Question about GPS
I updated my new Start52 before setting off to Southampton docks On returning , just outside the docks my satnav told me to turn right on two occasions where the road signs showed no right turn. Why?
3 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: The camera won't turn on. But in its dock I can
Yeah one would assume battery in this unit is not working like it should and may need replacment, or your flash capacitor inside is not filling with charge to power unit off the dock. Ether way here your going to need to have this fixed.
You need to find a camera shop local or send it back to casio for repairs ether way.
Thanks and I hope this does help you today, please be considerate and leave a positve feedback statment and ratings for your free soluton today.
Posted on Jul 01, 2010
emissionwiz
  • 79865 Answers
SOURCE: I have a ALPINE 099 series dvd/satnav in my car. I need to update the route info as many new roads are not featured. Where can I buy the latest disc/
Only from Alpine, but there is no guarantee they have released any disk.
Posted on Apr 11, 2012
How to update my satnav on my new Suzuki swift?
Most manufactures will refer you to the maker of your system (even when the lying salesman told you it would be free). There should be info in your owner's manual about the nav system. The update will cost you plenty.
Jul 05, 2016 | Suzuki Swift Cars & Trucks
Tip
How to remove a forgotten PIN from Garmin Nuvi satnav
Nearly every day there's a question asked by Garmin Nuvi satnav owners as to how to change or remove their PIN which they have forgotten. Ideally you should use a PIN that you will never forget or save it somewhere you can get access to it again if you do forget it. However we all make mistakes and so a lot of users end up on this website looking for a solution.
1.
When you set your PIN you get an option to set a Security Location. When you set this your satnav must have satellite reception. When you forget your PIN you go to your Security Location and the satnav will start up without you having to enter the PIN, provided you have a satellite connection. As you cannot see the signal strength bar until you get past the PIN entry screen you won't know if it has accessed satellites or not so you need to give it a while. Also as GPS is not one hundred percent accurate you may need to move around five to ten metres in a gradually widening circle from the security location. This gives you a better chance of getting the exact spot. If all is well your satnav should open but the PIN is still set. To remove the PIN when you get your satnav started
  • Press TOOLS
  • Then press SETTINGS (or LOCALE on some models which don't have the SETTINGS icon)
  • Press SECURITY
  • Press GARMIN LOCK ON
  • Press OFF
  • Press OK
Your PIN is now removed. If you want to set a new PIN
  • Press TOOLS
  • Then press SETTINGS (or LOCALE on models that don't have a settings icon)
  • Press SECURITY
  • Press GARMIN LOCK OFF
  • Press ON
  • Enter your new PIN
  • Press OK
You then get the option to set a new security location. Again be sure you have a satellite connection.
2. If you have forgotten your PIN but either have not set a security location or forget where it is the only option is to return it to Garmin to get it removed. You must send proof of ownership along with the satnav if you're returning it as the PIN is there to protect satnav owners from thieves. If you need to return the satnav to Garmin you can get their contact details at http://www.garmin.com/garmin/cms/site/us/support/supportcontact
on Oct 01, 2010 | GPS
Tip
No Detailed Maps Found That Support Routing
A lot of people have looked for solutions to the message "No detailed maps that support routing" which can appear on Garmin Nuvi satnavs.
This solution can also be used when the message doesn't appear but no maps are loaded. When no maps are loaded try the instructions in paragraph 5 below Selecting Maps on your Garmin Satnav
If that doesn't solve your problem the maps may be locked. In this case return to paragraph 2 below and follow the instructions to the end
(This solution is for both PC and MAC users. Follow the instructions only for whichever you use).
The "No Detailed Maps Found That Support Routing" message may appear on your Garmin nuvi satnav for the following reasons:
  • The Satnav is missing it's unlock code
  • The maps on the Satnav have been disabled
1. To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to Paragraph 5. below Selecting Maps on your Garmin Satnav
2. To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it, connect the satnav to your computer and go to www.garmin.com. Select your country from the dropdown list and click "Register your garmin device". Follow the prompts. You'll be asked to create a username and password. Keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
3. Retrieving your unlock codes:
  • Log into your myGarmin account
  • Select Manage Maps
  • Select Details
  • The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  • Plug your Garmin device into the USB port
  • Double-Click on My Computer or Computer located on the desktop
  • Right-Click on the Garmin or nuvi drive
  • Click Explore
  • Double-Click on the Garmin folder
  • Right-Click in a blank space in this window
  • Move your mouse over the word New
  • Select Text Document
  • Press Enter / Return on your keyboard
  • Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  • Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  • Select File
  • Select Save As
  • Change the Save As Type to All Files
  • Type gmapprom.unl in all lower-case letters for the File name
  • Select Save
  • Close the Notepad window
  • Delete the New Text Document file
  • Disconnect the Satnav from your computer
Creating an unlock code file for Mac:
  • Open the TextEdit application located in the Applications folder on the Mac HD
  • Click Format
  • Select Make Plain Text
  • Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  • Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  • Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
4. If you have a second maps you may also need to unlock it e.g. if the first map is USA and second is EUROPE this may also need to be unlocked
  • Click Explore
  • Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  • Select File
  • Select Save As
  • Type gmapprom1.unl in all lower-case letters for the File name
  • Select Save
5. Selecting maps on your Garmin Satnav:
  • Touch the wrench icon on the Where to/View map screen
  • Touch Settings (or Locale on some models)
  • Touch Map
  • Touch Map Info
  • Press the checkbox next to the maps to be selected on the satnav
    A tick will appear in the box. The map is now selected.
on Sep 28, 2010 | GPS
I purchased 3 nuvi 780 models about a year ago. One for me and one each for my children. Not long after we started using them the sound quit on 2 of them. Neither the FM or internal speaker will work on...
