Question about Kitchen Ranges
I recently bought an Efel oil Bayard stove which is heavily sooted, where can I get a manual for it?
landsend
  • 1066 Answers
SOURCE: Gas stove causing soot on everything
all of the burners are set to rich...open the vents on the burners more.  If this doesn't help you need smaller nozzles.
Posted on Mar 26, 2009
SOURCE: i hahe a double pod efel oil stove, how do i
besem ab wold womenefs kudus ahadu amlak amien
Posted on Feb 20, 2010
SOURCE: having trouble lighting a second
plug in, open bottom and clean line end by twisting and pulling pushrod, make sure valves are on, tank must be higher do to gravity feed, crack open door 1/2 in, turn timer dial (one that clicks) all the way it should glow at bottom of crown, turn on fuel to low setting (just counter clock of the click), once flame is burning across the bottom of the pan close door all the way. The door open is so that it keeps stove clean for lighting also open the door for closing. If smoke is coming out of the door close it a little more. the stove needs to be clean and will stay clean for a long time if you open the doors. if it floods you need to clean it out. there are fuel adjust screws and air adjust counter weight but have a professional set those. good luck its a great stove once you get to know it.
Posted on Oct 25, 2010
  • 37 Answers
SOURCE: Have an efel oil stove, it lights ok but the crown
The gas orfeces are pluged up you need to take a wire brush and cleen them.
Posted on Jan 21, 2011
muntejaya
  • 10421 Answers
SOURCE: just looking for any info. on efel harmony 3 wood
Please get it here : www.fireplaces-oldham.co.uk/Euroheat_Harmony_Classic_Multi-Fuel_Stoves.htm
Multi-fuel > Nestor Martin">www.murphyheating.com > Multi-fuel > Nestor Martin
Kind regards, Jay
Posted on Feb 20, 2011
Oil leak suzuki..Haven't road my 2001 vz800 much.. Turned in on today and starts to smoke out of the exhaust and oil leaking out of the exhaust pipe. Bought it recently.
You didn't say what color the smoke was, but even so I'd say that's (probably) not oil coming out - it's soot, or wet soot since the bikes been idle. Normally it gets blown out (mostly) when you ride, but when they sit the moisture in the air can turn it to gooey black gunk.
My best guess.
Mar 20, 2014 | Suzuki Motorcycles
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Soot produced by propane heating stove
If it is still producing soot two problems blocked burners burning yellow causes soot , or blocked injectors, or pressure to burners is wrong needs seting to correct pressure
Feb 07, 2013 | Heating & Cooling
Efel oil stove wont burn blue only yellow
Pull the crown and the two crown supports, scrape and vacuum the residual ash on the bottom and around the starter coil. Pull the and turn the oil feed tube scraper back out of the way. Reach inside the tube with a screwdriver and scrape out the residue until as clean as posssible. Exercise the fuel tube rod several times until there is no scraping sound. Vacuum the interior and replace the parts (Do not clean the crown).
Dec 23, 2012 | Cars & Trucks
I have an old Efel Kamina wood stove that I want to install in a new structure that does not have a chimney. I need the manufacturer's specifications to determine the distances from combustible materials...
From an insulated wall - 30 inches. Not insulated - 38. We have one as well and are trying to find out information about it.
Southport Stove Inc. Serial # F90309 ICBO 3 500 Another number: 079-66 It's a Kamina.
Any information would be great!
Sep 14, 2010 | Heating & Cooling
Having trouble lighting a second hand efel oil stove what is the steps needed to take when igniting it
Sep 13, 2010 | Heating & Cooling
Hi-E2 350 heater trips thermal switch on exhaust collector after 10-15 minutes of run time. Went through the manual tested all gas and air pressures with digital differential manometer, adjusted to within...
Check the condition of the heat exchanger. If it is heavily sooted from prior to adjusting gas pressure it will not vent properly. Check for downdrafting or blockage in the flue pipe if the heat exchanger is not sooted.
If the heat exchanger is sooted a good steam cleaning or even a trip to a car wash should remove enough soot for it to return to operating normally.
Dec 15, 2009 | Jandy Laars Hi - E2 350,000 Btu Heater
Mar 26, 2009 | Whirlpool Gold GW399LXU Gas Range
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
