SOURCE: Cannot load maps onto micro SD card.
Yust go to www.mapwel.biz/down.htm get software MapUpload and now you can upload any map to micro sd card without loosing your existing map.
SOURCE: enzer jor-001 gps
1. Go to http://www.enzersa.co.za/GPSDownload.html
2. Download the SA Maps Version 6 upgrade.
3. Follow the instructions:
How to use
1: Download South African Maps.zip to your computer
2: Open the zip folder and copy the content by right clicking and copy
3: Insert the SD Card from the GPS unit into the computer.
4: Now open the card through my computer
5: Replace the DestinatorApps folder with the new one
4. Replace the SD card in the Enzer and there you have it!
Best of luck!
SOURCE: Garmin nuvi 260
Re: Not sayinstreet names.
After you turn on your unit touch the wrench icon in the bottom right of the screen, this will take you to a menu which features "Settings" in the upper left of the screen. Touch "settings" and scroll down to "language" by using the up and down buttons in the lower right of the screen (down 1 should do it). Touch "Language" and in the voice category find and select "American English - Jill (TTS)". This is the voice that will give you Text To Speech (TTS) speaking the street names in English. If you prefer Spanish or French, find the appropriate catergories with "(TTS)" beside them - "Espanol Americas - Paulina (TTS)" and "Francais Canadien - Julie (TTS)" respectively. Any other selection will only give directional instructions such as "turn left in XXX".
After you have selected your voice press "OK" and back out to your main menu showing "Where to?" and View Map".
Now, when you navigate, you should hear an American female voice giving you directions by street name - assuming your volume is high enough to hear it.
RE: The computer icon displaying when you try to use your unit in the car with the 12 VDC cord.
You probably have a problem with the cord. The pin length in the USB style connector is critical and if it doesn't match up just right the GPS thinks it is hooked up to a computer. If you know someone who has a Garmin NUVI try using their cord and see if you have the same problem. Either way, call Garmin and see if they will send you a replacement cord or otherwise help fix the problem.
SOURCE: Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
SOURCE: The preloaded SD card for my Evesham GPS is bad. I need a new one
You can buy software on Ebay for uk Maps. Its a CD.Just copy the software onto an SD Card.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150362945965&ssPageName=STRK:MESELX:IT