The most common cause of this problem is that the voice files become corrupted and need to be replaced. To replace them:
  • Download and install WEBUPDATER to your computer from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
  • Connect your satnav to your computer with the mini USB lead and run the WEBUPDATER program.
    Webupdater will find any updates to your software that are available. Select all and install them to your satnav. When the update is complete it will then find optional updates including VOICES. Select a few of the English speaking voices and they will be downloaded to your satnav. After the download is completed SAFELY disconnect your satnav from your computer and restart it.
  • Press TOOLS
  • Press SETTINGS
  • Press LANGUAGE
    This brings you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD
  • Press VOICE and select one of the English speaking voices you downloaded.
I hope this solves your problem.
Jun 22, 2011 | Garmin nuvi 780 GPS
All of a sudden my Garmin Nuvi 850 won't say street names, just turn left or right
It may have switched voices. Some of the voices are basic and do not say the street names.
  • Press TOOLS (The spanner icon in the bottom right corner of the screen which shows WHERE TO and VIEW MAP)
  • Pres SETTINGS
  • Press LANGUAGE
  • Press VOICE and select an English speaking voice that ends with the letters TTS (TTS stands for text to speech)
If you don't have one on your satnav you can download them. Download and install, to your computer, the latest version of WEBUPDATER from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Connect your satnav to your computer and run the WEBUPDATER program
It will search for updates and you should install any it finds. Afterwards it will find optional updates including voices. Tick the ones you want and download them to your satnav. When you have disconnected your satnav from your computer you'll need to select a voice as described in the first paragraph above
Jun 17, 2011 | GPS
How do you download latest maps for free as i have been told it is possible ? Thanks...
It's only free to download the latest maps if a new map comes out within 60 days of your satnav first accessing satellites or if you have a satnav that comes with lifetime maps. However you can buy lifetime maps. The lifetime map of Europe costs €85 and you get updates every 4 months or so for the lifetime of the satnav.
Jun 15, 2011 | Garmin nuvi 250W GPS Receiver
I recently purchased a Garmin nuvi(r) 1310(T) from Halfords in Manchester and was advised to get a "free" update after registering my unit, as it could be 1-2 years old. On checking there were no "free"...
If a new map becomes available within 60 days of the satnav first receiving a satellite signal you get it free. If you only got the satnav there may not be an update at the moment. While the satnav may have been a while in the shop Halfords keep the maps up to date. Even if there was not a free update available myMaps in myGarmin should show if there's an update which could be paid for available. If it says no update available you probably have the latest version. A new map normally comes out in November though the dates vary. Keep a check by logging into myGarmin and checking on myMaps. When the new map becomes available it should show up there. It will let you know if it's free or not.
If you want to check what year the map on your satnav is:
Press TOOLS (the spanner symbol)
Press SETTINGS (or LOCALE if your satnav doesn't have a settings icon)
Press MAPS
Press MAP INFO at the bottom of the map page
This will show what map you have and the year of the map. If your map is the latest version it would explain why there's no updates
Oct 22, 2010 | Garmin GPS
I have purchased nuvi2020520serial20number20upgrade. I was told by **** Smiths salesman, that i was able to up-grade this nuvi 205 series inside the 60 days after this purchase! Please advise ...
If a new map comes out within 60 days of the first time your satnav accesses satellites garmin give it to you free. To get your update you must register your satnav with garmin. To register:
Connect your satnav to your computer and go to www.garmin.com
Select your country from the drop-down list. Click on "myGarmin" and then on "Register your garmin product" Follow the prompts. You'll be asked to create a username and password. Keep them safe as you'll need them anytime you want to update maps.
To check if there's an update available log into myGarmin and click on myMaps.
Your map will be shown there and if there's an update available it will be shown beside it. To get the map click on Get Update and follow the prompts.
Sep 27, 2010 | GPS
VOICE turn by turn has quit working. How do I restore voice.
Check that the mute box is not ticked.
1. Press Tools, Settings, Language and then press Voice. Select a new voice.
2. If that doesn't solve the problem it may be that the voice file has become corrupted. Connect the satnav to your computer. Download and install webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 When it's installed it will look for updates to your satnav software. After this it will give you the option to download voices. Select the ones you want and click next. The voice files will be downloaded to your satnav.
When you've disconnected the satnav from your computer select the voice you want as described in paragraph 1 above.
Aug 13, 2010 | Garmin nuvi 750 GPS Receiver
1390t stopped saying street names and only says distance before turn
Some voices on the satnav don't support street names. It's likely that the voice which used to has become unselected or corrupted.
1. Press Tools, then Settings, then Language and you will see a setting for Voice. Press Voice and change to a different one. If there's not another voice there or the other voice file is corrupted you can download more.
2. Connect your satnav to your computer. Download and install webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and your satnav will look for updates. When it has finished it will give you an option to download voices. Tick the ones you want and click next. When they have been downloaded to your satnav and you have disconnected your satnav from your computer select a new voice as described in paragraph 1 above.
Aug 13, 2010 | Garmin nuvi 1390T Car GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
