Question about Hoover Washing Machines
Hoover DYN 8164 D2X washing machine. It has got 11 minutes to run on a programme, the machine has then frozen. The door is open. We have turned off the power to reset but the display remains the same.
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
  • 1768 Answers
SOURCE: Hoover washing machine - door won't open and drum
1. please provide the model number for the washer
2. this is a timer error code and it seems that it locked the door during the spin cycle.
There may be a malfunction sensor or you will need to unplug the washer to reset the washer to complete the cycle.
Something electronic has caused the washer to shut down to protect the electronic circuit. You may have a defective timer.
Posted on Mar 13, 2010
Testimonial: "Thanks for your help, it's working fine now :-) "
  • 174 Answers
SOURCE: aeg Lavamat 64840 programme stops at 1 minute.
The main PCB, before sending the door aperture signals, checks for the following conditions:
• The drum must be stationary (no signal from the tachymetric generator)
• The water level must not be higher than the lower edge of the door
• The temperature of the water must not be higher than 40º C.
Automatic release device
In the event of a power failure, or if the appliance is switched off using the ON/OFF switch, or if there is a
fault in the solenoid valve, the bi-metal PTC cools within a period of between 55 seconds and about 4
minutes (at a temperature of 65°C), thus releasing the door.
if after swiching off for longer than 5mins and the door lock does not unlock the lock must be faulty.
Posted on Jul 16, 2010
Macmarkus
  • 2605 Answers
SOURCE: My dishwasher won't switch off
Welcome to FixYa.
Based on your description
I'd say the issue actually is with the control...unfortunately. This is commonly associated with a heating fault on Bosch built dishwashers ( various models including Bosch, Thermador, Siemens, Gaggenau, and Neff ).
Since the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
These are the steps you'll need to follow to resolve it or at least investigate.
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...this can also manifest as a long cycle time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning, no heating ( don't be fooled by the homes inlet hot water temperature ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e. ( this may differ from your specific model, but the same rules apply )
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last.
Bosch recommend`s replacing the control and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Feb 26, 2011
  • 6277 Answers
SOURCE: my hoover dyn 8164d washing
Hoover's 'e03' states 'drain timeout'- probably a blocked filter or even jammed drain motor/pump.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 07, 2011
How do I cancel wash programme on hoover optima7kg iv put wrong wash programme on but I can't seem to cancel it
I would suggest that you turn the programmer to the stop position then leave it for a few minutes and then reprogram.
Oct 06, 2016 | Hoover Washing Machines
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Hoover vhd sensor dry 59 minute programme not working
"Rapid W&D 59 Min.
When you only have a few items to wash and dry in a hurry, this 59 minute cycle is the ideal time saver! Suitable for a light 1,5 kg load size (e.g. 4 shirts) or slightly dirty fabrics, this cycle will wash, rinse, spin and dry your garments in under an hour.
We recommend that you reduce the detergent dosage when using this programme to avoid wastage".
If the other cycles work without issue, it in not faulty.
Check the wash weight.
Sep 20, 2017 | Hoover Washing Machines
The functions has stoped but the door is not getting open.the model is hoover nextra.what i should do to get the door open?
switch off at the wall then manually drain the water using the (emergency drain outlet near bottom) if your model does not have one of these turn on and off at wall then set the wash programme to drain only this will be indicated in the manual of on the programme guide on the front panel.
Now your door should unlock once the water is drained.
Feb 28, 2011 | Hoover AL120 Front Load Washer
Hoover washer/dryer VHW854D SHOWS ERROR CODE E11. Machine switched off and door opened. Wash cycle had not started. Door closed and machine switched on and all works OK. Any ideas?
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Dec 20, 2010 | Washing Machines
The washer programme has frozen and stuck on a cycle. how do i reset programme?
try unplugging the machine for 10 minutes,plug it back in and see if it will reset,if not you could have a button stuck inor a bad touch panel,send the model number next time located around the door opening.
Nov 28, 2010 | Hotpoint Ultima WF860 Front Load Washer
Front loading Haier HW-D1470TVE Door will not open. This inspite of the wash programme having ran and the digital dispkay reads "end". What can I do?
Sounds like your door is locked. Unplug the unit for 30 minutes then plug it back it hopefully it will reset everything and you will be able to open the door. Then after you get the door open you will need to run some tests to see what is the problem. Check the door lock sensor and the door lock mechanism
Feb 19, 2009 | Haier XQG50-11 Front Load Washer / Dryer
Washing Machines Logo
97 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
