Question about The Computers & Internet
Credit card machine screen broke and I need to close batch
I have the FD130 credit card machine. One of my associates dropped it and the screen broke, now I can't close batch
  • 5 Answers
SOURCE: nurit 2085
Press: Batch then select Host. When you see Close Batch, scroll down to Force Totals and press Enter
Posted on Jul 31, 2009
  • 3 Answers
SOURCE: My Wireless vx670 verifone credit card machine is
Depending if your terminal is on the IDLE PROMPT SCREEN or the VMAC SCREEN... you would select SETTLE on your terminal. If there is a password it should 1 alpha alpha 66831 (default pwd by Verifone). Then proceed with confirming the totals on the screen by pressing the GREEN "Enter" KEY
Posted on Apr 29, 2010
SOURCE: my credit card machines show
There was a miscommunication between your terminal and your processor. You need to call them to verify batch totals and possibly update some info inside the terminal.
Posted on Mar 25, 2011
  • 10 Answers
SOURCE: Our Verifone VX510 printed our
This problem could have multiple causes. It sounds like you are receiving a settlement error, which are specific to each merchant services provider. You will have to call the merchant services provider so that they can look up the error message on their end and tell you what is causing the error. For example, the error message that you would receive if you use First Data would be different than the message you would get if you used Bank of America. Your terminal will not let you run any more cards until you resolve the settlement error. This is to prevent you from continuing to run cards in a corrupted batch, or a duplicate batch.
Posted on Jul 29, 2011
  • 5 Answers
SOURCE: credit card machine
'Retry Batch Trans' indicates the terminal settlement was unsuccessful. Hypercom terminals require settlement errors be corrected before allowing processing of new transactions.
Attempt the batch and take the necessary action based on the response of the batch attempt.
Posted on May 29, 2013
What does must settle TSYS MEAN WONT TAKE CARD
This means that the batch file needs to be settled before more transactions can be made. Do a batch download and this should solve your problem. If you need more help call. Frank (775)338-6634
Sep 19, 2014 | VeriFone VX510
How to fix settle error RB-000-E0001H18000 on a hypercom t7plus
that error RB: means repeat batch / the batch was already sent and needs to be cleared out of the machine. TSYS also needs to clear it on there end too.
Sep 03, 2014 | Hypercom T7Plus Credit Card Machine
Why batch error RB-000-E0001H18000
That error RB: means repeat batch / the batch was already sent and needs to be cleared out of the machine. TSYS also needs to clear it on there end ...
Credit card machine
May 29, 2013 | Computers & Internet
How can I get the detail report print out with the settlement report when the batch closes?
Hi,after close the batch then all information flashed in your pos device so your are unable to reprint it.
psoftware109@gmail.com
Feb 28, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
My Wireless vx670 verifone credit card machine is not batching out how do i manually batch out?
Apr 03, 2010 | VeriFone TRANZ 380 Transaction System (X2,...
Proccessed incorrect amount on credit card
If you catch the error right after you run it, do a void rather than a credit. A credit could takes weeks to show up for a customer and they won't be happy with you.
Mar 29, 2010 | VeriFone OMNI 3200 (P092-101-10) Printer
How can i use credit card mashine
Following are the steps to use credit card machine
step1:Input the credit card numbers.If you have the credit card in hand, swipe it through the card reader. Most readers have a small icon or picture on them that shows which way the magnetic strip on the back of the card should be facing. If not, try running it
through the reader with the strip facing the machine first, since that is the most common direction. If you have a phone order, or do not have the credit card in hand, select the button marked "sale." On many machines this is also the "1" key, but it varies depending on the brand of the machine. Then follow the on-screen prompts to enter the card number and expiration date. Always double-check the numbers before pushing enter
step 2:
Input the sale information.Typically, the machine will first ask for the sales amount in dollars and cents. Input the amount using the number keypad. Double-check the amount to make sure it appears correctly on the screen and if it does, then push enter. If you accidentally input the wrong amount, look for the "clear" or "delete" key and start over. In some cases, the machine will prompt you for additional information after you've entered the sale amount. Follow the prompts to enter information, such as the customer's zip code or an order number.
step 3:
Wait for the sale to process. Depending on the machine's connection the sale may process within seconds or it may take a few minutes. If the machine seems to become "stuck" while processing a sale, do not re-enter the sale, but instead call the processing company's phone number for further instructions. In many cases this number will appear on a sticker on the machine.
step 4:
Process the receipt.If the customer is present, have them sign the credit card receipt. Give them the copy and retain the original for your records. If the customer is not present, write "phone-in" or another appropriate phrase on the signature line of the receipt. Keep one receipt for your records and include the other in the shipment of the goods to the customer.
step 5:
Close the batch.Double-check with your processing company, but most require you to run a "batch report" or close a batch of credit card receipts each day. This is the process that tells the company to finalize the credit card charges and deposit the balance to your account. Many machines will have a key that is marked "batch." You can press this key and then follow the prompts to close the batch at the end of the day. If the machine does not have a "batch" key, consult the user's manual for instructions or call your credit card processing company for instructions.
Thank you
Mar 14, 2010 | IBM Domino.Merchant Server Pack Upgrade...
Restraunt credit card machine
contact your processing company
phone# is on your statement
Aug 31, 2008 | VeriFone Omni 3700
Nurit 2085
This is most likely cause by a crupt transaction or a transaction that is not aloud stuck inside the terminal. Once you batch out contact your processing comapnyask them if they see you current batch you jut settled. If so they will need to clear the the terminal and up the batch number. Just make sure all of your sale are settled with your processign comapny before you go ahead and clear the terminal.
May 14, 2008 | VeriFone (M19755014US1) Magnetic Card...
Computers & Internet Logo
57 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
