during the spin cycle.
how is the spin in the delicate cycle compared to the reg cycle?
Apr 11, 2015 | Washing Machines
Delicate cycle fills with water but will not agitate
Timer needs cleaning on the delicate relays (points) in the delicate position. Maybe timer failure. Transmission stuck, jammed or failing in that wash mode
Sep 21, 2012 | Estate Washing Machines
Washing machine will not start the wash cycle after filling with water. I have tried normal, delicate, and heavy duty cycles.
Not sure what model you are referring to, but in general, it sounds like a problem with the timer switch or if it's all electronic, then it will be in the control board.
If I had the model number I could be of more assistance.
May 27, 2011 | Kenmore Washing Machines
Lint on the clothes. The machine has an automatic lint filter. How do I get rid of this problem?
automatic lint filter means it goes out the drain when the water drain, nice how they make that sound all fancy huh. make sure there is more water than clothes and whatever your washing is not delicate you have to wash delicates with the delicate cycle
Jul 28, 2010 | Westinghouse Washing Machines
The automatic delicate drying cycle does not dry
The delicate cycle is for damp, not wet delicate items. It is more warm air then hot and will not dry wet items forsay. If you have delicate items that need more drying try putting them inside a pillow case and tying the end closed long with a higher setting. Works great with stuffed toys too
Feb 24, 2010 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
Wash cycle won't start after the tub fills up with water.
There's no delicate or regular spin or agitation If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
May 07, 2009 | Washing Machines
I have a maytag washer-n-dryer(stacked). When the washing machine is filling in the wash cycle of the delicate or the permanent press cycles, it will not stop filler the drum with water. The washing...
it sounds like your water inlet valve is bad,change it,also try your washer on another water level like small load or med load and see if it cuts off,it might also be your water level switch,hope this helps,thanks-mike
Jun 02, 2008 | Maytag Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
