Question about Miele Washing Machines
I have a Miele WT 2780 washer dryer. I've just cracked the front plastic door glass on the outside of the door. Does anyone know which replacement part I need?
2 Suggested Answers
  • 64 Answers
SOURCE: miele -washer dryer-WT 2780 fault code 3
Hi. Is your filter clean?
Posted on Apr 27, 2017
Testimonial: "a filter is clean , I clean it. but the default code error 3 is there on dryer programm only"
Why is water not heating
Most washers require both hot and cold supply
Jan 06, 2017 | Miele Washing Machines
Miele washer does not power on at all
check the door switch or the mains fuse. they are both on the inside.
Feb 15, 2016 | Miele WT 2780 Front Load Washer
How do I get at the Motor on a WT 2780 Washing machine?
The most important thing you miss, is you should first diagnose what is defect. When 100% certain there is no cause for the defect other and died because of the usage and it is replaceable, you first should buy the spare part and then start the replacement. Without a manual I would not even start opening it. And when the motor costs more then half a new washing machine I would not even order one or replace one.
Please be careful when opening the machine. One mistake can cost your fingers or it even can cost a life.
Feb 09, 2015 | Miele WT 2780 Front Load Washer
Why is my Miele WT945 front lader washer dryer not taking water in properly or at all?
you may try cleaning the inlet screen by removing the fill hose.then pry the ccreen out with a small screwdriver.
May 05, 2014 | Miele WT945 Front Load Washer / Dryer
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
Could you please describe the problem you are having a little better?
Oct 20, 2012 | Miele WT 2780 Front Load Washer
'Close the Door' on Miele WT 2670
Door lock faulty or wires to lock adrift.
Mar 06, 2010 | Miele WT945 Front Load Washer / Dryer
Miele WT 945 Washer Dryer - Spin not working + Water Inlet/Drain Light Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Your filter of the water inlet valve is accessible outside the machine; it is at the water entry point. Close your faucet & check this out; this gets clogged often.
Hope i am helpful...... Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 24, 2008 | Miele WT945 Front Load Washer / Dryer
Washing Machines Logo
73 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
