Question about JVC Office Equipment & Supplies
I have a JVC DLA X3-BE I replaced the lamp but still the orange light blinking
, i tried to reset it from the menu bottom at the back of the projector but still bilking and now changed to the left red light and middle pink light blinking and still projector not working. hardle use it but i have it for 5 years the cover lamp was open and still open but i took it off to close it but didn't make any diferent at all , the light still blinking
Gigatech
  • 259 Answers
SOURCE: Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Posted on Feb 27, 2008
SOURCE: PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
Posted on May 27, 2008
SOURCE: Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Posted on Jun 23, 2008
busgeek79
  • 36 Answers
SOURCE: Lamp cover light flashes even with new lamp
Look closely by the cover there is a small sensor there, could be a pice of dirt and door not completely closing get a cleanpaint brush or little brush and clean area..Good Luck
Posted on Jun 30, 2008
SOURCE: cleaning the filter/blinking LAMP and TEMP
Goto Advanced menu and select option then lamp Time hold down the reset button on the unit for 3 seconds until a new screen comes up then hit reset. Do the same for resetting the filter time
Posted on Apr 27, 2009
I have JVC D-ILA projector and we just had thunderstorm and now it won't come back on
I had the same trouble with telephone answering machines - every thunderstorm and I would need a new one...
Lightning strikes and near misses and power outages can create mains borne voltage spikes and surges that frequently damage sensitive electronics. These days almost everything is a computer or contains a computer that uses extremely sensitive CMOS chips.
Electronics manufacturers don't make things better than they need to be for obvious reasons and so it is up to the user to protect appliances from damaging surges by using the most expensive of these with a surge protector and by using an area protector.
Since the penny dropped and I invested in a surge protector I haven't needed to replace my answering machine...
Aug 26, 2016 | JVC DLA-RS4800U Projector DLA-RS4800U
Warning and standby indicator of JVC D-ILA Projector model DLA-X70RBE flashing simultaneously.
Johan, Below are links to your model where you can access,manual,instructions and get support.
Press the helpful button and follow me on fixya for more tips and info.
4K shift ILA Projector DLA X70R Introduction
Replacing lamp on JVC Series Projectors
JVC DLA X3 Warning light issues
Feb 11, 2016 | JVC Televison & Video
My JVC DLA-X3-BU will not power on, 2 lights are red, lamp light is flashing orange, how do i get it to work?
I have a JVC DLA-X9-B projector which I think is the almost the same as the X7 and X3 the manual is the same.Its about 2 years old.It stopped working suddenly while I was watching a movie. Indicator lights were both on red and lamp light flashing orange. Replaced the lamp and it did not change the status,did cleaning filter bit , did lamp reset from the remote , did reboot and plugged it at a different ac outlet all that did not work . The lens cover is stuck at opened and the only thing you get when plugged in is the red light on and after 30 seconds the lamp light comes on orange .No fan came on no moving lens cover only flashing orange light.
From this conclusion was the power supply was working and software was a question mark either it was corrupt ,but the power cycle and lamp test start was normal and it checked the lamp and reported orange .So all the more it pointed to either the ballast or the power feeding the ballast.
I opened the projector up started with the screws at the bottom removed the the adjustable screw in legs. Removed the left and the right plastic cover ,then bottom cover, lamp cover, top cover plastic and then top metal plate cover, back cover until parts were all visible ,then put back the screw in legs a placed projector in an upright position. All this was in suspect that the ballast is the problem.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-6.jpgThis is the top view photo.
On the right black plastic cover is the lamp fan and air duct.
At the center is the lens assembly and motors for focus lens shift etc.
