Question about The Office Equipment & Supplies
Installing Grosfillex PVC Bathroom Wall panels.
The lenght of each panel is 2600mm. The height of our Bathroom wall is 2750mm which would leave a space of 150mm to be filled. Any advice on how to get around this problem would be appreciated. If i cut 150mm lenghts to fit the spaces would this ruin the appearance of the wall.
  • 306 Answers
SOURCE: Want to hook wall thermost to Rinnai propane space heater
If you are just going for heat only just connect the t_stat at these setting red wire R white wire to W green wire to G
Now the heater you can go to the gas valve or if it has a circuit board go to Red to R and white to W Green to G. Green is optional you just need two wires hooked up. You will see on top of the gas valve three connections the ones marked th are the ones you need.
Posted on Nov 26, 2008
dennymulford
  • 1055 Answers
SOURCE: can't remove broken PVC pipe from bathroom wall...need to install new faucet
there should be an acess pannel there somewhere too get too it ,if not then you will have too cut the wall and replace the pipeing
Posted on Apr 15, 2009
SOURCE: Lenght , Weight, High of Mercedes Benz 709D bus
LENGHT 20 feet
width 7 feet
height 8 feet
weight 6,600kg
max train weight 10,000kg
so can tow max 3,400kg
Posted on Jun 26, 2009
  • 19 Answers
SOURCE: hole in copper water supply pipe
solution#2 is one way to do it however those clamps will leak after awhile. You can cut pipe on center of hole and (A) push pipe up and install a copper coupling which does involve soldiering. Or (B) you can get a brass coupling fitting called (Shark Bite Fittings) which simply slides over pipe and locks and seals on pipes. This is a fairly new product and godsend to plumbers and plumbing repair. Whenever fixing pipes in walls check for any form of leaks thoroughly before covering up wall.
Posted on Jul 07, 2009
co7196
  • 3433 Answers
SOURCE: draper dhs80i space heater cutting out after 25
Does this heater have a fan,forced heat? If so, the unit will shut down if the fan is sluggish or stops. It could be getting too hot or the rhermal safety is weak.
Posted on Oct 10, 2009
How do i work out square meterage for a bathroom (floor and walls)? I need to retile
Multiply length by height in metres for each wall, and add up all these wall areas. Then multiply length times breadth for the floor, not forgetting the shower. If it is irregular in shape, divide it up into rectangular sections, measure each and add together for a floor total.
You will need then to add about 10% to floor and wall totals for wastage.
You don't say whether you are tiling yourself, but take special care in waterproofing in the shower and under the bath, if any. Also take care with the fall to the floor drain in the shower recess, if any.
Mar 06, 2015 | Home
Mounting tv on wall
You would need to get a flat panel wall mount. Since you are unsure on how to do this, I would strongly recommend hiring a professional or handy man with experience installing the mounts. Not installing the wall mount properly could cause the TV to fall and damage the set(warranty will not cover the damage) or cause bodily harm to somewhere.
Sep 03, 2012 | Scott LCT37SHA TV
What is a wall-mounted bathroom vanity?
Wall mounted vanities are fixed on to the wall and do not touch the floor. Here is what a typical wall mounted bathroom vanity looks like -
Sep 03, 2012 | Belle Foret Furniture
I'm thinking of getting the full reclining lazyboy loveseats, how much space I need to leave between the chairs and the wall?
If it is fully reclining you need to leave a little bit more than the height of the chair's back. For example: if the back height is 19", then you need to leave about 20" between the chair and the wall behind it.
May 29, 2012 | Furniture
I need to wire a remote thermostat to my electric wall heater in the bathroom. Not sure if I run the wire from the panel to the heater first or to the remote thermostat then the heater.
Run the wire to the thermostat then to the heater
BASEBOARD WIRING WITH A SINGLE POLE (2 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLY
BASEBOARD WIRING WITH A DOUBLE POLE (4 WIRE) WALL THERMOSTAT - 120V OR 240V SUPPLYdennis675_0.gif
Jun 21, 2011 | Heating & Cooling
I am interested in purchasing baseboard heaters, particularly I have been looking at the Farenheat PHH15002 baseboard heaters. I am purchasing an 1100 square foot 2 story condo with 2 bedrooms and a...
#1 you have to calculate the heatloss of your rooms,that will tell you ur wattage require. Oil filled or not,it's just as dry. As far as ur load to panel breakers, a rule of thumb is approx 3600 watts for 20 amps,using a number 12 wire. But ur wall heaterS should suffice
Apr 21, 2017 | Fahrenheat PHH15002 Oil Filled Baseboard...
I am trying to fit a plastic bath panel i have got all the fixings but havnt a clue how to do it! can anyone help?
Assemble the legs & fix to the bath. Leave the adjustment nuts a little loose. Fit taps and waste. Place bath in position. Use a spirit level to ensure lever both front to back and sideways using the adjuster nuts to get it level. Start at one end near the wall and level to the other end against the wall then level sideways. Then check all levels again.
Further help --- rod_davies@hotmail.com
Mar 10, 2010 | Home
Can't remove broken PVC pipe from bathroom wall...need to install new faucet
Apr 15, 2009 | Plumbing
Broken pvc plumbing for bathtub faucet.
if you have tiles in the bathroom wall, the answer is yes!
it is better to go fromthe back, where there is drywall.
since PVC is glue on, you have to cut out the pipe and reconnect.
make sure the bathtub faucet is not broken, and can be reuse.
Nov 11, 2008 | Plumbing
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
