I have aproblem with dstv remote only the on/off button is wsorking while others dont respond but the light is flashing
On and off is working fine but other buttons are not
    Top Expert:
  • Televison & ... Master
  • 74,999 Answers
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. [open and clean] [open and clean]
Posted on Apr 30, 2017
  • 5 Answers
SOURCE: wii remote
Hi Nixo, probably needs re-syncing, press the sync button on the Wii console and the button on the wiimote (under the battery cover), do it pretty much at the same time, the wiimote usually vibrates and one light wll show up.
Hope this helps
Posted on Feb 29, 2008
Agent Dort
  • 216 Answers
SOURCE: wii remote
Greetings baggie bird,
You need to resynch your remote to your Wii console.
You hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Go Ahead. Use Us.
Posted on Apr 21, 2008
F*** YoU
Posted on May 11, 2008
SOURCE: Flashing Lights and No Sound
I am 100% sure the battery is dead.
Opening my mm50 I find that the small 2"X 1/4" battery is attached to the back, very near the charging socket. The battery is connected to the circuit board through a small plug-socket arrangement - no soldering here like iPod. So, it would not be difficult to replace it by a DIY enthusiast. But it would be difficult to find this non-standard replacement battery. Better leave the job to Logitech service, they'd would certainly replace it on charge basis.
=Subhas Chatterjee=
Posted on Aug 03, 2008
SOURCE: Hi, My DSTV decoder is
press the shift button, its stats flashing than press the info button (tv1) works every time
Posted on Feb 08, 2011
How to reset explora remote
To set the remote to mode 3: press and hold both the i and BACK buttons for 3 seconds or until you see the green light blink on 1 and 2 (below the i and BACK buttons). The DStv Explora must be set up to "listen" for the correct mode. You can do this in DStv Central. Press the DStv button
Jun 29, 2017 | Computers & Internet
I have a Sony TV and purchased a RCA remote control new from Walmart (as a replacement for a Sony remote control). The RCA worked fine for 2 months until I accidentally hit the wrong button. The little...
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Sep 16, 2008 | Computers & Internet
Dstv remote doesnt work..
You could try to sync the remote by pressing the shift and info buttons together. Wait for the led to light.
Jan 25, 2015 | Cameras
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
1 Answer dstv remote control is not working despite showing a red light whenever i press any button.please help asap!thanx
my dstv remote control function any time it likes.pls what is the solution it is a new machine.Thank you.
Oct 18, 2010 | Televison & Video
TV does note respond to remote. Volume and menu flashes on screen
interference from flourecent lights, maybe the front panel buttons are stuck.
Aug 30, 2009 | Philips 32PFL6704D 32 in. LCD TV
Captive Works CW- 800 S REMOTE CONTROL
for some remotes you press and hold PWR + SET for 5 seconds and that's it.
Mar 31, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
