Why am I getting warm air when thermostat is set for cool
  • Heating & Co... Master
  • 1,874 Answers
Sounds like your compressor is not working. Remove electric panel outside and verify contactor is pulled in. 220 volts hurts so use caution. Use an insulated screwdriver to manually press in contactor. If contactor is in is your larger copper getting cold? Visually inspect capacitor, is it swollen or damaged?? Good Luck!!
Posted on Apr 30, 2017
Bad thermostat? Heater gets warm, but cools down as thermostat fluxuates between 180 and about 230. It goes back and forth when it is @180 heater blows warm air, but when it goes to 230 etc. the air b
Are you sure there are no air pockets in the cooling system ?
You should have heat anytime the engine temp is above 140 degrees regardless what the thermostat is doing.
Nov 13, 2014 | Cars & Trucks
Tip
Air Conditioners Cooling Tips
  • Whole-house fans help cool your home by pulling cool air through the house and exhausting warm air through the attic.
  • Set your thermostat as high as comfortably possible in the summer. The smaller the difference between the indoor and outdoor temperatures, the lower your overall cooling bill will be.
  • Avoid setting your thermostat at a colder setting than normal when you turn on your air conditioner. It will not cool your home any faster and could result in excessive cooling and, therefore, unnecessary expense.
  • Consider using an interior fan in conjunction with your window air conditioner to spread the cooled air more effectively through your home without greatly increasing your power use.
  • Avoid placing lamps or TV sets near your air-conditioning thermostat. The thermostat senses heat from these appliances, which can cause the air conditioner to run longer than necessary.
  • Plant trees or shrubs to shade air conditioning units but not to block the airflow. Place your room air conditioner on the north side of the house. A unit operating in the shade uses as much as 10% less electricity than the same one operating in the sun.
  • on Sep 21, 2010 | Heating & Cooling
    I have a whirlpool wall heat/ac unit, model ACE184XL0. All of a sudden, the heat quit working. Fan still blows, and AC still seems to work, although I can't tell if it's just pulling in cold outside air...
    Dear it is a thermostat system. You can simply check it by setting temp at 30 then check either warm air is coming or cool air. at this time warm air should come. If warm air is not coming means there is a fault is realy in your pcb. It can be simply remove no need to worry.
    Oct 14, 2013 | Whirlpool ACE244XS Air Conditioner
    2008 Altima- No Heat/ Only warm air.
    thermostat is stuck open. or you have an air pocket in the cooling system or the bypass door is stuck in the wrong position.
    Oct 14, 2013 | Nissan Altima Cars & Trucks
    Heater blowing cool air
    Is it set on summer switch which is the fan running all the time blowing cold air
    Feb 15, 2012 | Heating & Cooling
    Just started making an odd noise. Normally compressor blows out warm air. Air being blown out now is very cool
    Unless I'm missing something in what you said, air conditioners are supposed to blow out cool air, rather than warm air. Or does the air just feel cooler than what you had the thermostat or comfort control set on? If that's the case, turn the comfort control or thermostat Up a bit.
    I hope this helps. Thanks for choosing FixYa.
    Jul 26, 2011 | Carrier Heating & Cooling
    What happen when your hvac blows cold air and the heat is set at 73
    Sounds like you have a thermostat problem. If your thermostat is not triggering the furnace to ON/HEAT you will not the heat you desire. IF you know how to trigger the furnace you could jump your furnace controller wires BUT DON'T do this. Instead, get another thermostat and try it. But be sure to get the same rated thermostat... take it with you when looking for a replacement.
    Not sure about everything going on with your unit based upon what you provided but your thermostat should show the current temp and the temp you set. It also show the mode that the thermostat is in (HEAT / COOL / AUTO) Manually select heat, then increase temp above the current temp setting. listen for furnace to activate or wait a few minutes for warm air output. If not, you'll have to see assistance trom a local heating and cooling company.
    Mar 09, 2011 | Goodman Heating & Cooling
    Blowing out warm air
    Turn thermostat switch to 'cool' setting. It's a 'heat pump' and is in the heat mode.
    Nov 05, 2009 | Coffee Makers & Espresso Machines
    Installing 1 1/2 ton Weatherking Heatpump and ADP WAK351807P2 air handler 1 /1/2 with 7.5KW back up heat kit. Can't seem to get the thermostat hooked correctly. I understand the Weather King product...
    O energizes the reversing valve when the thermostat is set for COOL. B energizes the reversing valve when the thermostat is set for HEAT.
    The O/B is usually a orange or black wire.
    You can't hurt anything if you choose O or B incorrectly. Hook one of them up and run the unit. If set for COOL and the unit runs cool inside it is correct. If set for COOL and the unit runs warm inside it is not correct.
    If the inside temp is opposite from your setting change the wire to the other terminal.
    Remember to disconnect power from the air handler when changing thermostat wires.
    The defrost control board on the outside unit should be marked correctly for O or B.
    Your thermostat may have a slide switch rather than a separate terminal.
    Oct 30, 2009 | Weather King 10AJA6001AH Air Conditioner
    Thermostat setting
    what i would do is see if the outside unit is working at all. when you first turn it on the air was warm due to the fact that the temperature inside was cooler than the set point. when it get within 2 degrees the unit shuts off the backup heat and your running on the hp alone. with both stages at the same temp you are running the hp and the electric heater and that can become very expensive. What I would do is make sure that the filters were clean and look at the outside unit and see if it has a red reset button on it, if it does reset it and see if the unit runs. If it doesn't then you need to call a quallified service person out to take care of the problem.
    Dec 16, 2008 | Weather King 12AJA6001AH Air Conditioner
    Heating & Cooling Logo
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
