Question about Garden
Every time I engage the blaids on my riding mower it blows a fuse and dies
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Knowing the model help. But run down your wiring harness and make sure you don't have any loose grounds. Check the PTO clutch make sure everything is tight. Also with the mower off check under the deck an ensure nothing is blocking your blade/belts.
Posted on Apr 30, 2017
    An user who is expert in 3 categories / brands.
  • Garden Master
  • 924 Answers
Could be a bad clutch or the diode that is in the harness is bad.
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ... > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from
Dec 29, 2015 | Garden
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
Fuse blows when i engage blades on my bad boy ztr
Is the fuse a 15 if so there could be a short some where.
Oct 02, 2012 | Garden
EXmark mower blows fuse when deck is engaged.
try checking the wires from the switch that engages the mower deck. if there is a wire grounding out sumplace when you kick it on it will keep popping the fuse no matter what. id say its a short.
Mar 16, 2012 | Craftsman Garden
Husquevarna rider mower dies & blows fuse when pto is engaged
you may need to check that your blade engage sensor is working properly, and that the one on the seat is working properly. if not that, then check the ignition fuse connections. they may seem to be connected properly, and still not be seated properly. good luck.
Nov 20, 2011 | Husqvarna Garden
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
2007 Husqvarna Riding mower blade will not engage when switch pulled out. Fuse blows & mower dies! Help!
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Apr 25, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
