Question about Sewing Machines
Casing holding bobbin came out and I am unable to get it back in. Outer ring and internal bobbin case just fell out in my hand. Need internal schematic.
  • 8 Answers
SOURCE: bobin casing
Look in the bobbin area to see where the screw fell out. Check your manual. Sometimes they have a good picture of the bobbin area.
Posted on May 06, 2008
  • 323 Answers
SOURCE: Needle hits bobbin outer casing
Your hook/needle timing is off and it needs to be seen by a technician before you damage the hook. Some dealers can do a 24 hour repair for an additional charge.
sewman7
Posted on Jun 09, 2008
SOURCE: Bobbin Casing - CE150
Hi, I have one Futura GE-150, why the bobbin will not automatically stop when completely filled.
Posted on Apr 14, 2009
mohammed387
  • 1952 Answers
SOURCE: sewing machine bobbin casing is loose and can't get it back in!
In the lower right hand corner of the bobbin case area, there is a small finger-like spring structure. Gently lift it and push it to the right. Take the bobbin case in hand and inspect it. It is a round piece of metal with a groove running down the edge of it. Now look at the hook, or the round piece of metal that is in the bobbin case area. It has a slight shelf-like structure. Place the bobbin case groove into the shelf-like structure in the hook so as to make it sit flush. With your finger, take the front of the bobbin case and push it to its left so that it is as far counterclockwise as possible and replace the spring.
Hope this helps.
Posted on Jul 20, 2009
  • 136 Answers
SOURCE: Bobbin Casing keeps coming out.
This machine has had 2 different updates for the bobbin case, the second also included a new bobbin visor and the metal bracket that holds the bobbin case in proper position. This sis located at about the 5 oclock position looking straight on at the machine. These new pieces must be adjusted and i am sorry the exact position cannot be explained. It must have just the right amount of movement between bobbin case and bracket. The bracket also must be positioned just right.
Posted on Sep 08, 2009
Need help reassembling bobbin area.
You didn't state what model you have, and that makes it tougher to help you.
I'm going to take a guess here that the part that fell out is a silver U shaped part located on the right near the bottom of the bobbin basket (holds the case). If that's the case, it's called a "cushion spring" and can just be reinserted by hand. It is part of the assembly that prevents the case from moving while the thread is unspooling from the bobbin during operation.
Oct 30, 2014 | Singer Sewing Machines
How can I reinsert bobbin race back into my elna su 68?
Hey I can help you with this, its a long detailed explanation though. Have you removed the bobbin holden, ie,undone two small screws and lifted out the silver bobbin case, leaving a black round thing? This black bit is the lower ring guard, you have probably undone this to remove a thread caught in the edge of the bobbin case or umderneath. Elna manuals never detailed cleaning here but it is simple enough and needs doing from time to time, i have seen big wads of felted threads and lint under guard rings when pulling apart machines. This video shows how to line up the lower guard ring, the outer casing and the bobbin case.
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
I always turn the flywheel until the opening of the lower casing is facing forward, then look at the black lower guard ring and turn it until the cut out bit is facing the front. Now look a the bobbin case, it has a couple of silver Beaks and these need to fit in between the stoppers on the outer case. You will know if lined up right as it just fits straight in, wiggle a bit left or right until its lined up. Those two silver screws have to marry up with the two holes in the lower guard ring.
Once aligned , tighten up the two screws until firm. There is a dark coloured screw too, leave it alone.
Hope,is helps, once youve done this a couple of times, its easy.
Sep 04, 2014 | Elna Sewing Machines
How to put together the bobbin case assembly
Replacing the bobbin case after changing the thread spool gets you back to sewing. The Singer Simple model is designed for the beginning sewer. Even with its simplistic design, often getting started takes a bit of time, concentration and practice. Without the bobbin casing properly in place, the machine will not sew. You can get the machine up and running again.
The little spool holds the thread inside the bobbin casing.
Turn off the power to the machine. Power is not needed for any part of the process. Turn the machine off and unplug for safety reasons.
Turn the hand crank on the machine to move the needle into the highest position. Move the presser foot the up position.
Open the hinged latch covering the front of the bobbin cover. This is the device that holds the spool in place.
Place the threaded spool inside the inner casing. Place in so the thread is running in a clockwise direction.
Slide the thread through the slot opening on the let bottom of the casing. The slot is next to the outer arm of the casing. Close the hinged latch.
Hold the casing so the outer arm is sticking straight up. The thread will be coming out to the left of the arm; lay it under the arm to the right.
Push the casing into the internal bobbin slot on the machine. It will lightly snap into place.
Replace the outer machine cover over the bobbin
May 20, 2012 | Singer 2263 Mechanical Sewing Machine
MY BOBBIN CASE FELL OUT TWO PIECES HOW DO I PUT IT BACK TOGETHER
I assume you actually mean the metal ring that holds the small round case that the bobbin itself sits in. There are usually two arms that swing in to hold that larger metal ring in place and then there is a plastic and metal piece that sit behind the large metal ring. fit the plastic piece that may look somewhat like a scoop next to the metal piece that usually has the post the the bobbin fits onto and has a quite sharp tooth on it. The metal ring then goes on to hold those two pieces in place and the two arms swing in to hold the metal ring into place. The bobbin or bobbin case now can be put back in. Hint on metal ring placement: they almost always have a notch that goes at the very top where the arm on the bobbin case sits in when it is in place. You may find it easiest to do this with the machine laying on its back so you don't have to have 4 hands to hold everything in place while putting everything back in.
Feb 22, 2011 | New Home HF-2022
Can't remember how to load the bobbin
If you have the seperate bobbin case that goes into the raceway, that is the bit which should have a black clip either side, make sure the needle is at the top , with the two black clips open the gate can be dropped down or taken off, the half moon shape shuttle should fit in quite easily, put the gate back up and put the clips acrosss to hold it in, take the bobbin case by the latch with thumb and forefinger and pop it in.
Jul 22, 2010 | White Sewing 1415 Mechanical Sewing...
Unable to replace bobbin case back into machine
Here's how I do it. I hold the thread with my left hand, just like the thread wikk be pulled up. With the right hand pull the metal tab toward me, hold it open while pushing bobbin in and twisting. When bobbin stops turning and feels seated, then release the metal tab to lock. good luck!
Nov 18, 2009 | Singer Sewing Machines
Bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
May 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin compartment trouble
Put the needle in the up position. Tilt the machine back with one hand and lay the hook in its position on what is called the hookrace. The little ledge inside the the circle opposite the other part that moves. Then take the outer ring and lay that in over top of it. There is a small pin on the bottom that fits into a notch. The two small nubs should be on the outside, then click the two black knobs over those. Put the bobbin in the case and the thread through the notch up under the tension spring on the case. Looking at the back of the case, pull the thread and in most machines the bobbin should turn clock-wise. Now snap it onto the post.
Your good to go.
Good luck.
Jul 31, 2008 | Brother XL-5130 Mechanical Sewing Machine
sewman7
Jun 07, 2008 | PfaFF Creative 7570
Bobin casing
May 05, 2008 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
