Question about Nikon Cameras
Does the Nikon Coolpix L310 require special batteries, i have tried both rechargeable and Alkyd batteries and neither want to keep my camera going? This camera has been such a disappointment
  • Nikon Master
  • 5,412 Answers
You have to use high-power rechargeable batteries - 2300 mAh or 2500 mAh
Posted on Apr 30, 2017
Tip
Nikon Coolpix keep resetting Time and Date and menu settings.
Hi.
I am listing this tip for the Nikon Coolpix 995, but the tip is valid for all Nikon Coolpix models.
The Nikon cool pix settings are saved into an internal memory.
The internal memory is maintained by an internal rechargeable battery, that is recharged from the main Li-Ion battery.
If you leave your Nikon overnight with no main battery, or if the Li-Ion batteries have drained, then the internal battery will also drain , resetting the clock and other settings, saved on the internal memory. The camera may even drain in about 6 hours depending on the camera, normally it takes at least 12 hrs to drain the clock battery.
If the internal battery is resetting immediately, after you set the clock, or just after few minutes, then the clock battery must be replaced.
The camera must be disassembled completely to replace the battery located on one of the two main internal boards.
Nikon says that the clock battery loosing charge is normal. I quote what they say on the publication titled " The Nikon Guide to digital photography with Coolpix"
"Backup battery of the clock
The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset. Once the main battery has been reinserted, the clock battery will recharge in several hours, during which time the main battery should be left in the camera."
Original file: Download here
If the clock does not work at all, and is resetting immediately, even though the Li-Ion batteries are fully charged, then the best thing to do is calling Nikon, at the number listed on the owners manual, telling them that you did not do any improper use of the camera, and trying to get the fault repaired as factory defect. That is not always possible, and the decision depends on Nikon customer service.
See also: Nikon | Contacts
Ginko.
on Feb 05, 2010 | Nikon Coolpix 995 Digital Camera
Nikon Coolpix L310 usb driver
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa ( http://picasa.google.com ).
Oct 19, 2013 | Nikon Coolpix L310 Digital Camera Black
Konica Minolta keeps taking blurry photos? i dont know what i have pressed?
I'm curious, did you know:
Please be informed upon the termination of the Agreement between Sony Corporation and Konica Minolta Photo Imaging, Inc.. Konica Minolta will cease the entire customer services for Konica Minolta cameras and related products, as of 31 December, 2010.
After 1 January, 2011, the Repair Service Providers will continue support for the repair service independently.
here is a link to this: http://ca.konicaminolta.com/support/repair/index.html
On another note, and to try to help gain a solution to your problem...
My camera (the Nikon Coolpix L110) uses special batteries made by Nikon and they are very adamant on not using other battery brands... in fact, using other brands may negate their warranty. Is it possible yours also requires a special battery?
I ask because I'm having the same problems with my camera and just learned of the special Coolpix batteries. I guess I should have read the instructions more thoroughly,.. but I don't recall seeing this before tonight while I was looking for a solution to my own problem; blurry pictures as well.
I'm going to try the Coolpix batteries to see if this helps. Perhaps you might do the same if you find yours also uses a special battery. Good luck!
Jul 13, 2012 | Konica Minolta Dynax 5D / Maxxum 5D...
I keep getting the message "battery exhausted" on my Nikon Coolpix L22 camera even when I've replaced with new alkaline batteries. They are not rechargeable batteries though. I've tried...
Try rechargeables anyway just in case.Sometimes with age these cameras don't work well with alkalines. If that still doesn't work then I would suggest contacting your local Nikon authorized service center.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Nikon COOLPIX L20 Digital Camera
I have a Nikon coolpix L18 and can only take around 10 pics wiht it, with alkaline aa batteries, before I get the message "batteries exhausted". What can I do? Is the camer defective?
Well, alkaline batteries don't last long in a power-draining camera like the Coolpix. Try some rechargeables and keep spares fully charged.
Aug 12, 2009 | Nikon COOLPIX L18 Digital Camera
Cameras Logo
46 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
