Question about Radio Communications
My sylvania blue tooth speaker sp332 will not connect to my iPad (it has before). The blue on light just flashes.
2 Suggested Answers
  • 2045 Answers
SOURCE: Cannot establish blue tooth connection to ipad
try to turn on BT on iPad while Logitech is blinking (which means it in pairing mode and can be discovered). If that doesn't help I'd suggest to remove batteries from Logitech for 3-5 minutes then put them back.
Posted on Feb 09, 2015
Feb 08, 2015 | Logitech Ultrathin Keyboard Cover
Can I hook a blue Tooth speaker to my model #ld320ss8
I do not believe your model of TV has bluetooth support.
You will have to connect it with an auxiliary cable, or use other speakers with the appropriate cable.
You can use wireless speakers, but they would come with a receive that would have to be connect to the TV with a cable.
Dec 17, 2014 | Sylvania Televison & Video
How do I pair my I Pad with my new Philips portable speaker using bluetooth ( can connect fine using a cable)
If your portable speaker is Bluetooth-enabled, here is the general procedure:
1. Press and hold the function control button on the speaker until you see red and blue lights flashing in rapid succession on the speaker (the speaker is now in "pairing" mode).
2. Turn on Bluetooth on your iPad and then tap on Scan. iPad will begin scanning for nearby Bluetooth devices. When you see a name similar to that of your speaker, tap on it . You will be asked for a passcode/passkey to pair the iPad with the speaker. Enter '0000' or '1234' (without the quotes).
3. Once the passkey is accepted, the two devices are now paired. The light on the speaker should become a steady blue.
4. On the iPad, tap on Connect. If the iPad connects to the speaker, you will see Connected. You are done. Play some music from the iPad to see if you can hear it coming through the speaker.
You should have this procedure detailed in the set up guide that came with the speaker. Please note that pairing is required only for the first time you try to connect the two devices, to get them "acquainted" to each other. After that, all you need is to connect the iPad to the speaker every time you want to listen to your iPad through the speaker.
Nov 30, 2014 | Philips Audio Players & Recorders
Can I connect to Vizio TV with blue tooth
If your ear buds have been connected to any device before your TV then it won't work. If you want to connect it to your TV you turn on your headphones, hold the call button for 3 seconds, and you will see ur light flash and connect it to your TV. If this didn't help then go to the manual and check how to connect your headphones to your TV.
May 24, 2014 | AUVIO Bluetooth Headphones
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Jan 14, 2013 | Harman Kardon JBL Flip black
I am having problems connecting my plantronics explorer 390 to my black berry curve
First turn your Blue Tooth setting to "ON" on your Black Berry Curve, as it searches for a Blue Tooth Device, Push and hold on the middle button of the Blue Tooth until you see a flashing "blue light & red light." It's important that you see both flashing lights.
May 19, 2010 | Plantronics Explorer 390 Bluetooth Headset
No sound from speakers, loose connection in green jack wire.
Yeah man I have the same problem!
I guess I will just buy a new jack!
May 27, 2009 | Logitech Z-640 5.1 6-Piece Home Theater...
Wireless speakers not communicating to Receiver
Speakers have a unique RF frequency that needs to pair with the receiver (kind of like a blue tooth headset with a cell phone). At times, the signal may reset, so, you may have to go through the initial pairing sequence. Try this:
1. Unplug rear speakers
2. Make sure the sound signal connector is plugged in to the back of the system properly.
3. Press and hold the ID button for 3 seconds until the blue LED light flickers.
4. Connect the power chord to the rear speakers.
May 03, 2009 | NexxTech DP3222 DVD Player
Radio Communications Logo
221 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
