IR3300 ERROR CODE 00003 - Office Equipment & Supplies
4 Suggested Answers
  • 135 Answers
SOURCE: code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS
Posted on Apr 29, 2009
SOURCE: Canon IR C6800 Error 00003-0042
E000012-0001
Posted on Nov 20, 2009
  • 89 Answers
SOURCE: canon ir3300 is giving me error code E6002-0003, h...
Turn off the copier using the power switch on the right. Turn it on again holding 1 and 9. You should see rectangles on the screen. Once this is finished the copier should be in download mode (If this process hangs or doesn't get started the disk will need to be replaced by a tech). Once you reach download mode you'll need a tech to flash the hard disk to get the copier going again. If this doesn't work, the hard disk will need to be replaced. In any case your hard disk is dying and will need to be replaced soon.
Posted on May 24, 2010
Error code E000350-0001 in ir3300
Its the serial number board. Someone swapped the main controller out and didn't change the small serial number pcb with it. That board HAS to be returned to the machine or it will not function. Only way to get a new board is through Canon engineering.
Feb 11, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How do i solv error 100 code in canon ir3300
Hi Raj
please follow link it will give you all the error codes and also will tell you what your one is..hope this helps
Dec 23, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How do I fix error code E000014-000 for my Canon ir3300 copier
E014 is strain on the fuser motor. Is the lower roller cleaning roller clean? A build up of waste toner on it and could be sticky/tacky and causing friction. Take it out and clean it or replace it.
Sep 09, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Code Error in cannon ir3300
Hi Abhishek,
Go To Below official Canon Printer Page For Your problem Error Codes Canon iR3300 Still having Problem Then follow Us For Canon Printer Support
Mar 12, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Hard disc error
the error refers to PDL board mounting error- suggest if the machine has been moved or if any parts have been removed or replaced you check ALL pwb board connections this could take some time to complete try to start where you have been working in the machine first.
Jan 16, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
I need error codes for canon ir 3300
Hello, Here is a link to the full list of all the Canon iR3300 error codes with full details.
http://www.printcopy.info/index.php?l=en&mod=free&chap=erc&brand=Canon&model=iR3300
May 20, 2011 | Computers & Internet
Error code 000000-0000 in connon ir3300
The error code E000000-000 means that you have a problem with the fuser unit. Did you have a power outage recently???? That may have been the cause of the code. Or you may need a new fuser unit... Did you try to rest the error code in service mode?????
Mar 29, 2011 | Canon Office Equipment & Supplies
According to Canon, this code is being thrown most likely because the fixer (fuser on Xerox copiers) is not seating properly inside the frame. Vibration coming from the copier operating is most likely jarring the wiring connector, making it work loose and causing the computer to throw this error code. There is a fix for this but unless you are a certified Canon Copier technician, it is highly recommended you contact Canon to send a tech to fix it. I hope this helps you.
Oct 07, 2009 | Canon imageRUNNER C6800 Copier
My canon iR3300 is displaying error code E000002-0000. Please help.
My canon iR3300 is displaying error code E000003-0000. Please help
Jul 30, 2008 | Office Equipment & Supplies
26 people viewed this question
k24674
jasbo
jasbo
