Question about Whirlpool Washing Machines
Can you tell me the fault on my whirlpool AWOE9140 f27
3 Suggested Answers
  • 6277 Answers
SOURCE: I dont have user manual for Whirlpool AWOE9140
You can ignore the first paragraph- it's just me!!
(start rant) It still amazes me that new washing machines, other than those sold in the UK, seem not to have manuals placed inside the drum/tub! I think that purchasers should demand one from the vendor and threaten to go elsewhere if it doesn't supply the goods! (end rant)
Of course the manual could have been lost!
Now- unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Sep 19, 2011
richroth
  • 9472 Answers
SOURCE: f27 fault on bosch logixx 8
F27 is a problem with the pressure switch
Posted on Nov 05, 2012
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
F27 fault on bosch logixx 8
Nov 04, 2012 | Washing Machines
Hi i need to download instructions manuel for whirpool washing machine model number 859201315010 and number AWOE9140 searched everywhere on internet but no luck
Sorry, if you cannot find it there is little likelyhood of anyone on the forum being able to because we would only be doing the same thing for you ;-0(
Have you tried the manufacturer's web site direct?
John C.
Sep 15, 2011 | Whirlpool Washing Machines
Hi I have a Bosch Logixx 8 washing machine that
go to the manufactures website and download the user manual giving the model nr eric
Jan 19, 2018 | Bosch Logixx WAS2446 Front Load Washer
Water doesn't drain out. keeps getting 2 different errors F01 and F27. what does mean?
F1 is a pump drive failure and F27 is an overflow condition. Both point to a pump problem. Remove the front panel and unscrew the pump filter. Water will come out, so be prepared! If the pump filter is clean, you will likely need to replace the pump.
Kelly
Mar 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi i have a panasonic cs28 cassett units both have F27 01 fault codes. have checked power at indoor and outdoor units can i do anything else
f27- indoor outdoor unit disconnected.
Check power in output of indoor and input of outdoor, if power variation, replace wire.
Normally in this fault code, one of the wire burnt or rat bitten.
Dec 27, 2010 | Heating & Cooling
Error codes
F27 = OVERFLOW CONDITION
Did you inspect the filter for clogs I have seen this happen many times The filter is located behind front lower panel and can be white in color follow the hoses its before the pump. I have seen the filter clogged and give these type of symptoms
but here is error code F27 out of the maintenance manual
If the overflow contact on the pressure switch is closed for more than
60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump runs
constantly, even if PAUSE/CANCEL is pressed twice and the display is
cleared. Turn off hot and cold water faucets and unplug the unit before
servicing.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch,
water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
Nov 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Washer is flashing an error message. F27
Error code f27
OVERFLOW CONDITION
If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing.
Check
3. Check wire harness connections to the drain pump, pressure switch, water inlet value, and Central Control Unit (CCU).
Good luck
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal De
