Question about The Audio Players & Recorders
My YSP 2500 sound bar has a similar symptom to the YSP-1000, i.e. it won't power up. Does anyone know which is the appropriate capacitor to change or is it another fault.
  • 133 Answers
SOURCE: Black horizontal bars and jumpy picture.
Yes . Some of these caps are in the secondary of the power supply and some are on the signal board around 5v and 7v supply lines on the signal board . The 5 & 7 are mounted on heat sinks and the caps are right around there .Generally either 2.2uf or 4.7uf or the 47uf . Good luck
Posted on Mar 04, 2008
OnlyOneN
  • 86 Answers
SOURCE: Power Subwoofer doesn't work
Two possibilities:
1. Your source material does not contain bass frequencies.
2. Your SUBWOOFER SET - BASS OUT is set to Front, rather than SWFR (subwoofer). See page 63 of the manual.
https://www.yousendit.com/download/dVlvdFdaY3lJMHZIRGc9PQ
or
http://tinyurl.com/csw8sy
Let me know if that helps.
Posted on Apr 19, 2009
stwill2326
  • 77 Answers
SOURCE: connecting an iPod to Yamaha YSP-1000
The best way to get quality sound would be to go through the USB connection of the phone.
It will be hard and a bit costly to get a cable to link the Ipod and projector.
Easiet and economical way is to go to apple and purchase a cable for the jaudio jack at the top of the Ipod that will also have an audio jack connector for the projector
Posted on May 31, 2009
  • 9 Answers
SOURCE: ysp 1000 no power coming
C515 ON THE MAIN POWER PCB (HAS 223 K 630HI PRINTED ON IT) HAS FAILED
Replace with a 22nf capacitor - Maplin part number N38CN
the new maplin part has a higher voltage rating and is bigger. it will need to be fitted with the leads extended with wire to get it to fit.
Posted on Oct 01, 2010
moseleyboy3
SOURCE: LN S4051
Then your going to have to check them with a multi meter that can handle them. Find the bad one and replace.
Posted on Apr 02, 2012
What remote code should I use to control the YSP 2500 from a universal remote control?
Sound bars tend to use unique remotes, probably to prevent undesired interaction with other remotes.
Dec 11, 2015 | Yamaha YSP-2500 Sound Bar with Bluetooth...
Shaking during idle when warm.
try injector cleaner or newer fuel cleaners, try octane booster, sounds like a fuel delivery symptom but the temperature factor is a worry. I would guess injectors.
Jan 18, 2015 | Cars & Trucks
Ysp 1000 no power coming
Sep 18, 2010 | Yamaha YSP-1000 Main / Stereo Speaker
I get a loud static noise, when I first turn on the yamaha ysp-1. Lasts a few seconds. Have unplugged all inputs. Problem persists.
u have a cool sound projector but u have a baaaad power supply system. bad power supply design - u will get all sorts of noise when u power it up. i have a sub woofer with the same problem(which in my case is the way it is designed). i used a delay circuit. but in ur case i know YSP-1 has a clean start up. so, if the warranty still covers it get it replaced. static noises, pop noises are often caused by bad capacitors.
Mar 12, 2010 | Yamaha Digital Sound Projector Home...
Power became intermitentnow no power whatsoever changed the plug/fuse but no joy any suggestions
Replace with a 22nf capacitor - Maplin part number N38CN -
Jan 18, 2010 | Yamaha YSP-1100 Digital Sound Projector...
Suddenly the unit has failed - no power at all.
I have the same problem, fuse ok, plug ok and internal fuse ok. Sent it to reccomended engineer he said it cant bre fixed. only 3 year old, not happy
Sep 28, 2009 | Yamaha YSP-800 System
No power to the system checked all plugs and cables had been working for 2 years
I cannot know any specific answer but presuming that you have power at the wall socket (don't laugh sometimes it is that easy) a piece of electronics will not work because voltage is not getting to the circuitry inside. The most logical place to look is at the fuse but too often these days that is buried inside the unit and may be soldered on a printed circuit board. It is presumed that users will not fix anything and its certainly cheaper to solder one in than provide a fuse post externally . Clearly in such cases you must open the unit and check. If there is no fuse or the fuse is good it will require an electronic tech to trace the problem further.
Jul 03, 2009 | Yamaha YSP-900
Connecting an iPod to Yamaha YSP-1000
May 31, 2009 | Yamaha YSP-1000 Main / Stereo Speaker
DHR- 1000
Recently repaired one of these with what appeared to be a power supply problem; found several defective capacitors on the drive board. The symptoms were similar to what you are seeing.
Aug 20, 2007 | Sony DHR-1000 DVHS VCR
52 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
