Question about Ford Garden
I have a ford tractor It has got 3600 on it but I think it was a utility tractor cause there is yellow paint underneath. the number on it is 253C stamped by the starter
5 Suggested Answers
  • 8404 Answers
SOURCE: my 1949 8N Ford tractor, the starter just spins
My thought is you need a new "bendix" for lack of a better word. The device I speak of spins out and connects with the flywheel. There is the possibility you have electric problems but based on what you say, I think it is mechanical.
Thanks for posting your question at
Pleae vote
thank you
Posted on Nov 09, 2009
  • 203 Answers
SOURCE: Diagrams_For ford 2N tractor starter
If you have not already found the info, I would suggest visiting the following website for some detailed help:
No cost but will have to join to post questions. Likely all info can be had simply by searching the Ford "N" section. Good Luck!!
Posted on Nov 27, 2011
  • 1212 Answers
SOURCE: Ford tractor casting number on the blockIt is Lae 8015-E
Is there a serial number on the build tag or on the engine block? That can sometimes narrow down the range of years.
Also, is it flathead? Overhead valve? number of cylinders?
Was there another set of 4 digits ahead of the "LAE"? Is there a casting number on the intake manifold?
Something like D78A-XXXXXX-letter? This would be a 1970's era production
C0XX- would be 1960's production. Some tractors from the early 60's carry a "C" as the first digit of the serial number on the production plate, and after about 1966, they all do.
B8A--########-letterornumber? postwar production through 1958.
You should have small 4 cylinder Ford Industrial Kent engine and that was dificult to line up some parts for it in the US and Canada- There are performance parts available for it. It is a metric specified engine with "English" specified bolts. 3.45 inch bore but more often found metric 87.6 mm
To be sure you do, the manifold will have the D78S-XXXXX style casting number. This is a popular racing engie, so stock parts are difficult to find in some areas. And to complicate matters there were 2 different versions as well, 2mm difference in cylinder bore.
However the LEA block narrows it to 1970 through 1973. production.
If yours definitely has the fifties or early sixties look to it, that LAE may actually be an EAE,which would make it 3 7/16 inch bore 4 cylinder 134 CID which was used in the NAA, 501, 541,600, 601, 700, 701, 2000 and NAB.
Posted on Jan 09, 2012
  • 2478 Answers
SOURCE: ford 3600 tractor wont move in high gear
Is the clutch slipping?
Posted on Oct 22, 2012
3600 series . Year is 1978. Need the production numbers above the serial number for more detail.
Dec 23, 2016 | Ford Garden
My 3600 gasoline ford tractor stalls repeatedly after it warms up. It will start but runs for only a minute or two. It acts like a fuel problem. Any Ideas?
Has the system control module been checked for fault codes? I would think a Crankshaft position sensor or fuel pump issue.
Sep 21, 2016 | Ford Cars & Trucks
4600 ford tractor losing power steering fluid but have no leaks.
The fluid has to go somewhere is it leaking into a conjoining piece like the transmission...?
Nov 03, 2013 | Ford Tractor Grill 2600 3600 4600 5600...
3600 ford how to time it
if you think its 180 out. Pull the dist. up enougn to turn rotor
180. You should have it.
Oct 02, 2012 | Garden
I am looking to buy a used white 2001 ford zx2 that was rear ended and needs the rear bumper replaced, what is an estimate for the cost?
try an after market place that sells parts also a salvage yard also remember because cars are made at different factories through out the world take the exterior paint code inside on the driver door and the VIN# normally it is the 7th number on the vin so if you find one with the paint code of your car it will save you having to paint it but finish master are really good on matching paint
Jan 13, 2009 | 2002 Ford ZX2
Garden Logo
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