on the left are stacks of electronics that are stacked board on board of about 4 or 5 layers.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-11.jpgthis is the side view of the stacks of boards, to get to the ballast these have to be removed.NOTE LABLE ALL CABLES AFTER REMOVING THEM AS THERE ARE MANY OF THEM.Remove the side plate
Remove hdmi and land board,carefully there are connectors on bottom and all sides of this board.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-27.jpg jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-38.jpgthen remove the next board ,remember to lable all the cables.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-51.jpgthen the next board bellow ,carefull this one has 2 side connectors on pictures top side
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-66.jpgthis will be what it looks like.Note the bottom most is the power supply.,This feeds the ballast as well as other low voltage Dc components.THE CONNECTOR WITH THE WHITE END AND BLACK AND RED CABELS IS THE BALLAST FEED(picture above) .The ballast is located in a black plastic box above the power supply.The only way to remove it is to continue dismantling further. jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-83.jpgthis is the top view and the yellow tags you are seeing is cable labelson the wires.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-102.jpgthis picture is with all boards removed to check for physical burn outs on components
mainly on power supply ballast feed and ballast itself.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-123.jpgall boards out
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-146.jpgthis is the power supply board it has both low and high voltage output .Low for logic boards high output for ballast.Ballast feed from power supply should put out about 380 volts dc during projector boot up and zero during orange blinking light,(you can skip this removal of power supply if you read the 380 volts output on multimeter at boot up.Do this before taking all the boards apart but remove the side plate to access the output and check the output at boot up ,warning do not short this while reading output.
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-171.jpgpower board made by sumida and so is the ballast
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-198.jpgfinally the ballast is out this is what it looks like,do you see the dark grey wires they lead to the optocouplers (little led light sensing switch looks like a square little box all 3 are side by side)
jvc-dla-x3-bu-will-not-power-2-lights-zogl1yh0b34d0jvl0ocjipaz-3-227.jpg this resistor came out of the ballast ,notice physical damage like a hole in the center of it,tested it out of the board and yes its dead replaced this.
.Did all the checking one by one of the components then found one of the optocouplers had gone dead.The one located in the center of the 3 replaced that ,put it all back and got it working again.
The ballast cost 300 usd I bought one too and kept it handy just incase.
But for the meanwhile the old one is back and working just fine.
Aug 07, 2014 | JVC DLA-X3 Procision Projector
Jvc x3 projector orange lamp light flashes wont power up
1,Check the fans ,if the fan is running
2,Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Nov 02, 2013 | JVC Dla X3 3d Projector
Jvc dlax30bu
when i plug in power x30 jvc dila is red light on and lamp light on and the waning light r 6 time flash again and again
Feb 25, 2013 | JVC "DLA-X30 D-ILA 3D Projector"
I have a Epson lcd projector mp-x3 the lamp light is blinking so I replaced the lamp and the lamp light is still blinking and there is no light do I need to reset the lamp if so How do I do thatMukrray
Connect the power cable, power on the projector and then press the [Menu] button on the remote control. The configuration menu will be displayed.
Select Reset Lamp Timer from the About menu, and then either press the [Enter] button on the remote control or the [Auto/Enter] button on the projector's control panel.
Select Yes, and then press either the [Enter] button on the remote control or the [Auto/Enter] button on the projector's control panel.
The lamp operating time will then be reset.
Aug 11, 2011 | Epson EMP-X3 LCD Projector
Reset timer on jvc dla g150c projectorlamp
1 Turn on the MAIN POWER switch to go
into stand-by mode.
In stand-by mode, the STAND BY indicator on the
projector lights up.
2 Press the following buttons on the
projector, sequentially.
1 Momentary press the PC button.
2 Momentary press the ENTER button.
3 Momentary press the EXIT button.
4 Press and hold the HIDE button for two seconds
or more.
* During this sequence, the STAND BY and OPERATE
indicators alternately blink about every approx. 3 seconds.
After completion of the sequence, the STAND BY indicator
alone stays on.
* Buttons must be pressed within 2 seconds of the previous
button.
* When you make a mistake in button operations, return to
the beginning of the sequence.
* To check the lamp time on the menu, press the MENU button
and select “Information” with the cursor button 5 or ∞.
The lamp use time is indicated in the item “Lamp time”.
Sep 30, 2009 | JVC DLA-G150CL Multimedia Projector
JVC PROJECTOR TV 61INCH
try to checked the memory program I.C. located near the controler I.C. or it maybe put you on timer mode, try to go menu and checked the settings
Jul 30, 2009 | JVC AV-27020 TV
173 people viewed this question
Top JVC Office Equipment & Supplies Experts
MusicMania
Level 1 Expert
Piyal Perera
Piyal Perera
jasbo
jasbo
Are you a JVC Office Equipment and Supply Expert? Answer questions, earn points and help others
