Question about Hoover Vacuums
How do I take the Hoover Wet and Dry vacuum pipe apart to clean it. There is something stuck in the handle piece.
    Sergeant:
    Champion:
  • Hoover Expert
  • 357 Answers
Best left to a professional. Your local vac shop can help
Posted on Jun 12, 2017
reddevil6
  • 1673 Answers
SOURCE: Hoover wind tunnel vacuum cleaner shuts off during use
Check the inlet down by the brush roll to make sure it isn't clogged. If not and the hose isn't clogged, then probably the thermo protector (part #28382093) maybe bad. It is mounted near the motor. Could be motor Part #43576188. But I would suspect a clog in the inlet or hose, or the thermo protector has gone bad.
Posted on Jan 22, 2008
reddevil6
  • 1673 Answers
SOURCE: hoover floormate
The tank sits on what is called the reservior asm. it is actuated by the control rod inside the handle. With the tank off, watch and see if you can see that rod hitting the reservior asm when you squeeze the trigger. If it is moving up and down on it, then the resorvior asm may be bad. Also check the valve at the bottom of the tank, manually push it in and see if it releases water.
Posted on Feb 29, 2008
SOURCE: I can't put my vax vacuum cleaner back together
Contact Vax customer service, they are very helpfull!
Or use this link to find your local service agent: http://www.vax.co.uk/support/service_and_support.php
Hope this helps.
Dina
Posted on Dec 22, 2008
ukvacfan
  • 328 Answers
SOURCE: i need an operating manual for my hoover floormate
http://www.hoover.com/pdfs/manuals/H3000.pdf
You will need adobe on your PC/MAC to open this.
Posted on Mar 27, 2009
  • 18 Answers
SOURCE: manual for Bissell 1672 BIGgreen Wet/Dry Vacuum
Here is the user guide for model 1672 in either English or Spanish: http://www.bissell.com/searchresults.aspx?searchtext=1672&mode=userguides
Posted on May 25, 2010
There is no suction on Hoover Floormate. Have cleaned everything I can see or remove
check the hose from the base to the water channel when handle is down, and see if the hose is split and open. it becomes brittle and breaks as it ages.
Apr 01, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
The clean water is leaking straight out through the bottom of the machine. This just started out of the blue. I cannot use the machine because of this. Any ideas?
It sounds as if the reservoir is stuck open. If you look behind the upper tank, you will see a rod that opens the reservoir when the handle release is squeezed. This part may need replacement.
Jan 27, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
My Hoover Floormate series H3032 won't suction wet or dry. I have thoroughly checked the hose for clogs or cracks and there's no problem there. I notice the float never closes but just hangs down...
Check again that the pipes aren't clogged. Check all the way through from where the muck goes in to where it's supposed to end up, paying particular attention to places where the pipe narrows, goes round a bend, or changes material.
Check the machine doesn't just need emptying.
Wet/dry machines usually have some sort of float operated stop valve to stop you flooding the motor when you've filled it with water. Make sure this isn't stuck shut.
Check everything from the impellor right back to where the muck goes in is airtight. It doesn't take a huge hole to lose you a lot of suction. Pay particular attention to places that are meant to come apart routinely, and places where hoses join to hard fittings. If in doubt, run the machine and listen for sucking noises.
If there's a filter between the fan and the air outlet (there usually is) make sure it is clean
Assuming the motor is running, check it is turning the fan impeller.
Hopefully, one or other of these will get you somewhere
Dec 09, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floor mate/ wet/dry I added the water and turned on and no water is coming out? What did I do wrong, I dont have a manuel
I have had the same problem. I took the darn thing apart to see if the hose was loose. Come to find out that when you fold the handle there is an extension that sticks out. This extension pushes down on a plunger that allows the water to squirt out. My extension has broken off some how. I believe this to be a manufacturer defect.
Aug 11, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Clean Water Tank Leaks
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=612034
Posted by Liviaa on May 21, 2008
The clean water tanks leaks. What's causing the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 21, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate won't dispense clean solution
The tank sits on what is called a reservior asm, that may have gone bad. Does the water flow out of the tank when you push in the valve at the bottom?
May 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
No water or cleaner coming out when cleaning floor.
take the top part off to get to the middel and open it up inside u should have a little box with wires an hoses going to it just take the two hoses off and put a clean one on an blow throw it if having trouble, get a thin bit of wire and clean were the two hoses go then try blowing throw it again.
Dec 04, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
