Tablets & eReaders Logo
G
Graham Farquhar Posted on Apr 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to recover Apple ID for ipad - Apple Tablets & eReaders
Darren Neal
Level 2:
Habit-Forming:
New Friend:
  • Expert 51 Answers
  • Posted on May 01, 2017
Darren Neal
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
51
Questions
0
Helped
6881
Points
119
Go to iforgot.apple.com and follow the prompts
Why does my IPad always ask for the ITunes and IPad password but will not accept it. Also it shows "a problem has repeatedly occurred on Apple ID
The password is incorrect. Remember these password need to be exact, capitalization is usually the culprit.
Next, you Apple ID may be different from the iTunes password.
You should be able to recover either through Apple support.
My sister forgot her Apple ID on her iPad and she's 55 and can't remember her password what to do?
Under this circumstance you may have to reset the iPad if you forget both Apple ID and its password.
To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your tablet. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
How can I reset password for my Apple ID to get into ITunes?
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad
This is all done on an iOS device and is often the simplest way to log back into an Apple account:
  1. Open the Settings app and scroll down and tap on "iCloud"
  2. Tap on the email address at the very top of the iCloud settings screen
  3. Tap on the blue text underneath the password entry that says "Forgot Apple ID or Password?" where you'll have two choices:
    • If you know your Apple ID and don't remember the password, type in your email address and click "Next" to start the reset process
    • If you don't know your Apple ID, tap on "Forgot your Apple ID?" and fill out your full name and email address to recover the Apple ID login (yes, you can then do the password reset after you have the Apple ID)
  4. Answer the security questions pertaining to that Apple ID, and follow the onscreen directions to complete the process
At this point you should be good to go, you can reset the password for the account and then login as usual.
4answers
Why need passcode for software update ipad2?and how can we fix it?
If its asking for an apple ID or iTunes account password then you need to sign in with that. If you forgot it you can recover it using the email account you signed up with. If you have a lock code on the tabket then it may be that one. You can sometimes sign out of itunes and sign in with a new one as well. This is a security feature to prevent apps from auto updating and wiping out settings or other people screw with it.
Can't reset the iPad without the pass code
this is apple's lock, i will not want someone to open up my iPad if it is stolen, if not contact apple directly they will assist you after some checks, remember that the code can be reset if you know the apple id and password for that iPad.
4helpful
2answers
Where do deleted videos go if you delete them off the IPad
If you are talking about videos that you shot with the iPad, if you did not backup the iPad or sync with iTunes before you lost them, they are gone. If you mean purchased movies - you may be able to dwonload them again in the purchased tab of iTunes - if you live in the U.S. and - if those particular movies are available for re downloding. You need to use the same Apple ID that you bought them with.
And there is a step-by-step tutorial about how to Recover Deleted Files on iPad, which can help you recover deleted videos from iPad.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
