Question about Bush Televison & Video
My bush smart tv crashes when I turn it out,makes a very loud noise,can only be stopped by unplugging it, bought it from Argos a year ago and have misplaced the receipt, is there any way to fix this?
  • Anonymous Apr 30, 2017
    *it on
    * it's like an interference noise
    Top Expert:
  • Bush Master
  • 75,032 Answers
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 30, 2017
  • 1074 Answers
SOURCE: popping noise
The anode cap on the back of the tv tube is leaking the high voltage be careful as going into the back of a tv it store very high voltage and could be fatal.the solution to problem get a tube of clear or red silicone discharge the high from the tube,you do this by getting a alligator clip with wire attach clip to a ground wire on the back of the tube attached the other end of the wire to screw driver gently push it under the Anode cap you will hear a popping sound with i little sparks. remove the cap from off the tube get some alcohol wipe the dirt away apply the silicone around the anode and the anode cap place in on back and leave it to dry and cure for about 7 hrs close up back and turn on your tv and all the popping sound is gone.good luck.but if it is the wire for the anode cap that comes from the flyback is the one leaking change the flyback.again good me on or email me at
Posted on Apr 24, 2007
  • 8617 Answers
SOURCE: TV makes chirping noise, won't turn on!
That usually means a problem in the start up or deflection circuits. Diode, Horizontal ouput or driver transformer. What Chassis is this set, and I will be ableto give you some better information. Rca , GE and phillips need to be diagnosedwith the chassis number. Let me know the chassis.
Posted on Jan 25, 2008
  • 225 Answers
SOURCE: Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
Posted on May 02, 2009
SOURCE: smart ups 1500 apc making loud noise
tighten the screwa on the body
Posted on Jun 10, 2009
  • 105 Answers
SOURCE: loud static noise without warning
this problem come due to memory ic faulty contact service centre for memory is
Posted on Jun 04, 2010
Have Mikomi TV ( from Argos). Remote is a Bush .Need to replace remote ,'One-for-all' replacement does not work on tuning , any suggestions ?
If you have a smart phone with an Infra red sensor, you can download an app. Alternatively, try eBay or Amazon
Oct 24, 2016 | Bush Televison & Video
Hi 2 years ago I bought a BUSH washing machine model A1249RLB after having the machine for about 6 months the counter balance weight came off in the middle of a cycle destroying the machine I contacted...
my advice is simple if your disabled like me they contact your local reclimation yard center,,,, there are many across europe they will take your old machine away and provide you with a front loader machine refurbished i can help you via a local charity who will help too get it fitted email me at i can help you source a machine locally for free exchange ...
this isnt good enough im sorry youve had to ask for help here!!
Mar 05, 2015 | Washing Machines
Need bushtv code for sky remote lc39gl12f
If you have purchased This Tv Bush LC39GL12F from Argos, there is not a code available and Argos do not forsee a code being available in the near future.
I was advised to call Argos Customer service on 0845 6403030 to log a complaint as to no code and eventually a code maybe made available..
NO Good Ringing Argos Tech support, Ring 0845 6403030 Argos Customer Service.
Dec 03, 2012 | Bush Televison & Video
Wharfedale Powercube uncontrollable loud noise
Change the 2 elco's in the supply
6800µF 63Volt
Aug 01, 2009 | Wharfedale PowerCube PC-12 Subwoofer
Loud buzzing noise when turning on
It sounds like a bad internal connection or a component failing. If the picture still is very good take it to a known good repair shop.
Nov 21, 2008 | Televison & Video
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
Hdtv dlp 52 inch loss of picture and loud buzzing noise
Please see It sounds like your flyback transformer is not properly soldered down/is failing.
Sep 06, 2008 | RCA HD52W59 HDTV Projection Television
hi mate, ive had the same problem before with this amp. i bought it new aout 6 years ago and bought another new one about 1 year ago, new, for £70!
on the first amp there was a problem with the surround sound aspect, it kept overloading when turned up even a fraction, it would tick 4 times and power off. Eventually the surround sound stopped working all together and whenever selected made a VERY VERY loud hissing/crashing noise through all my speakers, blowing one of them, SO BE VERY CAREFULL.
when that happened i assumed was broken so bought another one, and had same overload trouble when i got a new speaker package.
Im pretty dam sure it was the ohmage ratings being different on 2 of the surround sound speakers that srewed the 1st one, so id suggest you check theyre all ok, as well as the speaker watt-age.
what are the specs on all your speakers (ohms and watts RMS)??
do you listen to LOUD music through the 5.1 option??
hope this helps, if all else fails buy a new one mate, theyre so cheap. go into panasonic shops and see if they have any left.
Apr 23, 2008 | Panasonic SA-HE7 Receiver
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same was deemed unrepairable and I was advised to return it to Circuit a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
Televison & Video Logo
27 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
