Question about Lands Phones
How to make a space between names on handset - Lands Phones
Tip
Gprs & Mms setting for Pakistan mobile networks
Hi friend i saw that many people have problem about there mms and internet settings.so i try to colect the settings of mms and internet of some networks which are usearound the world. i arrange them by the country name so select your country and get your mms andinternet settings
1.> PAKISTAN >UFONE You can get MMS & GPRS settings for your handset by; Sending your phone's model number in an SMS to 222 Example: P910i or 6600 or razr v3 Or by calling/visiting our Customer Services Centers. To call from your Ufone connection simply dial 333. To call from a PTCL landline, dial 111-333-100.
>MOBILINK Activate your GPRS & MMs connection now by calling 111
>Telenor VIA sms Send a text message to 131 with your handset make and model to receive your handset settings:
For Example:
For Internet Write "Internet" and SMS it to 131.
For WAP Write "wap" and SMS it to 131. For MMS Write "mms" and SMS it to 131.
For All handset setting Write "All" and SMS it to 131.
. MANUAL
You can also configure your handset for GPRS & MMS manually: 1. Configuration for WAP Access Point Name/Node wap
Login name Telenor Password Telenor WAP Gateway IP 172.18.19.11 Port (if required) 9201 Port (if required for HTTP handsets) 8080
2. Configuration for MMS Access Point Name/Node mms Login name Telenor Password Telenor WAP Gateway IP 172.18.19.11 Port (if required) 9201 Port (if required for HTTP handsets) 8080 Relay Server/ Messaging Server http://mmstelenor or http://172.18.15.1
.VIA CALL You can also dial 345 from your Telenor Mobile subscription and our staff will help you configure your handset for GPRS settings.
>WARID
please call Warid helpline 321 or visit out Business Centers to avail this service.
>ZONG To activate MMS send the following command; MMS <space> handset <space> model & sms to 131
on Jan 11, 2011 | Cell Phones
I have a BT 6500 with three handsets. How do I transfer a contact Name & Number to another handset
The name and number is stored in the base station and is available in all handsets.
Dec 18, 2014 | BT Lands Phones
Changing the first letter of a proper name from small cap to large cap? I have a Uniden Dect 6.0.
When entering a name in the phone book, after a blank space the first letter is always a capital one. Subsequent ones are small letters.
Jan 04, 2010 | Uniden DECT 6.0 Cordless Telephone...
How to change Handset number on ntl vs2000 digital phone
Naming your Handset:
Press Menu and Scroll down to Handset and Press OK
Scroll up or down to Label Press OK
To delete the existing handset name press the Clear button repeatedly.
Enter new name then press OK - confirmation tone
To exit, press and hold Clear button.
The display is disappearing on my phones - does this mean they are terminally ill?
Jul 19, 2009 | Lands Phones
How to make caller names show when contacts are in with name and number
Make sure your contacts are saved to the handset not the sim
this is because nokia handset only read the name and number from the handset when you get a call
so copy your contacts to the handset and this should work
Any Problems Contact Me On mjsnowdon007@live.co.uk
Michael (Mobile Phone Engineer)
Universal Mobiles Coventr LTD
May 28, 2009 | Nokia 6210 Navigator Cell Phone
NEC Dterm 80 display
It took me forever to find out, but heres what you do.
with the phone hung up:
1) "Feature" then press "1"
2) then press "#", "*", "#"
3) lift the phone, then hang up
4) press "Speaker"
5) dial "700"
6) press "hold"
7) enter the name (I'm still trying to find out how to leave a space, or use aother character that the same number key has... ugh"
8) press "hold" then "Speaker"
then make sure it saves it in the directory
Jul 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
VT2461 ADDITIONAL HANDSET PROBLEM
I can vouch for the second solution. It worked perfectly on my 2461 with two extensions. Even the vTech website was not able to provide a solution.
Dec 12, 2007 | Vtech VT 2461 Cordless Phone
Storing #s in memory
Try this. Memory The handset can store up to ten 24-digit numbers with up to 15-character names in memory for quick dialing. This memory feature is in addition to the CID memory log, which stores up to 40 CID records in the handset. Storing a Name and Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the mem button. 3. Press the desired memory location (0 through 9) or use Caller ID/vol (+ or to scroll to the desired memory location. NOTE: If the memory location is occupied, the memory location number and its contents show in the display. 4. Press the mem button again. The display shows ENTER NAME. NOTE: If you don?t want to enter the name, skip step 5. 5. Use the touch-tone pad on the handset to enter the name (up to 15 characters) and press the mem button to save. More than one letter is stored in each of the number keys. For example, to enter the name Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Wait for one second. Press the 5 key 3 times for the second letter L. Press the 1 key to insert a space between the L and the S. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H. 6. Press the mem button to save the name. The display shows ENTER TEL NUMBR. 7. Use the touch-tone pad to enter the telephone number you want to store (up to 24 digits). 8. Press mem again to store the number. You will hear a confirmation tone. NOTE: If you make a mistake press the del/chan button to backspace and erase the wrong character(s) or number(s). If there are any further questions or comments, please post here. Please rate this solution through fix-ya.com Thank you
Jun 18, 2007 | GE 25836 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
