I just bought a used cabrio and it doesn't seem to be working correctly. it fills with alittle water then stops. How does this thing work?
  • 641 Answers
SOURCE: DISHWASHER WONT FILL WITH WATER
I don't think that the problem is relates to the leaking water. Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Posted on Sep 10, 2007
SOURCE: My washer will not stop filling with water and overflows
Turn the washer on and let the water run, while the water is running unplug the power cord if the water stops the inlet valve is ok but if still running the valve is bad and need to be replace if the pump is good you need to test the water level switch, if faulty need to replace.
good luck
Posted on Apr 04, 2009
  • 6 Answers
SOURCE: washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
Posted on Dec 15, 2009
  • 129 Answers
SOURCE: Whirlpool Cabrio stopped working mid cycle and
CLEAN WATER PUMP
Posted on Jan 31, 2010
  • 949 Answers
SOURCE: washer fills up with water then stops working
You may have a voltage supply problem, the water valves on the washer take very little power to fill the machine but the motor that washes and spins takes a lot of power. If there is a poor electrical connection in the circuit or you are on an extension cord that is too long or too small this will happen for sure.
Posted on Apr 20, 2010
Whirpool awm5100 machine not getting rid of washine powder in despenser only filling water alittle then stopping cycle
The most likely fault is the water inlet valves are blocked or only partially opening , pull off the pipe coming from the inlet valves and put the machine into cycle the flow of water should be full of the pipe and at mains water pressure, if this is not the case replace the inlet valves. Thanks tk
Mar 10, 2014 | Whirlpool Washing Machines
Cabrio washer won't fill normally but diagnostic shows valves are fine
when doing the diagnostic testing machine fill up almost full and stop display an ol mode
Apr 17, 2013 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool cabrio stopped working
Tough repair but easy fix. get all the water out you can then lay the washer over and remove the pump motor from down under there. get the sock or whatever is in there out like in my home movie:
Aug 03, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My Cabrio washer won't drain and spin. It says "LD" and consistently stops with 24 minutes left on the cycle. For a while if I would spin the basket a little it would work. Not that...
There could be several things causing this problem. Have any small items gotten caught in the pump or between the basket and tub? You may be using a cycle with a low spin speed. If you need to remove excess water, select the Drain and Spin option. If the load is tightly packed it might cause the problem you're having. Are you using ONLY "HE" detergent? If so, be sure you're using the correct amount. To clean out residue from too much or wrong type of detergent select the "Rinse and Spin" option but do NOT add any detergent.
I hope this information helps. If it does, please rate my suggestion and its effectivness. Thanks!
Jun 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How do you set the Cabrio to wash a small load?
this one only has 1 setting on water level. same size uses same level
Feb 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
