Question about Simpson Washing Machines
My Simpson Eziset 555 dryer has started beeping repetitively with all lights flashing as soon as I turn the power button on. Does anyone know what might be going wrong?
SOURCE: Hi, my simpson eziset 550
5 beeps with the 3 temp lights flashing means lids not closed. or lid switch not working
i just fixed this problem. the magnet in the lid had come loose. I undid the two screws on the side of the lid put the magnet back where it should sit then i poured candle wax over it to hold it in place and working fine now.
Posted on Apr 04, 2009
  • 713 Answers
SOURCE: My Simpson Eziset 550 won't
Hi just read your posting.Now in your posting you said there were 2 lights flashing.What lights are flashing?Also on a sticker at the back of the machine there is a model number.Could you please reply back and let me know the model number and which lights are flashing.Looking forward to your reply.
Posted on Aug 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: Lid lock light beeping continuously and flashing
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 18, 2010
SOURCE: my Simpson eziset 800 washing machine will not
When I had a problem with my simpson washer, with all 3 water temp lights blinking, it was a blockage in the pump, I emptied the washer and disconnected the host to the pump underneath, then cleared out the pump and put the hose back on, problem solved.
Posted on Dec 18, 2010
caroldon
  • 17130 Answers
SOURCE: Simpson Eziset 750 washing machine - rinse light
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Posted on Jun 20, 2011
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
My Simpson eziset 800 washing machine will not start, I press power on then the button start and beeping alarms starts with the 3 water tap lights flashing, Have checked and clared filters and taps
Nov 08, 2010 | Siemens Washing Machines
My Simpson Eziset 550 won't drain. 2x flashing lights and continual beeping. HELP URGENT PLEASE :-(
Aug 18, 2010 | Washing Machines
Hi, my simpson eziset 550 washing machine wont start, I press power on then the start button and beeping alarm starts with the three water temp lights flashng, this has happened intermitantly in the past...
Nov 30, 2008 | Washing Machines
Washing Machines Logo
43 people viewed this question
Top Simpson Washing Machines Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
