Question about Cell Phones
SkyPatrol sp8801 will not charge. why? Just bought a new charger from the company and it still will not charge. It is only 5 months old.
  • 17 Answers
SOURCE: roomba 4108 does not charge
Try resetting your Roomba by removing the battery, unplug the charging connector, hold down the Power button for 30 seconds. This will reset the charging system, replace your battery, connect your charger and see what happens. By the way do you also have a homebase ? If so try that too
Posted on Jan 10, 2009
  • 60 Answers
SOURCE: old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Posted on Mar 11, 2009
fwadley
  • 482 Answers
SOURCE: BATTERY UNABLE TO CHARGE
shorting out battery
Posted on Apr 17, 2009
GrinningFool
  • 625 Answers
SOURCE: Samsung D900i
It is probably the charging port. It seems to be a common issue with this model of phone.
If it is the charger port on th eD900, You have 3 options.
1. get it repaired, under warranty if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay
For more information and links to the parts check the following link below.
Samsung SGH-D900 will not charge problem
Posted on Aug 18, 2009
My ZTE 998 will not charge dispite changing the battery out. what to do now
a bad charger get a new charger make sure you have selected correct charger ect.
Aug 19, 2014 | ZTE Cell Phones
My battery does not hold the charge, i will charge it for 24/hour and it only last 5 minute, why is that, iI buy this product for wife when went to Iraq, and when i talked ton her on the phone three months...
NiCad batteries have this problem when they are recharged frequently after being only partially discharged. This is also the case when the batteries are left in the charger continuously - even if the charger is described as being "automatic". I have old 12v batteries that I have been using for 20 years, but I only charge them for a few hours, and only when they have run down enough to be useless. I prevent leaving them too long in the charger by using a timer that cuts the power to the charger after a couple of hours. A couple of years ago I bought new drills and chargers, and believed that the chargers would be automatic and so could be left plugged in. Those batteries only lasted a couple of years, while the old ones are still going strong. I now use the timer for any of these chargers, automatic or not - but I had to buy new batteries first. good luck, Al K
Jul 29, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Camera only takes 5 photos before dying
This new battery, if it is the exact type of battery recommended by the manufacturer then it is most likely not the battery. if you bought a similar battery it might be for even the minimum difference makes all the difference with digital cameras. for camera repair this company does a good job and you can even select your problem on their online quote. www.teleplancamerarepair.com
Jul 08, 2010 | Canon PowerShot S500 IXUS 500 Digital...
My nokia 6300 mobile charger not support pls help
If your phone was bought in the last 6 months you can go to nokia care center and demand for a new battery for free provided you have the warranty card.
Did u try another charger of the same mobile company,if yes ,and it works ,the problem is with your charger.You can either buy a new charger or get an all battery charger ,a china piece that recharges all batteries of any mobile company.You can get it below 2$ .
If your battery doesn't charge even with other charger of the same company then the problem is with your battery.If you are a nokia user ,here is the price list of all nokia batteries.
http://www.priceindia.in/mobile-phone/nokia-battery/
Feb 16, 2010 | Nokia 6300 Cellular Phone
Hai i have nokia 6300 mobile when i charge my mobile i say charger not support what can i do for that porblem
Feb 06, 2010 | Nokia 6300 Cellular Phone
Please help
Oct 01, 2009 | Nokia 1600 Cellular Phone
Problem with charging nokia 5800
If your phone was bought in the last 6 months you can go to nokia care center and demand for a new battery and charger or repair the existing ones provided you have the warranty card.You should get it done for free of cost.If 6 months exceeded then
Sep 17, 2009 | Nokia 5800 XpressMusic Smartphone
The batteries does not hold the charge.
A few solutions for you:
1) The batteries that you are using may have reached their end of life.
2) You are using higher capacity batteries in a charger that was designed for lower capacity batteries. The charger may be a 1 hour charger that was designed for say, 1500 mAH. If your batteries are 2000 mAH, then after the same hour, the batteries may not have a full charge, and will be damaged if this were the case, and the practice continues.
3) You are using a combination of batteries and charger that isn't compatible. For example, NiCD chargers cannot charge (usually) NiMH batteries, and vice versa.
4) There is always some drain by the batteries themselves, just being rechargeables. Though, this is usually on the order of 5-10% per month, and probably is not the issue.
I would put my money on saying that the batteries are worn out. Try a new a new charger / battery combination. If that works, then either the old batteries or old charger are defective.
Sep 15, 2009 | Canon PowerShot A590 IS Digital Camera
Bought an MXT DV7000 digital camcorder, but the battery never charges on their charger, tried a new battery still wont charge unable to find contact details or warranty card need to know where can find a...
I had the same problem.
Put the battery in an old Nokia desk charger (the docking type), aligned the contacts as the battery is smaller than the housing and left it overnight.
Eureka. Fully charged
Sep 02, 2009 | Cameras
Phone not charge.
right this happened to me too
its the charging port the pins in it are crushed and when you put in a charger it just pushes them of the plastic so they cant charge
basicly it the charging port
Sep 16, 2008 | Samsung D900i Cell Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
