Question about Samsung Refrigerators
Reset water filter light on a samsung French door refrigerator
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
MNTECH
  • 1543 Answers
SOURCE: Reset Filter Indicator Light is on
Look for your model number from the sticker inside the fresh foods section of the refrigerator, usually on the liner near the door opening. Now, go to http://www.geappliances.com/service_and_support/literature/ to download a use and care manual for your model, as the reset procedure may vary by model. The filter is usually located at the very back right upper side of the fresh foods compartment, but again, it may vary by model.
Posted on Apr 11, 2009
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Posted on Oct 15, 2009
  • 1891 Answers
SOURCE: Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Posted on Dec 24, 2009
shane_mccown
SOURCE: water build up underneath deli tray drawer
Ok. I know why this is happening. Or at least in my case.
The coil for the Fridge is stored behind the center panel when looking directly into the the Fridge.
What happens is the drain for the coil becomes iced up. It then wont drain and when the fridge goes into defrost mode the melted water will run out of the bottom of the center panel. This is difficult to see due to all the shelves in the way. i noticed this because I could see ice through the vent holes in my center panel.
To fix this:
Take all the items out of the fridge.
Take all the shelves out so the center panel is exposed.
Remove the 3 screws at the bottom of the panel and single screw under the cover of the shelf rail. (This one is a little hidden) pop off the plastic cover first.
Now you can pull the panel off.
(Note. This can be a little difficult to get off because you have a ton of ice behind there keeping it stuck to together. Just ease it off as much as possible.
When you get this off you'll most like see alot of ice in the tray that the water is draining into. chip this ice away and then I used Hot water to pour into the drain. I would then use a shop vac to **** the water out and put in more hot water until the ice plug is removed and the water can flow freely to the drain pan under the fridge.
That is it. I own this fridge and I've been tired of having to **** water out of fridge with a shop vac every 2 weeks. So I decided to resolve this myself.
*disclaimer. I'm just a DIYer not a Samsung repair person.
Good Luck and I hope this solves your issue.
Posted on Aug 25, 2012
The alert ding goes constantly and no doors are ajar
How do I use the digital control panel on my Samsung fridge ...
www.samsung.com/uk/support/skp/faq/1023129
Samsung ElectronicsFeb 17, 2015 - Energy Saver Button. For better energy efficiency press the Energy Saver button. If condensation occurs on the doors turn the Energy Saver ...
Support - 4-Door Flex Refrigerator ... - Samsung
www.samsung.com > ... > French Door
Samsung Electronics4-Door French Door Chef Collection Refrigerator. 4-Door ... Will the Water Dispenser on the French Door Refrigerator Work Without a Water Filter Installed?
My New Samsung Fridge Won't Quit Beeping - eHow
www.ehow.com > Home
Remove bulky food items that might keep the door ajar. ... Samsung refrigeratorsfeature an internal door alarm system to alert you when a door ... The alarm turns off and the beeping stops no matter how long the doors remain ... Therefore you hear thedoor alarm go off in intervals, even though the door is actually closed.
Jan 19, 2016 | Samsung RF4287HARS French Door...
Changed filter on samsung rf4287hars refrigerator. filter icon on LED is still red
Hold Alarm for 3 seconds and this should reset the filter light. Good luck!
Jul 04, 2014 | Samsung RF4287HARS French Door...
How do I get red filter light to go off on my Samsung RF4287HARS refrigerator
Press "Alarm" and hold for 3 seconds. It will reset the Filter Reset.
Good luck
Samsung french door refrigerator wont disense water after replacing water filter
Put the old one back in and if water works, then the new filter is blocked. Buy another filter.......
Jan 11, 2014 | Samsung RF4267HARS 27 cu.ft. French Door...
Samsung refrigerator filter light won't go off after new filter installed
Press and hold "Alarm" touch pad for 3 seconds and it should reset the filter light to blue.
Feb 02, 2013 | Samsung RF4287HARS French Door...
Water tastes funny
if there filter was not properly installed you would not have any water at the door.
you do not need to turn the water supply off to change the filter.
you should be able to push the filter light for three seconds,they do not turn off they just change color
May 28, 2010 | Samsung RF265AA Bottom Freezer French Door...
I have a red light that looks like something water dropplets?
Ok, That sounds like a water filter change light. The model number you gave is for an oven and if possible could you give me the true model number for your Samsung refrigerator. That way I can tell you more about how to change the filter and reset the red light, Thanks Sea Breeze
Dec 27, 2009 | Samsung RF265AA Bottom Freezer French Door...
Apr 11, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
