Question about Fishing
Zebco micro series A11SF small reel needs the bushing that feeds the line back on the reel when reeling back in
  • Fishing Master
  • 3,498 Answers
SOURCE: akai reel to reel
I have a complete 1730d ss that I never use. Lots of tape too that's been in storage for ages. Make me an offer for the whole works at
Posted on Apr 09, 2008
  • 257 Answers
SOURCE: 9855 ribbon take up reel not working
When you're sending data to the printer you're sending a command that is telling the printer you're NOT using a ribbon. When the printer receives the data it's shutting off the ribbon. Check your software.
You should be set for THERMAL TRANSFER.(RIBBON)
Posted on Apr 15, 2009
SOURCE: Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
Posted on Apr 29, 2009
  • 1285 Answers
SOURCE: reel to reel tape pioneer model RT1011L
Posted on Jul 04, 2009
woobie dog
  • 1273 Answers
SOURCE: string is stuck inside reel and I need to remove
Hi, W/D here.
The string tends to get caught in itself, despite our best winding efforts. Pull the spool straight off, and try to get some fingers on the spools as it comes off, in case one of the spools if free, so the line doesn't fly off.
Usually a kinked piece can just be pulled at an angle to free it up.
Best regards, --W/D--
Posted on Aug 15, 2009
How do I attach the Zebco 202 reel to the rod?
Zebco 202 has a foot projecting from the frame.....this is mated to the reel seat area on your rod and the knurled rings on the rod are tightened down over it to secure it for fishing.
Jul 08, 2016 | Zebco 202 Spincast
String only comes so far when you shoot has enough line no knots or anything seems like its getting caught on something
unreel the line and hold tension on it when reeling back onto spool some lines dig in worse than others .
Sep 07, 2015 | Zebco 808 Bowfishing Spincast Reel 808...
How do I get my zebco to retrieve the line
Your reel has pickup pins on the spool that will guide the line onto the spool when you reel in.
Try holding gentle tension on the slack line just above your reel and start reeling in. If this does not work then remove the top cover of the reel and look to see if the line is tangled up on the inside around the center shaft underneath the pickup pin cover.
if this is the case, simply unscrew the pickup pin cover from the center shaft. It will be on the tight. Remove the tangled line and reassemble.
Sep 18, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
How do I get my reel to keep from letting the line out while I'm holding down the cast button?
Hold the line with your index finger and against the rod itself. Then cast and release your hold
May 12, 2014 | Zebco 11 Authent Micro SpinCasting Reel...
Need to respool a 404
As an avid fisherman myself I know the value of fresh line. Here is a great link that shows the step by step for respooling the 404
please mark my answer as very helpful. thank you. Joe
Apr 05, 2010 | Zebco Omega Spincast Reel
Fishing Logo
187 people viewed this question
Top Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Fishing Expert? Answer questions, earn points and help others
