Question about Westinghouse Refrigerators
How do i replace a thermostat on my westinghouse refrigerator model RP214T
How do I reset the thermostat on my Westinghouse silhouette frost free 522?
There is a few models of refrigerators that in order to reset the thermostat control, all you have to do is unplug the main power plug for 15 seconds and plug it back in. If this does not work on your model, you will probably have to get another thermostat card. If your model is still under warranty, call the 800 toll free number and pay the nominal service fee and get an authorized repair man. The parts should be free if still under warranty.
Hope this helps
Dec 13, 2014 | Westinghouse Refrigerators
Westinghouse freezer is not freezing and the temp is getting higher. do I need to replace freon? or is there another issue. everything seems to be working and it is running. it is an older model. ...
Last would be refrigerent unless you were aware of a leak (corroded pipe, ice build up on pipes) or gurgling noise when compress cycle is on.
Check temperature control thermostat is working. As this is electrical you need a repair person. If the temperature control passed the electrical function test, the problem may be a defective temperature sensing bulb on the temperature control. The temperature-sensing bulb is an integral part of the temperature control switch, so you need to replace the complete control.
Sep 04, 2013 | Westinghouse Refrigerators
Westinghouse rs662v cooling element frosting up.
Write down your model number search for a new thermostat online YouTube has videos on how to replace them yourself.
Apr 14, 2013 | Westinghouse Refrigerators
Westinghouse fridge freezer model RS6437*4 FRIDGE SIDE KEEPS FREEZING UP
Could you please check that model number again? The number you posted came up as a range. The model number should be listed in the refrigerator section.
Oct 17, 2012 | White-Westinghouse White Westinghouse...
Hi, I've recently found that my westinghouse
if the back wall of the freezer is iced up the problem is most likely the defrost thermostat.
May 06, 2011 | Westinghouse Refrigerators
Freezer & fridge warms up on average every 6-8 weeks. Remedy turn off and leave 24 plus hours with doors open. On turning on the fridge and freezer cool down again to operating temperature....
Good day,
That's too long a period, for a normal. defrost system failure.
You'll have to wait until it quits, then remove the rear panel and look for ice (not frost) building up somewhere in the freezer compartment.
I have solved similar problems on this model, by replacing the defrost thermostat with a GE 60 degree thermostat, and a WR9X330 GE 6 hour defrost timer to get this model to defrost completely.
It's also possible that the refrigerant charge is slightly low, causing the defrost thermostat not to reach a cold enough temperature to perform a good defrost cycle. (building ice over a long period of time).
Make sure Freon 12 was used when replacing the compressor.
Some substitutes caused the evaporator coil to act as if it was
slightly low on charge.
Nov 08, 2009 | Westinghouse Refrigerators
Digital thermostat replacement for westinghouse fridge wse6100sa
easy, just remove and pay attention with the screws you remove and do not forget where they belong when you install the new one. dont worry they are all the same size of screws, if you see longer find where it fit, ok boss.
Sep 04, 2009 | Refrigerators
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Refrigerators Logo
37 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
