Question about GE Microwave Ovens
I have a JVM1630WB GE Spacemaker microvwave oven. It turns on with a bit a a buzzing sound, smells like rubber is burning and does not cook the food. What do you think? It is 9 years old. Worked fine yesterday.
  • trp0408 Jul 25, 2009
    Yes, the light, cooling fan and turntable all come on. There is a "different sound to the fan, and it doesn't microwave.
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    microwave, do the inside light, cooling fan, and turntable all
    come on?
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • GE Master
  • 9,047 Answers
It's almost certainly a shorted high voltage rectifier diode or a failed magnetron.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Here are some handy links you or someone you know can use for test help:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I have a JVM1630WB GE Spacemaker microvwave oven. - d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If it's within the magnetron portion of the warranty (for this model it's 10 years from the date on the tag inside the unit) but out of the original full warranty (1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
G.E. they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on Jul 26, 2009
Buzzing noise and burned smell
Faulty diode pack and possibly magnetron.
Mar 27, 2014 | GE JVM1631 Microwave Oven
Have ge profile spacesaver xl sensor. will not heat strange buzzing sound and burning smell. clock, light, vent still work
This is most likely a defective magnetron, especially with the burning smell. There are two other parts that can be a problem, the high voltage capacitor and diode, all three work together to heat food. If the magnetron is the culprit, probably cheaper to replace the microwave oven.
Mar 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Have Spacemaker Microwave--JVM1630WB 004. started cooking ,heard a POP!! , and it did not cook the food. smelled like burnt wires or capacitor. No fire. fuse did not blow. Any suggestions ?
I had the same thing happen to my 20 year old Frigidare microwave (it was 8 years old at the time). Same POP!, same failure. Though I'm handy with electrical, I don't mess around with the innards of a microwave. There are lethal doses of electricity stored in some capacitors even when the device is unplugged. I took mine to an appliance repair shop that works on microwaves. In my case, a high-end capacitor had blown. The repair cost me $80.00. $5.00 for the part, $75.00 for the labor. My microwave is still working 12 years later.
My solution is not pleasant. If you call a tech out to your house, his charge for labor and parts will probably be more than the cost of a new microwave. Taking it to a repair shop is cheaper, but you would want an estimate first which in itself will not be free of charge.
New microwaves have come down in price over the years. Countertop models for as little as $100.00. Over the range models starting at about $250.00.
Whatever you decide, this is going to cost you some money. Your microwave is dead. Good luck and hope I've helped a bit.
Jan 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Have a GE "Spacemaker II Sensor" microwave oven. When we try to cook now, it trys but the food does not get hot. Something is getting hot becasue there is a distinctive smell, perhaps like a burnt IC or...
you will need to find the source of the burning. it could be a cheap fix or more involved depending on the component. it could be a transformer, h.v.diode, magnetron, etc. if the diode is shorted, there is a good chance magnetron is defective too.
Aug 31, 2010 | GE Profile Spacemaker II PEM31 Microwave...
Ge jvm1630wb-006 making loud buzzing sound when on-heats ok
If the buzzing sound is present even when you are not cooking, then the problem is almost certainly a failing electrolytic on the control circuit board.
We regularly repair this problem for $39.95 postpaid for folks all around the country.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Aug 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm160wj01 was working and suddenly started buzzing, gave bad electric/burnt smell and buzzes. Still buzzes and does not seem to heat now.
Sounds like the magnetron just shorted out. Its the part the generates the microwaves that heat the food. Buzzing sounds are a symptom of a shorted mag. Usually not worth fixing since the magnetron costs almost as much as a new oven. Sorry.
Jul 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave works perfectly but does not heat
Sadly your microwave has done it's last cooking. The mechanism you need to make it cook again would cost you more than a replacement microwave.
Jul 15, 2009 | GE Countertop Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
964 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
