Question about Westinghouse Refrigerators
How to fit a thermostat to my westinghouse refrigerator model RP214T
How do I reset the thermostat on my Westinghouse silhouette frost free 522?
There is a few models of refrigerators that in order to reset the thermostat control, all you have to do is unplug the main power plug for 15 seconds and plug it back in. If this does not work on your model, you will probably have to get another thermostat card. If your model is still under warranty, call the 800 toll free number and pay the nominal service fee and get an authorized repair man. The parts should be free if still under warranty.
Hope this helps
Dec 13, 2014 | Westinghouse Refrigerators
Westinghouse rs662v cooling element frosting up.
Write down your model number search for a new thermostat online YouTube has videos on how to replace them yourself.
Apr 14, 2013 | Westinghouse Refrigerators
Hi, I've recently found that my westinghouse
if the back wall of the freezer is iced up the problem is most likely the defrost thermostat.
May 06, 2011 | Westinghouse Refrigerators
My door freezer is broken how do i fix it
The best is to get the replacement door from Westinghouse if a tinkering job wont help or might look ugly.
Remvoe the old broken one and put in the new one with the fittings... hope the spare of this model is available!
Sep 28, 2010 | Westinghouse Refrigerators
Westinghouse model RS663T - not cooling fridge or
IT IS THE DEFROST THERMO STAT REMOVE REAR COVER AND MELT ICE IT IS ROUND SILVER PART
Jan 31, 2010 | Refrigerators
Freezer & fridge warms up on average every 6-8 weeks. Remedy turn off and leave 24 plus hours with doors open. On turning on the fridge and freezer cool down again to operating temperature....
Good day,
That's too long a period, for a normal. defrost system failure.
You'll have to wait until it quits, then remove the rear panel and look for ice (not frost) building up somewhere in the freezer compartment.
I have solved similar problems on this model, by replacing the defrost thermostat with a GE 60 degree thermostat, and a WR9X330 GE 6 hour defrost timer to get this model to defrost completely.
It's also possible that the refrigerant charge is slightly low, causing the defrost thermostat not to reach a cold enough temperature to perform a good defrost cycle. (building ice over a long period of time).
Make sure Freon 12 was used when replacing the compressor.
Some substitutes caused the evaporator coil to act as if it was
slightly low on charge.
Nov 08, 2009 | Westinghouse Refrigerators
Digital thermostat replacement for westinghouse fridge wse6100sa
easy, just remove and pay attention with the screws you remove and do not forget where they belong when you install the new one. dont worry they are all the same size of screws, if you see longer find where it fit, ok boss.
Sep 04, 2009 | Refrigerators
We have replace Thermostat Control in westinghouse RJ390m and was told that a RJ215m is the same part in which we put in know it over freezing top and bottom with this part why. we been told two type for...
Gosh most thermostats for a particular brand will sub nicely, I cannot see why it would not. I sold appliance parts since 1990 and this is very common.
Jun 08, 2009 | Refrigerators
Refrigerators Logo
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
