Question about Vacuums
Rug doctor carpet cleaner won't suck up the water
SOURCE: The bissell proheat turbo carpet
Bissell cleaner will not **** up water???
Posted on Sep 14, 2008
farr64
  • 121 Answers
SOURCE: Cleaner not sucking up dirty water.
try stripping it down and cleaning all parts and filters .some cleaners use a safety 'ball' to stop water getting on the motor is this stuck it should slide up and down a small track in a tube..good luck hope this helps farr64.
Posted on Apr 29, 2009
SOURCE: hoover will not suck carpet shampooer
the most common problem is the recovery tank. Most often the square piece of plastic that attaches to the side of the recovery tank is not snapped in-- it comes loose when you dump the tank. Take off the lid, pull the clear plastic sqare (about 4 inches by 5 ) that is attached on the OUTSIDE of the recovery tank and snap it back into place.
2nd make sure the rubber rim is clean and free of debris
3rd attach the lid with the hinges on the back first then snap down the lid
4th make sure the yellow float is down on the bottom (this is inside the filter inside the recovery tank)
5th put the recovery tank in the machine FRONT FIRST (where the two round peices of plastic are)then back, snap the sides back to lock the tank in place.
If these things dont work....make sure your not clogged with debris on the top (but I am sure you would have seen this before doing all the rest!)
Posted on Jul 21, 2009
SOURCE: Hoover steam carpet cleaner brushes dont spin
There is a plastic cover over the spinner indicator. If you take the plastic cover off there is also a little filter in that area (almost like the spinner is on the floor and the filter is on the wall). If you clean this filter it may start working again. I had the same problem before and it worked for me. I found the info in the user's manual for my model. Hope this works for you as well.
Posted on Sep 04, 2009
Wonder Wizar
  • 62 Answers
SOURCE: hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Posted on Apr 12, 2010
Rug doctor deep carpet cleaner leaks the clean water solution out the bottom so quickly I can only clean a very small section of carpet per tank. You can watch it pour out
You have a crack or hole in the container holding the clean water solution. Also check any hoses going in and out for integrity.
Aug 26, 2017 | Vacuums
My bissell proheat 2x dual dirtlifter is not succioning very well then the carpet smells
We have several parts here for the Proheat 2X,
Proheat 2X Shampooer Shampooer Parts
It may be a clog in your tank, preventing the water being sucked back up. Check your tank and tubes for clogs or damage. Make sure the brush is still rotating and the belt is not broken too.
800-775-6586
GoodVac com
Feb 26, 2015 | Bissell 2X Proheat 9200 rug cleaner
My rug doctor will not spray out water
check your spray jets are not blocked but also check your small pump is working & operating that spray the water out of the nozzles
Sep 01, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
Rug doctor shampooer sprayer quit, I think
You think ? If it did you will have to take it to a vacuum repair shop. That's not a DIY job typically.
Oct 19, 2013 | Rug Doctor Mighty Pro Carpet Cleaner
Why is my carpet cleaner over heating
pump needs replacment how do i replace it
Apr 06, 2013 | Rug Doctor Mighty Pro Blue MP-C2D
Find water pump rug doctor
is it your own machine or a hire machine?
Your best bet would be your nearest rug doctor distributor or try ebay.
Tony from DirtMaster
Feb 25, 2013 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
My bissell upright won't **** up the water, but the attachments will
Hey Maria, sorry to hear about the no suction.
Here's a quick link to troubleshooting steps to assist you.
Feb 02, 2013 | Bissell 8910 ProHeat Clear View Upright...
Rug doctor won't spray water
I had the same thing happen to mine. I looked at the hose in the water tank and the screen at the end if the hose was slimy and clogged. I took the screen off and cleaned it up, put everything back together and it works like new again. Only 2 screws and a screen.
Oct 17, 2012 | Rug Doctor Mighty Pro X-3 Ready Pack...
Can't get Bissell carpet cleaner back together
I've purchased 2 of these both are broke again, although I may fix one again and give it away instead of throwing it in the trash. You can tell by all 10 pages on this site that these machines are just **** that is poorly designed. Just ordered a Rug Doctor Mighty Pro from Kohls with 30% off for $503. You won't even find 1 problem on this site on a Rug doctor. Also you can research them as I did and 98% of their owners was very satisfied, alot of whom used bissell prior to Rug Doctor. You will also see that the performance is way, way better and not even close on cleaning.......
Feb 10, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
384 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
