Question about Dryers
How to obtain a manual for my dryer - Dryers
Service manual
You can try to obtain a manual from Indesit
Jun 01, 2013 | Indesit IS70C Electric Dryer
Can i get manual for maytag neptune elec dryer model number mde3000aya
You can obtain a FREE copy of the user's manual at managemylife.com. Type in the model number "MDE3000" under their "Manuals" link and you will find a manual available in .pdf format. Here is a direct link:
http://www.managemylife.com/mmh/owner_manuals/11455/MAYTAG-Residential-Dryer-L0807349?brand_name_search=mde3000
I hope this helps you.
May 05, 2011 | Maytag Dryers
The drum doesn't turn but it heats fine
With this model, it is usually the belt, has either broken or come off, the drive pulley.
It is a difficult job to do, but it could be done DIY. You will need to obtain a service manual, and the belt to do so. (You would need to obtain a service manual first, to be able to obtain the part number for the parts required, as this is the only place this info exists)
If you do not wish to DIY, then please contact a Bosch service center, and ask for a "Quote" for the repair. When the serviceman calls.
Below is a DIY website to assist you in troubleshooting the exact cause, as although it is usually just a belt, it also maybe, the Motor, the main board,,sensors, the list goes on...
http://www.acmehowto.com/howto/appliance/dryergoe.php
Oct 03, 2010 | Bosch Axxis WTA 3500 Dryer
Anyone know where I can obtain a copy of a service/troubleshooting manual for Sensordry WhiteKnight tumble dryer? Dryer will not tumble.
You can trace this out without any service manual , to only keep the logic of tracing the voltage to the circuits. Now if the tumble is not working it is the motor not working, so check if the door switch is working and then the program controller.
If there is power to motor is humming check if this has a capacitor. If so check if faulty as the motor will not start.
www.appliancerepair.net/dryer.htm
www.devicemanuals.com/guide/???dryer-manuals.html
Sep 30, 2010 | Dryers
I would like to obtain the user manual is it
Sure. Just click on the below link to access your user manual. Be sure to print it out for safe keeping, and storage.
CLICK HERE
Jan 06, 2010 | Whirlpool Dryers
Dryer takes 2 or 3 cycles to get clothes dry. how
they make a dryer vent cleaning kit found at Home Depot and Lowes
Dec 16, 2009 | Dryers
GE Profile dryer Model# DPSQ475ET4WW
You posted under a DPGT705EC and then a DPSQ475ET4WW, so I am going to guess you have the later one. If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, use a putty knife to push in on the 2 clips about two inches in from the sides at the seam where the front panel meet the dryer top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side. You may have to contact GE to obtain an owner's manual (but there is nothing in them about how to service the dryer, just installation and settings, etc.) Parts can be obtained from just about any appliance service company or appliance retailer which does service in your area.
Nov 19, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
Top Dryers Experts
