Question about Dell 962 Photo All-In-One InkJet Printer
I have the same **** - error 2200
So, there's NO FIX for this? Makes me think they are all set to give this error after a certain time is up! I can't believe Dell says to "buy a new printer!" HP is sounding better and better.
  • 118 Answers
I read the following on the net about this error.
Error 2200 is described a "scan carrier stall". The general consensus to fix it is to unplug the printer at the wall socket, leave it unplugged while you have a coffee and then plug it all back in. It should work properly but don't know for how long.
Posted on Jul 25, 2009
  • 73 Answers
Try disconnecting your printer.
Download and run this patch to completely remove the printer from your computer.
Restart your computer.
Download the proper drivers.
XP Drivers
Vista 32-bit Drivers
All other drivers
Install the proper drivers. You'll be prompted when to connect your printer.
Install the latest firmware for the 962 printer
Let me know if you need help doing this, or other help.
Lg top loader ie error message, fills ok, but water running out of bottom of machine
Hi IE means Inlet Error. The machine thinks that it is not filling (as a certain time has passed without reaching level it wants).
This makes sense if water is running out the bottom.
You will need to find the leak. Maybe the tub to pump hose, or the drain pump itself. Once you stop the leak and the machine can fill in the correct amount of time, you shouldnt see the IE error any longer.
Cheer
Jun 01, 2014 | LG WD-1045FH Front Load Washer
Show error 2200
The 2200 error code indicates that the scanner has stalled. That's why you're not able to make a copy. Please refer to this article on the Lexmark website to fix the problem:
2200 Error on the Lexmark X7100 Series All-In-One
Should the error continue to display, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Dec 11, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I get a 2200 message from my lexmark717 how can fix it?
The 2200 error message indicates that the scanner has stalled/jammed. This article in the Lexmark website will help fix the problem: 2200 Error on the Lexmark X7100 Series All-In-One
Apr 20, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Epson 2200 printer error code 40. What is error code 40 and how do I fix it?
Computer and printer may be set to different baud rates.
2. Computer is powered off.
3. Unseated or defective MIO card.
4. Indicates an abnormal connection break occurred while Transferring data from the computer.
5. Turn printer off and reseat the network card.
6. Verify that the printer serial configuration is set the same as the computer.
7. Check that all cables are connected to the EIO ports and that the EIO board is seated properly
  1. CBR Tech Solutions or http://www.cbrtechsolutions.com
Feb 20, 2011 | Epson Stylus 2200 InkJet Photo Printer
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
My nikon S220 has a lens error makes weird noise and the lens goes in and out 6 times when i turn it on. Help
Lens is probably just stuck, because of debris or misaligned gears. The lens can in about 50% of times be repaired without having to replace it. Try to return to manufacturer. If you're out of warranty, there are third party place that fix them such as camera lens repair. There are also free camera repair guide websites that show you how to replace the lens, the part is usually available on ebay.
Jul 02, 2010 | Nikon Coolpix 2200 Digital Camera
Cant Download Certain Updates
I don`t know if you are speaking about a game console or a pc, but if it`s a pc then I think your problem is due to the date and time set wrongly. Go to control panel-date and time and reset it to the right time. I think even if you are talkign about a game console that accesses the net , the problem might be the same, that is the time is set incorrectly.
May 14, 2009 | THQ WWE Smackdown Vs Raw 2009
My Dell 962 Photo Printer gives error when trying to photocopy.
The issue you are experiencing with your printer i.e error 2200 is related to "Scan Carrier Stall error" I believe the steps mentioned below will fix the issue,
1. Unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
5. Plug the power cord back into the wall socket.
  1. Go to www.support.dell.com.
  2. Click on Drivers & Downloads.
  3. Under Option 2: Select a Product as printers .
  4. Locate the printer(s) 962 printer and click Go.
  5. Select an Operating System that is installed in your computer then choose downloads and look for Firmware.
  6. Download and install the firmware, then restart the computer and the printer, however please make sure that you do not restart your computer and the printer when the download and the installation is in progress.
I would appreciate if you could let me know if you have refilled the black cartridge, cause Dell printer often give error messages if the cartridges are refilled and not replaced with an original Dell one. If you have done so please replace the cartridge with a genuine Dell cartridge.
Regards
Malik Khan
Jan 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
258 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
