Question about Tivo Televison & Video
TIVO canot get on line stop 63% - Tivo Televison & Video
I have an AKAI PDP4273M monitor and DirecTV R10 DVR( TIVO). I canot control on off and volume of the TV with my TIVO remote. The codes listed in the DVR do not work. I have the same problem with a...
best bet for this is logitech unv harmony remote more way more compatbilty with all units u have even the lights it dims and glows in dark so u can see on sale now at best buy
Jan 18, 2008 | Televison & Video
How do i get my tivo 652-160to stop recording tivo suggestions?
Go to: TiVo Central>>Messages & Settings>>Recording>>TiVo Suggestions, and press 'Select' "Do Not Record TiVo Suggestions"
Jan 18, 2016 | Tivo Televison & Video
Can I record VHS tapes to my TiVo model TCD649080?
Sure, just plug the output of the VCR into the input on Tivo. Set the Tivo to Channel 0 or 1, hit play on the VCR and then Record button on Tivo. Stop recording when the tape (or portion of) is finished.
Mar 04, 2011 | Tivo Series2 TCD649080 Video Recorder
I have a problem with tivo it says my gateway canot be found is this a router problem or a setting.its happened getting 87 % signal strenth
I would check the router to see if something has changed.
Sometimes you need to re-add the wireless password to the Tivo Setup.
Jan 05, 2010 | Tivo Series2 Digital Video Recorder...
I do not have a phone line to do guided setup. I would like to use a wireless adapter with my home network router but have been unable to buy a compatible one from the list locally. Is the list...
You can do the guided setup without a phone line up to the point where it attempts to connect to the network using the wireless adapter. If it successfully connects, then you can continue the guided setup. If it does not successfully connect, then you're stuck until you can. In other words, you don't need the phone line as long as you have a wireless adapter and that adapter can successfully connect to your network and the internet.
I believe that, with the exception of some dicey hacks, you're stuck using the Tivo wireless adapter. The Tivo Community Forum website is a good place to ask questions like this. The site is independent of Tivo, inc. and has a lot of great information.
Hope this helps.
Oct 05, 2009 | Toshiba RS-TX60 DVD Recorder
When my Tivo stops recording a show on, say, channel 54, instead of staying on channel 54 it switches to channel 5. In other words, it only gets ''part'' pf the channel number. This happens with other...
The end of the IR Cable that attaches to your cable box may have to be repositioned.
Try moving it a small distance (you are already close or you wouln't be receiving ANY channel changing info. from it) and see if that helps.
Sep 12, 2009 | Tivo Series2 TCD649080 Video Recorder
Tivo & cable
Have you gone through the automated set-up again, to let the Tivo detect what channels you have and don't have?
I had a similar issue a few years back when Comcast changed our line up, and that solved it for me.
Jul 12, 2008 | Tivo Series2 TCD649080 Video Recorder
Tivo box
If you have call waiting or another service, make sure you have any codes you need in the dialing prefix. if you have dsl, make sure you have a phone filter on the line coming from the tivo.
Has your phoneline w/ the tivo ever worked? or is this just new?
You can try another phonejack in the house. You can also try a different dialing #. Sometimes they take them down.
If you have a broadband connection, you can use a usb to ethernet adapter and dial in over your network. It's quicker and doesn't tie up your phoneline.
Nov 25, 2007 | Tivo Series2 TCD649180 DTV Receiver /...
Televison & Video Logo
27 people viewed this question
Top Tivo Televison & Video Experts
Computer Repairing
Computer Repairing
Level 1 Expert
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
