Question about Cameras
How do I enter new password into my camera recorder
  • Cameras Master
  • 4,015 Answers
Without more information we cannot help you.
Posted on Apr 30, 2017
How to reset password CCTV DVR Telview PD801 ???
It's a matter of going to the default IP address of the DNS server for the camera.usually found on the box or name tag of camera.otherwise google make and model...it should start with192.168.0.1 or 192.168.1.1 then enter default user passwords to gain access to reset camera.if you have a reset port on the device try pressing it in with a paper clip for 5 - 10 seconds this with factory reset the device but probably clear a
l recordings.if you need the recordings remove hard drive and piggyback onto another computer.
Mar 25, 2015 | Home Security
Screen wont show cameras or record
Are you pressing menu button on the monitor or the DVR?
Your problem may not be the cameras, but between the DVR and the monitor. Found this on page Eng-19 of the user manual which I found on Samsung.com
This monitor was set to password lock when you purchase a new set. Therefore, you must first enter a 4 digit password to activate the On Screen Display... the default password is 4321. Not sure if that helps.
Dec 17, 2013 | Samsung SMT-190DN 8-Channel Security...
Describe how to reset a password on q-see system
To reset password. Enter ttvvtthuanyuan at the login screen.
The password will be back to default password 123456
Feb 06, 2011 | Digital Peripheral Solutions New Q-See...
Password Error
To reset the password:
Turn unit on and wait for password prompt
Depress the and hold the enter button until camera
switches into 5-digit password mode _ _ _ _ _.
Trail sentry systems will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
Press enter to confirm 5 digit mode
Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th digit is entered in the _ _ _ _ screen.
Camera will now go into operating mode, and user can now program a new password from the setup mode
Mar 18, 2010 | Bushnell Trail Sentry 11-9200 Digital...
How do oyu activate voicmail on the T7316E?
Press "Feature 9 8 1" to open the mailbox.
The system will prompt you for the password - enter the default password "0 0 0 0". The system will prompt you to change the password - it must be between 4 and 8 digits, and cannot start with zero. You may have to enter your new password a second time.
Next the system will prompt you to record your name for the company directory (ie: "John Smith at extension 23"). You have the options to listen to your recording, retry, and accept it.
This will bring you to the mailbox main menu, where you will see how many new and saved messages you have. Finally, you can record a mailbox greeting. Press "ADMIN", "GREET", "RECORD", "PRIME". Here you can record your primary greeting. Press release or hang-up when you are done.
Hope this helps!
Nov 16, 2009 | NorStar T7316E Corded Phone
Decode to reprogram new pass word
Try this:
Trail Scout and Trail Sentry camera re-programming procedure.
1) Turn unit on and wait for screen to prompt password
2) Press the enter button and hold until camera switches into 5-digit password mode _ _ _ _ _.
Trail sentry cameras will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
3) Press enter to confirm 5 digit mode (for trail scouts go to next procedure).
4) Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th 0ne is entered in the _ _ _ _ screen.
5) Camera will now go into operating mode, and user can now program a new password from the setup mode
Sep 30, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Initialising Mailbox
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
To Change the "Recorded" Name for the Company Directory:
1. Have the Voicemail User log into their mailbox, after putting in their password, press the button under "Admin" (or press the number 8 key., and then press the number 1 key.
2. You will hear the old recorded name and then the system will "beep", prompting you to record a new name (name only here, not greeting..
3. Press "Ok" in the window when you are done recording and then "Ok" again to accept the recording
Apr 23, 2008 | NorStar M7310 Corded Phone
Reading multi zone DVD's
If you forget your 4-digit code
If you forget your password, to clear the current
password, follow the procedure below.
1. Display Setup menu then select an 1 level icon.
2. Use the Number buttons to enter the 6-digit
number “210499”.
3. Select [Yes] then press ENTER. The 4-digit
password is cleared. Enter a new code.
Mar 10, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Bushnell Trail Sentry Digital Trail Camera
Dec 27, 2007 | Cameras
How to stop recording,without killing the power?
My record lock is turn off, but every time I press the record stop to stop record it takes me to the password screen where I must enter a password before I can stop the recording....This piece of xxxxx is stink. I hate my Samsung SHR-1040...I cant even talk to Samsung about it.....When I call, they transfer me to India and they dont even know what a DVR is......I told them DVR 10 times, but they keep repeating to me " VCR"
Nov 02, 2007 | Samsung 4 Channel Dvr
Cameras Logo
35 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
