We have an Airwell conditioner number XLM24RCB and we are unable to successfully change from cooling mode to heating mode using the prompts in the manuel . Can you advise us what to do ?
3 Suggested Answers
  • 257 Answers
SOURCE: please advise heating/cooling capacity for carrier
Hello rgar919,
It is imposible to tell you the capacity of the unit without some kind of numbers to find out what it is. They made more than one unit 25 years ago. The numbers off the compressor may help to find the size of the unit. Please try and find some sort of model or serial number, compressor number, fan motor number something that can be cross referenced.
Thank you for choosing FixYa.
Posted on Mar 06, 2011
  • 2133 Answers
SOURCE: my carrier air conditioner / heat pump is
Check your thermostat setting. It must be minimum 4 degrees difference from room temp.
Posted on Oct 27, 2011
I have a airwell GC-30RCC when put on heat the fan on the indoor unit wont kick in it works fine on cooling and plain fan mode but not on heat mode the red fan light is on too
How do you get it to kick in ?.Fid you spin it by hand ,if that's what you did and fan runs then you have a bad capicator. If fan runs fine in cooling and not in heat then you have a bad board
Jun 01, 2017 | Heating & Cooling
Air conditioner that won't heat. It turns,louvre goes to vertical, it beeps, the fan comes on for a while then goes off and does nothing then although left for 1 hour? any suggestions
If it works in cooling than most likely you have a bad control board in the condenser. It's possible the reversing valve is bad also. You need a professional.
Apr 01, 2017 | Heating & Cooling
How to change from cold to heat
Check your remote control. press mode from fan, cool, heat and check if the heat mode indic
Jul 01, 2014 | Hitachi Heating & Cooling
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
I got an Airwell ducted air conditioner unit with 4 outlet model: GC24RCC-S and Remove controller 4 and PCB unit is Storm 2. When turned on, the green operation led of the display controller unit is...
Check the unit that's located outside .You need to open it to get to the control board ,there you will see a couple of buss fuses. Check to see if fuses are fine. Do this with the power OFF on disconnect
May 19, 2017 | Heating & Cooling
Box on the wall. Push buttons
mode will be heat, cool, or automatic. cool will show a snow flake flashing. Heat will show a flame and auto will switch from heat or cool by itself. Usually the auto feature does not work well as one is unable to set the heat and air where they are comfortable on both
Jul 27, 2010 | Carrier 38CKC036 Air Conditioner
We have just purchased a universal remote for our ducted airwell air con - we need a code for it and airwell isnt listed on the remote
I am sorry if ask wha may seem like a few silly questions, but I need some clarification to assist you better.
-Is this a Residential AC Unit?
-If it is a residential AC unit, where is the thermostat located for this unit?
-Do you know if there is a wall mounted thermistor located on the wall in another room or in the room it cools?
I ask these questions, because generally if the fan coil is mounted in the ductwork, then there isn't always a way of controlling it remotely. Generally, it's controlled by hard-wired thermostat.
If you know it was controlled remotely, then you will need to go the website for the Airwell Fan coil and do a search on programming the remote. I'm sorry there is no short cut for this, you will need to obtain the code from Airwell.
Hope this helped... :D
Jun 27, 2010 | Heating & Cooling
Heat pump is in heat mode 4 hrs. in to the
Hi, this is your programmable thermostat not being programmed right. If you have the manual, set your times and temperatures for both heating and cooling to cool or heat at the times you want it to. I am not sure where you are, and if you want to use just heat or cool, but you can set it to run on just one or the other, or to auto change over. Just be sure to run it in the auto mode. I can't tell you how to over the net as there are so many models of thermostats, but if no manual, you may be able to get one by getting the model number off your stat and name, go to a place that sells that stat and they can tell or show you how to set it up. I hope this has been of help to you. Let me know please.
Dec 23, 2009 | Ruud Handle Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
